Results 1 to 31 of 31
    Apr 04 2008
    milford, pa
    has anyone ever run new wheels w/o TPMS
    looking at new wheels, but don't want to spend extra for TPMS. Since Audi uses an indirect system, what would happen if I didn't use TPMS? If its just a light on dash, I don't mind. However, if its an ongoing beep, then thats a problem.
    2014 Q5 prem plus, white, Quattro
    Veteran Member Four Rings Phrost's Avatar
    Jan 24 2007
    1977 VW Type 2 Westfalia
    Wisconsin
    Re: has anyone ever run new wheels w/o TPMS
    I believe you can disable the light/sensor with a vag-com, but otherwise it should beep once every time you turn your car on and have a light on.
    Ignorance is bliss.
    Apr 04 2008
    milford, pa
    Quote Originally Posted by Phrost View Post
    I don't have a vag-com. Can someone do this for me?
    Jan 24 2007
    Wisconsin
    You could possibly ask your dealer to do it (most likely for monetary compensation) or else post up your situation in your regional forum.
    Ignorance is bliss.
    Apr 12 2008
    Can the new wheels accept TPMS? Why not just move the sensors from the the stock wheels over to the new ones?
    2008 A4 2.0T Quattro - IBIS White
    Registered Member Three Rings P3RryaudiA4's Avatar
    Oct 15 2007
    2000 Audi A4 quattro
    Brocktron Ma
    take the old tpm that are on ther now and throw them all in the spare tire in the trunk....... problem solved
    until u get a flat and put it on and all you hear are them floppin around lol
    Senior Member Three Rings oakenfolde's Avatar
    Jul 24 2007
    Las Vegas
    spend the money... do it right the first time.
    2005 turbo Acura Rsx-s
    2007 Ibis White A4 Quattro S-line
    2009 Tahoe Z71
    2013 A5 S-line
    Veteran Member Four Rings kooltechie's Avatar
    Sep 04 2007
    '13 S5, '18 540i, '21 ID.4
    Pasadena, CA
    found this on another forum:
    http://forums.vwworld.com/vag/msgs/15937.phtml
    could anyone confirm this????
    2013 S5 Glacier White | Black Alcantara | DSG | Sport Diff | MMI Nav + | B&O | Carbon | Advanced Key | 19" Ti Peeler
    APR ECU/TCU | PSS10 | AWE Touring | EC Alu Kreuz/Sways/End Links | SPC MS Edition UCA | VMR V810 Gunmetal 19x9.5 (et25) | Michelin PSS 265/35 | Xpel Ultimate | 3M Crystalline
    Nov 12 2007
    Grand Junction, CO
    Can a TPMS be added to a car that didn't come with it? i.e mine
    Sep 04 2007
    Pasadena, CA
    just tried it with the "unregistered" version of VAG-COM and this mod seems to require the registered version only.
    Feb 09 2008
    2006 A4, 2006 4Runner
    Colorado Springs
    Been running my wheels without the TPMS sensors for about a month now, it beeps everytime I start it and I have the tire flat light all the time, which sucks, but still trying to track down a registered VAG-COM in my area. Both the Audi and VW dealers were no help, FWIW.
    Registered Member Two Rings The Broker's Avatar
    Feb 27 2008
    E90 M3 - MK5 Rabbit
    I disabled TPMS through vag-com, it takes less than a minute. I do enable it when I put my winters on as that set has the sensors.
    Sep 04 2007
    Pasadena, CA
    Quote Originally Posted by The Broker View Post
    I suppose you have the registered version of vag-com?
    so the instruction to disabe the TPMS on audiworld/vwworld is correct then?
    Apr 04 2008
    milford, pa
    don't understand the logic behind the indirect TPMS that Audi uses. It works only if one or more tires are lower by 25% than the rest. It doesn't tell you the pressure, nor does it say what is underinflated.
    The US Government mandated it so drivers would not have underinflated tires, thus some direct systems tell the amount of pressure in each tire. The system Audi uses doesn't do what is required, thus is a waste.
    Jan 24 2007
    Wisconsin
    Thank god my 2005 didn't come with the tpms I was nervous when I first put my winter wheels on, because I wasn't sure. ron717 is right though, the system sucks and needs to be re engineered.
    Ignorance is bliss.
