Results 1 to 13 of 13
    Veteran Member Four Rings s vier's Avatar
    Dec 10 2006
    Wisconsin
    Ram air Prototype:
    Please look past the dirty ecode I used for this first one. The headlight should retain ALL functionality with the exception of the highbeam. That includes self leveler, parking light and low beam xenon. The air will run directly through the 3" clear tube into the:
    Stock intake w/s-flo
    X-1 intake
    V-flow
    RS4?
    It will seal up and let zero hot engine air into the intake with everything BUT the V-Flow. For rain I will have an airtight plug to push in to seal out the water. With the plug in it will retain 100% stock functionallity. Remove the plug and gain an extra 50-75% more air flow to the intake without removing your headlight. Keep in mind that this is for the B5 S4 right now but a B5 A4 with an open element air filter will be able to use this as well. This isn't a sales pitch as much as a heads up if anyone is interested. If no one is....oh well, I'll keep building stuff for our cars.
    2015 Suzuka RS5 Black Optics
    Wings
    Carbs
    Titaniums
    Dec 10 2006
    Wisconsin
    Re: Ram air Prototype:
    Wings
    Carbs
    Titaniums
    Veteran Member Four Rings Overboostin's Avatar
    Mar 15 2007
    New England
    looks good. I wonder if you could do the outer seal clear instead of black so it would blend in.
    the homebrew'd s4
    Active Member Four Rings
    Jul 17 2004
    Interesting. Similar to this fiberglass piece I have, except it obviously isn't streetable:
    Alex
    2001.5 Nogaro Blue S4, 6-Speed, ARD 2.7T 68mm HTA GT2868 Kit
    Dec 10 2006
    Wisconsin
    Wings
    Carbs
    Titaniums
    Dec 10 2006
    Wisconsin
    [QUOTE=lil' is 300;2479168]Interesting. Similar to this fiberglass piece I have, except it obviously isn't streetable:
    What intake do you run with your fiberglass "light"
    Wings
    Carbs
    Titaniums
    Veteran Member Four Rings Boris's Avatar
    Dec 20 2005
    District 7
    Hey you know what might look sweet is if you made that ring out of carbon fiber, or covered it in CF
    Veteran Member Four Rings Reich's Avatar
    Oct 14 2007
    2001 s4 ; 2001 jetta tdi
    Val-Belair
    Quote Originally Posted by Overboostin View Post
    I agreed. It would be very interesting. Go ahead ''s vier'' try an other seal. Use clear ones. I'm sure there's a guy looking for this ram air setup. No one will see that in the night driving.
    Forum Moderator Four Rings
    Apr 16 2005
    Pearl City, Hawaii
    Quote Originally Posted by lil' is 300 View Post
    Looks like your S4 got a black eye.
    B5S4/A3S3RS3/Hawaii Forum Moderator - PM Comments/Concerns
    18 Daytona Gray Pearl S3
    00 Laser Red S4 (Sold )
    VAST Performance | BLOUCH | AWE | EvolutionRacewerks | Volk Racing | Vogtland | STaSIS/Alcon | JHM Motorsports | RS4 OEM
    Dec 10 2006
    Wisconsin
    Wings
    Carbs
    Titaniums
    Dec 09 2005
    Sayaovong
    Looks good Brady. I'm interested. Let me know how it turns out.
    2003 RS6 Ebony
    2010 Q5
    2014 Q7 S-Line
    Established Member Two Rings LUKAS(awd4eva)'s Avatar
    Jan 24 2006
    2000 AUDI s4 6 speed
    Frankfort ILL
    this is gonna help alot with the flow. Im definetly iterested.
    Giac chip / Giac race program/ 710n's / rs4 clutch / darintake mod /Neuspeed Titanium 3" Exhaust / 5% tints / valentine one / piggie pipes / tt shift knob / apr snub mount / raderwerks 18'' MTEN80BK wheels / cc mod/
    auto meter boost gauge/ k&n air filter....
    Veteran Member Three Rings sfored's Avatar
    Dec 30 2004
    Hey is that custom or can anyone buy that ?
    thx
    Ari
