Results 1 to 33 of 33
    Mar 30 2004
    jersey
    Buy a stg 3 or build one....
    i am buying a s4 again because my evo is too much to drive on the street. More of a track car now. The question is as the topic states. I have talked to mark from asp. Have known him since he started and value his thoughts. He said to buy a stockish s4 and send it to him for the rs6 kit because i feel that a pj ko4 kit wont be enough. My evo is 350whp and 2990lbs. The ko4 that i saw make this power at 500+ more lbs weight. I have about 28 or so to spend total. So should i buy a stock s4 for 14 or so and have it worked or buy a stage 3 already done for 19 or so and get the rs6 kit and sell the k04s. Thanks
    Jun 14 2007
    2000 S4
    Connecticut
    Re: Buy a stg 3 or build one....
    personally, i like the fact that i bought my car stock and brought it up since then to 3. since you have all this spare change though it really doesnt matter, i mean dont forget all the maintence that has MOST likely been done on a stg 3. (timing belt, waterpump) all that fun stuff, and the small odds and ends.
    Jun 14 2005
    Central US
    Back to the S4s eh? I recall your post about the S4 being stolen and how the po po were unable to catch the thief in you car.
    Build a nasty one.
    Mar 30 2004
    jersey
    Quote Originally Posted by rharris View Post
    Build a nasty one.
    yeah it was taken on a 170+ high speed chase then they blocked off rt280 in jersey. The brembos brought them safey to a stop when the exit the highway and crashed the car. sucks
    Mar 30 2004
    jersey
    Veteran Member Three Rings S4tranquility's Avatar
    Dec 29 2005
    Baltimore
    Buying a stage 3 will probably be cheaper in the long run unless you get a great deal on like a stage 2/2+ that already has some good usable mods (exhaust, suspension, etc)
    19 S4 Prestige & 17 Q7 Prestige.
    Former: Tesla P3D; 6MT 13 S4 (dual pulley); multiple B5 S4s
    B5 S4 120+ club; Sleeper, Stages, and more B5 S4 vids
    Mar 30 2004
    jersey
    Quote Originally Posted by S4tranquility View Post
    yeah i am just worried about the power. I guess the way to go is rs6 for the power i have seen it make. so yeah if i could find a nice stage 2 i would do that and the rs6 kit.
    Veteran Member Four Rings Overboostin's Avatar
    Mar 15 2007
    New England
    Personally, I would buy one that's already modded a bit to save some money. If you have the cash though, get a stock one.
    the homebrew'd s4
    Veteran Member Three Rings DefiantS4's Avatar
    Jul 30 2004
    Houston, TX
    I would personally find a nice well-built stage 3 car (suspension, BBK, the works) and sell the stage 3 components that aren't needed for RS6 turbos. You will spend a lot more building up from stock. Use the savings for more mods and/or insurance in case something breaks.
    Past - '01.5 S4, APR Stage III
    Mar 31 2008
    eS-4
    CAL*SO
    you'll save more money just finding a used stg 3. cuz if u think about it if someone HAD the money to stg3 their car that means they've already replaced everything that needs to be repaired anyways(bushings, belts, pumps etc...)
    The same throttle body and corn toon as everyone else.
    A ported blower and the mega bitch pulley.
    Lots of water and wheels lighter than my bank account.
    Veteran Member Four Rings McKennaS4's Avatar
    Sep 25 2006
    2500 dodge ram diesel
    Boston, MA
    if you think k04s are not enough bring your 350whp, 2900 lb evo out and i (or anyone in jersey with a healthy stage 3) will show you what a healthy stage 3 car is all about... jw why is a 350whp evo too much for the street? friend of mine daily drives his 680whp evo and loves every second of the drivability. is your car caged and gutted or something? anyways an aggressive fueling setup stage 3 will be faster than your evo all day (something similar to epl's fuelling kit) so i wouldn't waste your $ on rs6's if you think your evo is too fast =P
    01 Casa sedan 6MT, sport, cold
    Veteran Member Four Rings Tifosi's Avatar
    Apr 27 2004
    Pacific NW
    +1
    Stage 3 S4: Cheaper, unless there are issues to iron out or mods that you do not like.
    Stock to Stage 3: Allows you to add you own personal touch and no guess work to exactly what was done or not done on the car.
    If you are anal about your cars like many of us here are, I think it is better to start with a stock S4 first. Remember, the journey is part of the fun of owning a Stage 3 S4.
    Mar 30 2004
    jersey
    Quote Originally Posted by McKennaS4 View Post
    not that the evo is too fast at all. i was going to go 30r. The problem is its got recaro pole positions, all sound deading, backseats, trunk material removed. You can hear every rock, exhaust drones out the car(hard to talk on your cell phone), 255/35/18 on 10k suspension, and a on/off clutch. also close to -3 camber. tracks really bad.
    btw the way where are you located because i would like to go in a k04 car to feel it.
    Nov 17 2006
    b5S4, b8.5 Allroad
    Las Vegas
    mckenna is right and also there are plenty of k04'd b5's putting down 400whp.. 350 is modest for stage 3.
    Veteran Member Three Rings MiniRS4's Avatar
    Aug 11 2005
    Exclamation Re: Buy a stg 3 or build one....
    Quote Originally Posted by ROUGHEDGES View Post
    welcome back dude!
    PSA/FYI to all, this man is an OG. had one of the hottest B5's around back in the hay...
