Originally Posted by
gotaudi
evos will run up to 400 HP on the stock intercooler. The down side to the evo intercooler is it is tube and fin, not bar and plate.
do some reading -- tube and fin isn't always worse.... bar and plate has worse heat soak, and if the t/f core is constructed well - it will have the same (if not less) pressure drop. it's ALLLL in design.
there's a reason that supras, evos, skylines, etc all come with t/f from the factory...
and technically speaking, there are new forms of water/air heat exchangers that work FAR better than any air/air setup out there... there's a company which develops parts for the Porsche 944T almost exclusively which has developed a near 0 restriction, 0 pressure drop, and EXTREMELY efficient form of intercooling by using specially constructed piping. i'll try and find the link/article on it.
it's a really interesting design, and i'm tempted to give it a try on the a4 and see if i can't shorten up/simplify my intake plumbing while retaining all of (if not gaining some more) performance.
and the evo IC might work better if you flip it upside down. if you're getting a killer deal on it i say you go for it, if you're going to end up paying what you would for a kit anyways -- just skip on the evo IC
