Results 1 to 17 of 17
    Veteran Member Four Rings OneBadAudi's Avatar
    Feb 25 2008
    02 A4 Quattro, 09 Yami YZ250f
    Cape May, NJ
    Damn alarm..Please help
    So my alarm keeps setting itself off...I was standing right next to the car and locked it, it beeped and flashed the lights as normal...Then like 2 min later is went off. Nothing touched the car it just went off..So unarmed it and locked it again and what do you know, Went off again...Really pissin me off cuz i cant set my alarm.
    Any help would be appreciated..
    Thanks in advance
    Feb 25 2008
    Cape May, NJ
    Re: Damn alarm..Please help
    O and i did search and no similar problem has been brought up from what i have read....
    Feb 25 2008
    Cape May, NJ
    update...still nothing...Damn this sucks. i cant lock the door without the alarm being set off...
    Senior Member Two Rings sailor's Avatar
    Feb 19 2008
    TBird.TC Miata A4Avant BMW.R80
    Blackhawk, CA
    Try turning the motion and tilt switches off to see if one of the sensors is faulty.
    2003 A4 B6 Avant 1.8T Quattro Sport Tiptronic REVO
    Feb 25 2008
    Cape May, NJ
    How do i turn the switch off for motion?
    Veteran Member Four Rings quat's Avatar
    Apr 06 2007
    A4 Quattro 1.8T, H-D VRSCA
    Pittsburgh
    Its in the drivers door above your trunk release
    Feb 25 2008
    Cape May, NJ
    sweet thanks...will try it...When its off, if its working, what should it do...not set the alarm off?
    Feb 25 2008
    Cape May, NJ
    do u think vagcom will pick it up?
    Apr 06 2007
    Pittsburgh
    Right, if you set your motion and tilt switches to off, the alarm in theory should not go off. If it does go off then it means that it is not one of those switches. And I don't know if VAG will tell you
    Nov 06 2007
    B6 A4 1.8T MQ, B7 A4 2.0t MQ, B8 A4 Avant 2.0T K04
    I had a similar problem and it seemed to be battery related. I had a phantom fan problem that would drain my battery and the alarm would go off due to low voltage. After it did that a couple of time the alarm was acting the same way yours is.
    A new yellow top later everything seemed to fix it self. The alarm went off about a day after the new battery was in but I have not had the problem since.
    Feb 25 2008
    Cape May, NJ
    hmmm i do notice that when the door is open at night, the dome lights flicker, same when i roll the windows up with the door open.
    Dec 06 2007
    ^^something is shorting, or u have a bad fuse!
    -Kirk
    BetaAlphaTau Member #58
    Feb 25 2008
    Cape May, NJ
    So i hit those tilt and motion switches to off( im assuming when they are lit, it means off) and it has not gone off...Yae..So im going to check the battery and alternator.
    Dec 06 2007
    ^^check ur pm's!
    -Kirk
    Feb 25 2008
    Cape May, NJ
    so i checked the battery with a voltage meter and i got 12 when it was off and around 13-14 when it was on at idle...Im goin with it being the battery dieing..pretty sure its the original battery and its got 54,000 on the clock so yep new battery time.
    Dec 06 2007
    ^^thats normal!
    -Kirk
    Feb 25 2008
    Cape May, NJ
    yeh noticed u are having battery problems...the bitch is on my warranty because its not CPO'd, it does not cover battery or alarm but i dont know if its the battery or what...it dosnt say alarm either which pisses me off but i just bought the car so they may be able to do something for me i hope...gotta love dealn with dealers.
