I BROUGHT THIS INTAKE SYSTEM FOR MY B6 A4 IT WAS INSTALLED FOR A TOTAL OF ONE DAY CAUSE I SOLD MY CAR THE NEXT DAY SO THIS UNIT IS NEW. THIS SYSTEM COST ME $140 I BROUGHT IT OFF THE INTERNET.
02-05 Audi A4 1.8T High Performance Air Intake
Brand new direct bolt-on 02-05 Audi A4 1.8T High Performance Air Intake , everything you need to install is is included, made specially for the A4 this is not a universal kit . Comes with Urethane FIlter that will last you a lifetime and comes with breather filter as well, includes aluminum intake pipe that will accept your MAF no mods or welding. Get a nicer sound, hear your DV releasing boost , improved engine response and better performance with this kit, let your Turbo breathe better and notice the power gains.
These will also fit some 1997 to 2001 A4 Turbo we had sold a few for 97-01 but you need to make sure that you have the correct MAF , different MAF's were fitted depending on year, the diameter of the MAF sensor hole on the intake pipe is 1 11/32 inches (34mm) your MAF sensor when measured should be less then 1 11/32" if you have a larger one it will not fit.