    Dec 30 2007
    08 A4 Black Avant 2.0T 6Spd
    Cleveland, OH
    I just had the dealer put my TI Non TPMS tires on my 08 Avant and was told that the light could not be overridden via Vag Com on 2008 models. The dealership told me they would not have a problem turning the warning off if they could.
    Jan 24 2007
    Wisconsin
    The dealership can, but I think most of them wouldn't want to or would say they can't since using a vag-com to delete/modify codes isn't a normal thing to do. If one of the techs are enthusiasts they probably would, but the others just wouldn't want to mess up your car doing something that isn't exactly recommended to do.
    Ignorance is bliss.
    Established Member Two Rings lowandslow's Avatar
    Dec 15 2007
    Surrey
    Audi uses a direct TPMS
    Indirect TPMS takes readings off the ABS wheel speed sensors
    Direct TPMS takes readings from a sensor inside the wheel... which Audi has
    Matt
    Apr 04 2008
    milford, pa
    Quote Originally Posted by lowandslow View Post
    Matt
    Not true. Audi uses indirect, which works off wheel speed sensors in the ABS. If it was direct, it would show the actual reading of what tire was low. This system in the 2008 A4 only warns you when one tire is lower than another--this is indirect.
    Veteran Member Four Rings EuroA4's Avatar
    Feb 12 2004
    PA-NJ
    2008 models can not be done via VAG-COM!
    Apr 12 2008
    Maybe I'm not understanding something here but again...
    Quote Originally Posted by OneDollarBill View Post
    This is what I did and everything works fine.
    Feb 27 2008
    E90 M3 - MK5 Rabbit
    Quote Originally Posted by kooltechie View Post
    Correct
    Sep 04 2007
    Pasadena, CA
    Correct
    do you have an '08 A4 or the previous year model?
    it seems that the '08 models have a "direct" monitor system whereas previous year models have an "indirect" system.
    thanks!
    Apr 04 2008
    milford, pa
    thanks!
    If the 08 which I have has a direct system, then why per owners manual does it state that it only senses loss of pressure when compared to other wheels?
    I don't plan on using TPMS in my winter wheels, so what will happen?
    Dec 15 2007
    Surrey
    Audi's use a two piece in wheel TPMS sensor designed by a company called Beru. I just went over this in a training seminar put on by TIA.
    http://www.beru.com/english/produkte/tss.php
    Maybe this is only in the 2008 models do to the new manditory TPMS systems by law in the US
    Sep 04 2007
    Pasadena, CA
    Quote Originally Posted by ron717 View Post
    if you read OneDollarBill's posting, it seems kinda clear that '08 A4 has tire pressure sensors in the wheels thus it's a "direct" system.
    maybe Audi didn't want to spend extra money to display individual tire info on DIS.
    Feb 27 2008
    E90 M3 - MK5 Rabbit
    thanks!
    I have an 06 but I have also disabled TPMS on an 07.
    Sep 04 2007
    Pasadena, CA
    I believe '08s are the only ones with the direct system....'07 and older A4s have the indirect system (I'm positive I've read this somewhere, but can't find it).
    not sure if it's the same way TPMS can be disabled on all B7 A4s, but it'd be nice if it is.
    Veteran Member Four Rings cstarky15's Avatar
    Feb 16 2008
    Oakdale, MN
    Quote Originally Posted by P3RryaudiA4 View Post
    I'm pretty sure that they use the same valve or connect to the valve to read the prssure. you can't just throw them inside the tire.
    As for audi not wanting to spend the money, the A8 shows what tire is low.
    Apr 12 2008
    I just got my 08 2 weeks ago and the all the TPMS tells me is that I have a tire with lower pressure, but does not tell me which one or what the pressure is.
    Like I said when I got my new wheels they removed the valve stem sensors from each of the factory wheels and installed them on the aftermarket ones. Once I verified the tire pressure was correct in all four I told the computer going through the stalk on the steering column "new wheels" and "record tire pressure". It's been fine ever since.
    Veteran Member Three Rings mksap11's Avatar
    Apr 06 2005
    Boston, MA
    It is a direct TPMS system and is the same one used in the C6 A6 and Q7. Here's some more information about them. In addition, my guess is that most dealers would refuse to turn off TPMS since it is now a federally mandated requirement to have them. It's almost like asking your dealer to install a test pipe for you.
