Results 1 to 10 of 10
    Veteran Member Four Rings Boris's Avatar
    Dec 20 2005
    District 7
    How would hybrid KO4's run on stage 3 fueling meant for normal KO4's?
    I have full stage 3 right now and am thinking of perhaps getting a little more pep.
    If I were to have a shop install some hybrid ko4's, how would it react to stg3 fueling?
    I have a mbc also.
    Just wondering if there would be gains, or if that would not be available until it was custom tuned ?
    Veteran Member Four Rings S4 in_lowplaces's Avatar
    Feb 09 2006
    2021 SQ8, 2000 AWE stg 3 s4, 2012 CTSV 730Whp, Sold: 2000 Stg2 S4 revo,Totaled: 2000 Stg1 S4 APR
    Huntington Beach
    Re: How would hybrid KO4's run on stage 3 fueling meant for normal KO4's?
    I assume it woudl be the same principal as going from k03's, to k04's and then keeping the stage 2 software, You woudl only be running stage 2 software. Although you have the MBC so you might be able to do a bit more with out affecting anything else. Good question though. I wanna hear what everyone says.
    2021 Ocra blk SQ8 - Daily
    2011 CTSV coupe 730 WHP - Garaged
    2000 Silver B5 S4 AWE stg 3 - Garaged
    2002 Silver b5 s4 stage 2 revo - Totaled
    2001.5 silver apt stg 2 b5 s4. - Sold
    Feb 17 2004
    Sterling, VA
    Quote Originally Posted by Boris View Post
    I have a mbc also.
    If you have 60Lb injectors, you should be fine. You'll obviously need to re-tune the maps to work properly with the new airflow rates and the fuel to match it.
    If you have 42Lb injectors, you probably will be stressing them too far. Regular K04s come close to that as it is.
    Brett - Moderator
    Issue?: email me.
    _____________________
    Stage 3 2004 A6 2.7T 6M
    Dec 06 2007
    Calgary, AB, Canada
    ^^depending on what altitude you're at, of course
    Feb 17 2004
    Sterling, VA
    Quote Originally Posted by The_Jerbel View Post
    By altitude do you mean closer to sea level?
    The higher in elevation, the less actual oxygen there is to burn.
    Brett - Moderator
    Issue?: email me.
    Dec 06 2007
    Calgary, AB, Canada
    Exactly, the higher in elevation you are, the less fuel you need to maintain the proper AFR. For example, I'm at 4000 ft and my 42lb GG's only get pushed to about 85% of their potential.
    Feb 29 2008
    Durham/NC/Southeast
    It all depends on the tune. I have hybrids and on different versions of the AWE files they have runs great and poorly. What software are you running now?
    Dec 20 2005
    District 7
    You know I guess they are not even worth the $
    Its about $1350 for the upgrade, and I would be netting maybe 30 more horse max it looks like...and I guess it looks like it would definately need a custom tune then on top of it
    Either way thanks for the input
    Feb 17 2004
    Sterling, VA
    Oh ok, I didn't understand where you were going with that at first...yeah that's a good point. Not to mention that GG's are smaller volume than the plain old green top (410cc vs 440cc).
    Air pressure drops like .5Psi for every 1000ft above sea level. Your ambient air pressure is like 12.5Psi..hehe.
    Brett - Moderator
    Issue?: email me.
    Dec 06 2007
    Calgary, AB, Canada
    Brett,
    Are you sure about the flow of the GG's vs the GT's? I'm quite positive my GG's are flowing ~500cc @ 4bar...
    for reference:
    info
    more info
