Results 1 to 14 of 14
    Senior Member Three Rings Wilco's Avatar
    Dec 11 2006
    1998.5 B5 A4 2.8QM
    Tacoma, WA
    Question Wheels/Tires Question
    I picked up some wheels in a staggered setup (18x8.5 in the front, 18x9.5 in the back) and I'm wondering if those rear wheels will be too wide. Is anyone here running x9.5 that can put my mind at ease?
    Also, what would be a good tire size for these? I'm not really a fan of that stretched look where the wheel is obviously wider than the tire. Just going for the more standard look.
    I was thinking 225/40/18 in the front and 235/??/18 in the back (not sure what aspect ratio would make sense). Does that sound about right? Other ideas?
    EDIT: Offset for both front and back is ET 35.
    BRAND SPANKIN' NEW: AudiWiki.net
    1998.5 Brilliant Black A4 2.8QM
    Veteran Member Four Rings zrowcool's Avatar
    Nov 09 2006
    2000 B5 A4 Quattro / 00 F-150 XLT S/C
    Bronx, NY
    Re: Wheels/Tires Question
    yeah they should fit fine depending on the offset. Test fit them as that can also change the tire size in case they need a slight stretch to clear control arms or the fender lip or maybe even roll the fender lip. There are members here runnin 10" wide in the rear without any rubbing so they should work in theory.
    2000 A4 1.8tq
    Running only on Amsoil fluids.
    Amsoil products at wholesale pricing... Ask me how!
    Veteran Member Three Rings BrokeDown[20V]'s Avatar
    Sep 06 2007
    I ran basically the same wheel sizes, but my tires had some stretch to them.
    18x8.5 ET. 35 - 215/40
    18x9.5 ET. 20 - 235/35
    The rear poked a good amount with that offset.
    Hoped that helped out some.
    Original.
    Mar 23 2008
    Queens Ny
    ^those look sick.. what suspension are you running ?
    Sep 06 2007
    Thank you, Im running H&R coils.
    Original.
    Veteran Member Three Rings dingguhlbary's Avatar
    Jul 17 2007
    New Jerzzzzzzzzzzzzzzzzzzzzzzz
    damn, what wheels are those? twists?
    edit: no cant be twists
    Jul 17 2007
    damn it what are they? i want to buy them. and drive around nj looking for you
    Sep 06 2007
    Haha, They are Mercedes(SL500) Alphards. I sold them 2 weeks ago to a kid with a MK5 GTi
    Now I have BBS CH's.
    Original.
    Dec 11 2006
    1998.5 B5 A4 2.8QM
    Tacoma, WA
    Question Re: Wheels/Tires Question
    Nice pics!
    So if I'm looking at a 35mm offset on both the front and the back, do you think I will be ok clearing the suspension/control arms in the rear? Judging from your pics, it looks like I (hopefully) wouldn't have to roll the fenders to avoid rubbing, but I'm nervous about the other side of the wheel (I'd be basically shifting my rear wheels inward by 15mm compared to yours).
    Veteran Member Four Rings oneohone's Avatar
    Nov 13 2007
    Baur TC2 / W221 S600
    Dallas, TX
    Quote Originally Posted by BrokeDown[20V] View Post
    Wtf, did you fill in the muffler gap on the lower valance??
    Daily - 00' Audi A4 1.8t Quattro 5mt Laser Red Avant
    In.Progress - 00' A4 2.7t Swap (w/ K04's)
    Sep 06 2007
    indeed.
    Original.
    Jul 17 2007
    whoa, is this the set you sold? back up for sale?
    http://www.xrims.com/rims_1995/merce...d_5_holes.html
    Sep 06 2007
    Nahh, Those are wayyy nicer then the ones I had. Those wheels are so sick.
    Original.
    Registered Member Two Rings nyca4tq's Avatar
    Mar 14 2008
    Quote Originally Posted by Wilco View Post
    If your car is a Quattro, there is an issue with differing tire sizes and wear on your drive line and traction issues. My .02.
    F N G here....
    Everything is relative.
