Results 1 to 37 of 37
    Registered Member Three Rings elgallo's Avatar
    Feb 20 2004
    Wheel Center Caps
    The OEM center caps on my wheels are discoloring and turning yellow. I went to the dealer and they will not replace them under warranty. The parts dept wants $54.00 each. Has anybody experience this problem? What was your solution.
    '06 A4 Sedan 2.0t Front Trak CVT, Quartz Grey Metallic, Ebony Interior, Premium Package, Sunroof Package, Technology Package, 17" Wheels, Bose Audi Simphony XM, Dark Walnut Wood Trim, Votex front wings & Votex rear valance, Vibrant 1304 exhaust tips.
    '06 A4 Sedan 2.0t Front Trak CVT, Moro Blue Pearl Effect, Beige Interior, Premium Package, Sunroof Package, 17" Wheels, Bose Audi Simphony XM, Polished Vavona Light Wood Trim.
    Senior Member Two Rings scottns's Avatar
    Apr 10 2008
    MA, USA
    Re: Wheel Center Caps
    My 2006 has this too but I just bought it a couple weeks ago. When I take it in for the 25k service I'm going to see if they will replace them under warranty. If not I'll prime/paint them myself if I can figure out the right color to spray them.
    Senior Member Two Rings Robr10's Avatar
    Jun 14 2007
    2007 2.0T Q-T
    Boston
    grab them off eBay mad cheap.if not make sure u use a really good cleaner, i use eagle one chrome and aluminum cleaner , works like a charm on my Premium wheels and s-lines, took off all of the gunk,salt,yellow crapola from a rough Northeastern Winter.
    ______________________________________
    07 A4-QGrey 2.0T
    MODS: //Retro-Fitted Xenons//Tint F35%-R25%//Flat Black S-line Valence//S-line Door Blades//Seatbelt chime delete//Remote windows//Retrofit RNS-e//S-line shift knob//RS4 ebrake//18" OEM S4/RS4//Perelli PZero 235/40//DE-Badged
    http://www.flickr.com/photos/8260603@N05/
    Apr 10 2008
    MA, USA
    No, no... The paint is actually coming off the centers showing the yellow plastic color underneath. No cleaner can fix that
    Jun 14 2007
    2007 2.0T Q-T
    Boston
    Quote Originally Posted by elgallo View Post
    oh my bad, from reading his post , doesnt sound like its the paint , sounds like he's talking about the yellow grime that gets stuck around the corners of the caps.. if its the yellow under the paint.. then DEF no cleaner will do that ... lol.. but he still can go to ebay for cheaper caps
    07 A4-QGrey 2.0T
    Senior Member Two Rings intonation's Avatar
    Apr 09 2008
    Lawrence, KS
    This is a common problem, and no, they will not cover it. Order a can of Wurth silver; this is the exact silver paint that is used on the OEM wheels. It will match like a charm. Just sand before you spray, and mask off the chrome center part.
    Apr 10 2008
    MA, USA
    Thanks for the color info !
    Feb 20 2004
    Thanks for the info. I'll probably just buy the paint. Is the paint available thru the parts dept?
    Apr 23 2008
    Orange County, CA
    steal someone else's
    Feb 16 2007
    Same thing happened to mine and the dealer replaced them under warranty about 6 months ago at 25K miles.
    Jan 29 2008
    clarksville, tn
    hey GottaAudi2,
    any chance you can post a copy of your invoice showing this replaced under warranty or some #, etc that references this? i've been to 2 dealers and was denied at both. thanks
    Feb 16 2007
    No problem. Mine's an 05.5 like yours. The paint started peeling and making weird cracks in the clear. Dealer didn't even question it.
    Jan 29 2008
    clarksville, tn
    Sweetness! Thanks man.
    Veteran Member Four Rings Phrost's Avatar
    Jan 24 2007
    1977 VW Type 2 Westfalia
    Wisconsin
    Which wheels are you guys having this problem with? I have the premium split spokes on my 2005 and have no issues... Just wondering if I should expect them to peel soon or not
    Ignorance is bliss.
    Jan 29 2008
    clarksville, tn
    i believe i have the same ones as you; 17" five spoke splitters.
    Veteran Member Four Rings Siggiepop's Avatar
    Aug 20 2007
    B6 A4 . Bus Pass
    Ontario, Canada
    wow i dunno how your center caps have painting coming off it...
    had my car for 4 years and the caps are perfect and its a daily summer/winter
    Jan 29 2008
    clarksville, tn
    i bought it 7 months and 23k miles ago (total mileage is 44k) ; not sure if the orig. owner did something stupid to it or not but only one is jacked up; it's all yellow underneath. i was rather pissed at the dealers telling me that audi was aware but not replacing them under warranty and have just been too busy to bother tracking down a replacement
    Established Member Two Rings MrRevesz's Avatar
    Oct 08 2007
    2012 Audi Q7 TDI
    Mid-Coast Maine
    Mine are doing the same thing on the right side of my car... no idea why... if I don't think about it and look at it, I'm happy... but now that the New England winters have come to an end, and I clean my baby day in and day out... it's horrible... Audi should really cover this as it is their faulty protection screwing up our wheels....
    Veteran Member Four Rings cstarky15's Avatar
    Feb 16 2008
    Oakdale, MN
    mine also have been peeling. i think just 2 of the 4 but i'll have to check to make sure. i go in soon for the 25k and i'll see what they will do.
    Apr 10 2008
    MA, USA
    I bought mine used with just under 23k on it (about 2 weeks ago ) and they came with the paint peeling. It's a 2006 with the 17" split 5-spokes.
    Mar 05 2008
    PA
    Quote Originally Posted by GottaAudi2 View Post
    Besides 'GottaAudi2' has anyone had any success with the dealer replacing the caps? All 4 of mine are pretty bad, some worse than others. My 35k service is coming up soon and would like to know if anyone had any success?
