Results 1 to 4 of 4
    Senior Member Three Rings skiroad'r's Avatar
    Apr 21 2008
    2002 allroad Tip, 2005 Mazda 6 Wagon 5MT
    Central New Jersey
    noob exhaust question
    What is the function of the center resonator?
    In a few of the custom exhausts I've seen, some eliminate the resonator and pipe 2.5" all the way back to hi flow mufflers, others substitute an x-pipe in there.
    Is it just a taste/exhaust tone different or is there any other functionality to it?
    '02 allroad 2.7T Tip
    ASP Flash, 034 Snub Mount (DIY), VAST EFK (DIY), H-SPORTS (Hard)
    Anrott Gen II Front Airsprings (DIY), Magnaflow mufflers with 3.5" tips
    Summers: Yokohama Avid W4S/RS6 Reps
    Fog DRL's, Toggable 628 Relay, Tip Override Recode, Remote Window Recode, Clear Corners (DIY)
    Timing Belt DIY (at 60K miles), Tiptronic Drain & Refill Service DIY (at 62K miles)
    GET OEM PARTS HERE: http://www.europaparts.com/
    Senior Member Two Rings A4CE1's Avatar
    Feb 10 2008
    06 A4 2.0, 03 Wrangler, 96 XJ
    Westchester, NY
    Re: noob exhaust question
    reduce back pressure. sounds better if you keep the resonators and cut the mufflers out and weld in pipe and some nice tips IMO. Thats what i did on my 02 allroad. sounded nice and mellow and gave it a little extra juice.
    VW Touareg V10 TDI. Don't mess.
    Past: Stg. 2+ B7 2.0T, B6 A4 1.8T, Allroad 2.7T 6spd (<-monster), Chevys, Jeeps, and a Nissan.
    Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car. Horsepower is how fast you hit the wall, torque is how far you take the wall with you, Body kits and decals are how much of a mess you leave on the wall.
    Feb 01 2008
    Missouri
    How loud is nice? I heard a mazdaspeed 3 running resonators and it was a little to loud for me!
    Apr 21 2008
    Central New Jersey
    I ended up keeping the resonator and put on magnaflows instead of stock mufflers. Perfect IMO. Loud enough w/o being ricey or obnoxious.
