Results 1 to 40 of 42
    Nov 04 2006
    05 S4
    LI, NY
    Talking Snub mount.....go get one
    well after having this little cheap black rubber mount sit on my desk for almost a year...I installed it today after work. WOW!!!!!!!!!!!!! is all I have to say. EVERYONE should go buy one now. and EVERYONE should pay to have it installed ;)
    the install really does suck. Took almost 3 hours of bleeding knuckes, burning arms, and leaking washer fluid : but well worth every once of sweat. I had to grind down my snap-on allen wrench but its all good. Aligning the bumper back sucks too.
    Also....note when installing the mount back on the block, the top allen bolt was a bitch to start threading. What was happening was because the snub is soo much bigger....its size actually gets in the way of the bolt turning smoothly. Sooo....what I did was use a small file and took off maybe 1mm about 1 cm wide of the snub for the bolt to thread smoothly. Some might wanna consider this.
    And after the roadtest, almost every once of sloppyness and harsh shifting is gone. I really cant believe how much smoother and more fun the car is to drive. Well worth every penny even to have it professionally installed. Let someone else do it ;)
    And lastly....thanks to eddieman and all the other posters with their write-ups and guides.
    Oetty roof spolier // FI Catback // Ecodes // Xenon Interiors // Solaris and LED Exteriors // Lower Euro-grille // ECS Snub // PSS9s // 19x8.5 BBS CH on 245 Potenzas // Euro RS4 Exclusive shift knob and Pedal Set // Carbon Fiber Trim // Custom Carbon Fiber Emblems
    Originally Posted by Justincredible
    "With the flux mod you can just put the supercharger in the trunk for extra traction"
    Veteran Member Four Rings channad's Avatar
    Oct 14 2007
    2008 S4 DTM; 2017 Q7 Prestige
    Mammoth Lakes, Ca
    Re: Snub mount.....go get one
    word! Eddie Man's write up is phenomenal!
    ChannaD aka Techno Dad | New DJ Mix | New YouTube Video!!
    2012 Q5 - Black | Black | Premium Plus | S-Line | Nav | B & O
    2008 - DTM | Sprint Blue Pearl | Black leather/Alcantara | Navi | CF trim | OEM 18" RS4s
    Senior Member Two Rings B6_Rakete's Avatar
    Apr 17 2008
    '04 S4 Avant 6sp, '06 330i 6sp
    Quote Originally Posted by ant7701 View Post
    I thought the aftermarket mount was stiffer than stock!? Would this make the shift shock worse?
    Veteran Member Three Rings cam's Avatar
    Oct 11 2007
    NYC / west palm / las Vegas
    Quote Originally Posted by B6_Rakete View Post
    no, cause it takes away the slop associated with the soft stock mount.
    to the OP, which mount did you end up installing, im looking into getting one in the near future.
    Dec 30 2007
    Constantly changing.
    DC
    Quote Originally Posted by cam View Post
    I too am interested in knowing this.
    Nov 04 2006
    05 S4
    LI, NY
    ECS snub
    Dec 30 2007
    DC
    ECS snub
    Thanks.
    Veteran Member Three Rings S4J's Avatar
    Sep 26 2006
    Nor Cal
    Super mod for the buck
    "Will power? I've got all kinds of will power...it's the WILL NOT power I'm lacking." saj
    || MoroBlue/Silver/6sp/Prem pkg || JHM LW Pulley & Mani Spacer || APR Snub || H-Sport F/R || Bilstein PSS9's || Neuspeed SS || GIAC || K&N || Full Milltek Res || Apikol Rear Diff Mount || Ind Fog Mod || PIAA Xtreme 4150K Fogs || E-Codes || Carbotech Bobcat Brake Pads || RS4 Pedals || V1 W/Remote-mute in Shift Boot || Vellano VSQ 19x8.5 || ECS Rotors ||
    Veteran Member Four Rings b00st's Avatar
    Oct 17 2004
    04 B6 S4, 08 RX350
    St Charles, IL
    i have an ECS snub sitting on my desk as well. i will pay the 80 bucks and get it installed. i'm way to lazy at this point to screw around with that.
    The RIDES:
    2015 M3 - BM3 stage 2
    2011 335 Msport - FBO + E85 sold
    04 S4 - JHM 93oct Tune | JHM Piggies | FI CB | JHM Intake Spacers | JHM Stage 4 Clutch | JHM LWFW | JHM LW Rotors | Snub | K&N | 034 Density Motor Mounts |SOLD
    99.5 A4 PC16 K04 - SOLD-
    http://www.cardomain.com/ride/2404758
    AMA Member
    JHMFTW!!
    Registered Member Two Rings 37doc's Avatar
    Oct 24 2007
    B7 S4,03 R1,04 Taco 4wd,75 RDs
    Southern Maryland
    I too installed my snub a couple days back, and I hear you on the upper allen bolt! What I disd is install the upper bolt and washer all the way flush on the mount and the screwed the mount to the engine with my fingers, it worked fine , then I installed the two easy ones. I also used a couple pieces of 2x4 to seperate the bumper bracket from the engine to give me the room I needed. I also did my AWE DP's a week or so back and , can say id rather do downpipes than another snub.... Anyway cograts on the install ! Im stopping by a shop called Induktion motorsports to see about a GIAC load !! Take it easy .