    TIA!
    2006 A4 2.0T Quattro
    Quartz Gray Metallic
    Apr 10 2008
    MA, USA
    Quote Originally Posted by scottns View Post
    Just to follow up my dealer IS covering these. They are on order.
    Mar 27 2008
    06 A4 2.0T Q MT, Jeep GC
    PA
    Yeah find a dealer that will do it!! My 06 had the same problem and someone on here had their dealer replace theirs so i asked my service manager and he took care of all 4 of them under warranty!
    Jan 08 2008
    What dealer in MA do you go to? I was going to go to Bernardi, but never made it out there, I went to Audi of Nashua instead twice and both times they refused to give me new covers.
    Feb 16 2008
    Oakdale, MN
    i'm waiting to hear back from the Rep to see if he will cover mine! he has been out of town the past 2 weeks and today is his first day back. I hope to hear from him tomorrow. My dealership took pics of them and sent them to the rep! we shall see
    The usual things!!
    Resistor Install
    Apr 10 2008
    MA, USA
    Quote Originally Posted by TrustNo1 View Post
    Wagner Audi in Boylston. Closest place to me.
    Senior Member Two Rings unh112's Avatar
    Jan 18 2008
    06 A4 2.0TQ Manual
    Boston, MA
    i want to know which dealer in Mass do you go to also. I asked Prime Audi in Westwood and they want to charge me $54.00. That dealer sucks anyway. Not to mention all they want is your money. They wanted $300 plus labor to fix my headlights which Brookline Audi did it under their TSB. They have nooooooo knowledge whatsoever. i would never do business with them. Sorry for being angry.... :)
    06 B7 Quattro Silver MT
    RS4 Sway Bar | RS4 pedals | S4 Door blades | Votex front spoiler | Votex rear spoiler | revo stage 1 | Forge DV | clear side markers | VAG-COM mod | Eibach pro kit | Koni FSD | 40% Llumar axcess tint | LED license plate light | 6000K HID | 18's B8 wheels 245/40/18 tires with 8/12mm H&R spacers front and back
    Mar 05 2008
    PA
    I actually just called the dealer I bought my car from and the service rep claims that he knows about the issue. I then asked him if this would be covered under warranty and he said, "After a certain period of time it must be approved by the service manager." I then asked him what qualifies for "certain period of time" and he said that first year or 12,000 miles.
    So it looks like if this happens to you within the first year then it's covered under warranty, if it happens after that its gotta get approved.
    Feb 16 2008
    Oakdale, MN
    yeah thats why i am waiting for approval! errr. cross your fingers! some dealerships dont want to deal with it too.
    The usual things!!
    Resistor Install
    Mar 05 2008
    PA
    Does Audi of America do anything about it? It shouldn't even need to go through approval in my opinion....
    Since my dealer says they had replaced a bunch of them I do not see it being an issue. Although with my luck, they'll give me some poor excuse!
    Registered User Two Rings john@fifteen52's Avatar
    May 02 2008
    B7 A4, Mk3.5 Cabrio, Mk5 Jetta
    White Plains, MD
    Here's a picture for those that do not know what the problem is. Excuse the durty car/wheels.
    Active Member Two Rings vedran's Avatar
    Jun 25 2008
    Norway
    I have the very same problem and asked my dealer in Norway. Whaiting for answer (but it seams to me that he is avoiding it).
    However, he didn't avoid to tell me the price which is around 70$ for 1 pcs.
    I would post picture but I don't know how.
    P.S. you can see picture clearly in my gallery
    Active Member Two Rings seriously.emo's Avatar
    Feb 06 2015
    Springfield, MO
    Mine were getting very bad. I don't have a photo of them on the car yet but they look like a factory paint match.
    Sent from my Pixel using Tapatalk
    Veteran Member Four Rings papadelogan's Avatar
    Jul 31 2011
    1999 F250 7.3 Powerstroke
    Gulf Coast of Florida
    After 8-1/2 years, we finally get a pictured of a center cap getting spray painted... I feel like a burden has been lifted off my soul. Thank you emo
    2013 Phantom Black A5 P+ Cabriolet (2.0T quattro) mods4cars, mesh grill, gunmetal VMR 701, HFC "Boudica"
    2007 Ibis White B7 A4 Ti Avant 6MT quattro JHM Stage 2, HFC, Milltek CatBack, GFB DV+ "the YETI" sold
    2005.5 Black B7 A4 6MT quattro sold
    Feb 06 2015
    Springfield, MO
    Lol, I like to resurrect dead threads. I'm sure a lot of people are just like me who googled this and only found thread upon thread of 6-7 years of age. So I thought I'd post up and share people are still going through this issue. The paint color is perfect. I tried clearing the chrome ring and Audi rings and it ruined the chrome, so I repainted over that with chrome again and it just wasn't the same. It's like a slight more metallic shade of the wheel so it looks different but not chrome. I'll post a picture of these puppies on my ride. So you all can see how well they blend. And so you all know, I scrubbed them with soap, rinsed, dried, sanded with 320grit to rough up, then rewashed without soap to get the sanded particles off then dried and painted multiple coats first 2 coats lightly then a thicker coat, then another 2 light coats and a thick coat of clear and a light coat of clear to finish it off.
    Jul 31 2011
    Quote Originally Posted by seriously.emo View Post
    now THAT'S the way to do a necro-bump!! You are learning, grasshopper... but always expect a rash of crap for any necro-bump. That's just the way it is, but I will give you credit for not taking it like a little pansy. Doing that just guarantees an onslaught from the AZ community
    Feb 06 2015
    Springfield, MO
    I'm
    Here ya go!
