Results 1 to 9 of 9
    Registered Member Two Rings tristate_s4's Avatar
    Dec 20 2006
    01 audi S4,93 corrado 97 jetta
    SNJ
    opinions on clutch removal
    still deciding if i want to pull motor and trans, or just the trans?
    not sure if ill have a lift available, so my options maybe limited.
    oh and ill be doing piggies while apart.
    any opinions??
    i just did my tb a few months back and no problems.
    much appreciated.
    P
    Dec 06 2007
    Calgary, AB, Canada
    Re: opinions on clutch removal
    Just the trans if you have access to a lift or a pit.
    If you don't, but have access to an engine hoist, then pull the engine and tranny.
    Established Member Two Rings DAP's Avatar
    Mar 16 2004
    Having done both (transmission on a lift, motor on jackstands), I prefer to pull the motor & transmission together.
    Veteran Member Three Rings MiniRS4's Avatar
    Aug 11 2005
    Quote Originally Posted by DAP View Post
    2nd!
    it more convenient together, but still a lot of work. im assuming you are doin this at home or in a garage, so you'll need a bunch of stuff to get you off the ground.
    -lift
    -jackstands (2 is enough)
    -cherry picker
    -palette (to drop your motor/tranny onto)
    anything else i forgot?
    Jan 09 2008
    01'NB'S4 sold 04 LSBlue M3
    VA
    Some beer and a water pipe for tobacco use would be nice while working with these cars.
    Aug 11 2005
    Quote Originally Posted by JayyyyyC View Post
    2nd!!!
    Dec 20 2006
    SNJ
    jack stands- check
    engine hoist-check
    water pipe for tobacco-check
    ok sounds like ill pull the whole drivetrain out
    yay
    Dec 06 2007
    Calgary, AB, Canada
    I've also done it both ways (tranny in a pit, and engine/tranny on jackstands), and I can tell you that it's about the same amount of work, it just depends on what you'd rather EFF with, axles, tranny mounts, and dp's, or the rad support, AC, and PS pumps and lines. Also, if you pull just the tranny you don't have to drain any fluids. If you pull the engine as well you have to drain pretty well all of the fluids minus the brake fluid.
    Like I said, you don't have a lift or a pit, just pull the engine/tranny together. If you DO have either of those things, I'd rather just pull the tranny, myself.
    Veteran Member Three Rings Dowskeet's Avatar
    Aug 10 2007
    Those are always key tools whenever your tackling things on Audis lol.. More the second than anything else.
    Happy 'in