    $28k is a small fortune. its really hard to find low mileage clean S'. but def try n get a low mileage clean one and then RS6 it. id say VAST or EPL over ASP. both proven, the last one isnt. that is all.
    Senior Member Two Rings PoloIceberg's Avatar
    Oct 12 2006
    Bx, Ny
    My stage 3 is for sale...hint hint
    Mar 30 2004
    jersey
    Quote Originally Posted by PoloIceberg View Post
    do you ever come into the jersey area?
    Jun 14 2007
    2000 S4
    Connecticut
    what the hell! you go back and forth! now youre selling ?!
    Senior Member Two Rings quickdub's Avatar
    Jul 06 2005
    1973 Mustang Conv.
    CA/NJ
    I wouldn't bother with an all stock car... atleast get one with brakes and suspension... and maybe wheels or something.
    I was happy to find mine with tasteful mods... saved me about $5k in parts that I would've bought later on.
    Veteran Member Three Rings ubermidget's Avatar
    Dec 08 2006
    Boston, MA
    if your looking for a strong stage 3 check out my car.....i walked a gt3 and an 01 viper the other night...lets just say they were disappointed they spent all that money and some audi beat em...bad
    EPL Stage 3 Aquamisted
    Awaiting Confirmation Two Rings
    Oct 06 2006
    Mt. Laurel, NJ
    Quote Originally Posted by MiniRS4 View Post
    welcome back dude!
    lol
    Mar 30 2004
    jersey
    Quote Originally Posted by Frank@AutoSpeed View Post
    lol
    I have been talking to mark over the last two days about your rs6.
    Veteran Member Four Rings GURUMAN's Avatar
    Mar 13 2007
    2.9L PTE 6766 1000 Bhp single Monster !
    Montreal
    Get use to it Frank, welcome to AZ, it's happening to me when I cross to AW. Where it's Autospeed land...
    Veteran Member Four Rings S4 in_lowplaces's Avatar
    Feb 09 2006
    2021 SQ8, 2000 AWE stg 3 s4, 2012 CTSV 730Whp, Sold: 2000 Stg2 S4 revo,Totaled: 2000 Stg1 S4 APR
    Huntington Beach
    You coudl buy a stock one for 14, and have 14k left to mod it.
    You coudl buy a stage three already done for 19, and have 9k left for modding.
    With a stage 3 you can sell the turbos, the intercoolers, but that motor has already been beatin on.
    Buy a stocker, For 14k you can definatly turn it into a beast.
    2021 Ocra blk SQ8 - Daily
    2011 CTSV coupe 730 WHP - Garaged
    2000 Silver B5 S4 AWE stg 3 - Garaged
    2002 Silver b5 s4 stage 2 revo - Totaled
    2001.5 silver apt stg 2 b5 s4. - Sold
    Mar 31 2008
    eS-4
    CAL*SO
    what if lets say you could drop 10k on the spot and take a loan for the rest but not wanting to go over 16-17k when all is said?
    Veteran Member Four Rings EvilllEmpirE's Avatar
    Jun 23 2004
    2001.5 S4 Laser Red Avant, 1996 993 C4S Twin Turbos, 2007 997 GT3, 2020 X3MC
    Scotch Plains NJ now!!! =)
    we can do some pulls with your Evo and see if K04 power is enough for you Adam
    117-118 mph traps on pumpgas and 120-122 on racegas isn't enough power?
    Out of Bounds Snowboard Shop
    2520 Rt 22 Scotch Plains, NJ 07076 908-232-4500
    (Vans Capita Union Bataleon Lib Ride Oakley 32 Boots)
    2001 Nogaro S4 Avant
    2001 Laser S4 Avant
    2001 Imola S4 Avant
    2020 BMW M2 Comp
    2020 BMW X3M Comp Wife’s
    2007 Porsche GT3
    1996 Porsche 993 C4S Protomotive TT
    Senior Member Three Rings b5rs4's Avatar
    Aug 30 2007
    bmw x5
    winter springs, fl
    buy mine pm'ed
    Oct 12 2006
    Bx, Ny
    You seem upset...lol, yea im moving on to something else its time
    Dec 08 2006
    Boston, MA
    wanna trade your tin can evo for my car?
    always loved the feel of an evo
    Veteran Member Three Rings quicksilver_S's Avatar
    City that never sleeps
    Welcome back. I personally are back to an S4 avant as well. I still have my evo for fun times but uses the S4 for more casual/comfort driving.
    Good luck. I think you should buy a semi-modded S4 and build your own stg3 s4. Buy the yellow S4 with the FMIC. Ive been eyeing that car but I cant afford a third car: )
    Mar 30 2004
    jersey
    Quote Originally Posted by ubermidget View Post
    Yeah depending. i had somebody else ask me this but wanted me to de mod somethings. All in all you would problary have to put money in because the book value of my car is 28k. It has 19000 miles. 10k in mods
    Veteran Member Four Rings Turtle's Avatar
    Oct 09 2006
    Thinking......
    Los Angeles, CA
    I say don't buy a stock S4..... I did and I regret it. could have saved a WHOLE lot of money
    2000 Audi B5 S4 WMS RS6 Stage 3
    *Rods
    F/S: Koni Adjustable Coilovers - BNIB -$1000
    Mar 30 2004
    jersey
    i have been talking with spturks today. i am going to check out his car