    05.5 B7 S4,silver,6MT, black leather recaros,Carbon,Bose, cold weather,AWE DP's, Neuspeed cat back, GIAC 93/stock,Neuspeed short shift,BMC filter, RS4 pedals,shift boot/knob,and e-brake handle,DTM carbon rear spoiler,TCarbon rear valance,Kerscher DTM carbon splitter,DTH carbon engine cover, RS4 Optic grill, H&R swaybars,Hella optilux xenon H11 fogs,ECS snub mount,VMR 18" RS4's,stoptech F/R SS brake lines,Audi Rear sunscreen.
    Oct 24 2007
    Southern Maryland
    oh yeah also installed my Kersher splitter ! Eddiemans DIY helpful again ! thanks to everyone for the DIY's !
    Veteran Member Three Rings PburghNogaro's Avatar
    Dec 04 2006
    04 Nogaro S4, 71 Pontiac Grandville
    Pittsburgh, Pa
    I agree, great mod for the price, though it was a little PITA to do. Eddieman's write up was a huge help.
    7doc, did you use a DIY for the DP install?
    http://www.youtube.com/watch?v=1ebxoOBIi-k
    2004 Nogaro S4 6MT - Sold
    APR res full exhaust - APR ECU - APR Snub mount - K&N - 19 BBS CKs
    1971 Pontiac Grandville
    2012 Jetta TDI
    Apr 13 2007
    Chicago
    I also had an ECS snub mount installed last week and it's amazing how much smoother the shifts are. I read all the posts about how great a mod it is but didn't realize how much of a different it makes ... especially the shift from 1st to 2nd ... silky smooth.
    Mar 02 2008
    Cleveland
    Quote Originally Posted by b00st View Post
    $80? Probably a lot more than that! Current labor rate in my neck of the woods is $98/hr, and if it took this guy 3? I will find out, though, as my car is in the shop to get the aux radiator replaced, I told them to put in the snub mount while they are in there, hopefully it won't require too much extra for the tech. Looking forward to see what this $39 part can do!
    Oct 24 2007
    Southern Maryland
    I agree , if you can fid a competent mechanic to install the snub for $80 DO IT NOW! It took me approx 3 hours as well, it took 4 for the snub and the splitter... Anyway its the part where you have to seperate the bumper bracket from the engine to get the room you need and even with the bumper mount allighnment nuts backed all the way off its tight!
    Mar 02 2008
    Cleveland
    I can't find Eddies' writeup, can someone point me to it?
    Oct 24 2007
    Southern Maryland
    check audiforums DIY?
    Veteran Member Four Rings Jrunr's Avatar
    Oct 27 2004
    2007 Audi S4, Phantom
    El Paso, TX
    is there a difference between the ECS and APR snubs?
    Veteran Member Four Rings SuperAvant's Avatar
    May 30 2007
    MA
    How much of a pain is it to align the bumper? I thought it was pretty much self aligning?
    2014 R8 V10 - Gated
    2005 S4 Avant 6 Speed - JHM Stuff
    2017 TRDoffroad 4 Runner
    Oct 24 2007
    Southern Maryland
    the bumper has 6 bolts that hold it and the lower bracket to the frame rails, 3 on each side, and one smaller allighnment stud with a nut on it , after removing the 6 bolts,I just loosened the allighnment stud nut all the way back not removing it. That allowed me enough play to put the 2x4's in between the bumper bracket and the engine.
    Veteran Member Four Rings trexturk's Avatar
    Mar 20 2007
    '11 Sprint Blue S4, 03 996 Targa
    Chicago Burbs
    i also installed the ecs snub. But i didnt take off the front bumper.
    It was harder to go around things, but i would rather do it this way then taking off the front end.
    It took about a good 3-4 hours to get this done taking my time.
    Senior Member Two Rings BGEDWN's Avatar
    Mar 28 2007
    B7 S4 MT6
    Bronx, NYC
    Quote Originally Posted by Jrunr View Post
    Search the boards for snub threads and you will see some older posts where the APR snubs supposedly failed for some people.
    I was quoted 2 hrs labor for the snub install. So you're looking at approx $180.
    '06 B7 MT6
    Sprint Blue / Silver - RNS-E / Bose - Premium Pkg
    Corsa Catback / ECS Snub / RS4 Pedals / Hoen Xenonmatch / K&N
    Senior Member Two Rings ZONAWILDCATS4's Avatar
    Apr 14 2008
    996 Carrera 4s, 2018 F85 X5M
    WheatonIL
    I got mine done 2 weeks ago at Renn Art in Arlington Heights for $80.
    Registered User Four Rings Mike@PureMS's Avatar
    Jul 19 2007
    San Diego, CA
    Fantastic and inexpensive upgrade!
    Stern Snub Mount
    Senior Member Three Rings asurugger's Avatar
    Mar 12 2008
    2008 Cadillac Escalade
    Phoenix, AZ
    how many snubs are there...3 maybe?
    2016 Audi A6 Prestige
    Apr 27 2004
    2018 GTS Cab, 2020 AMG A35, 2021 XC40 PLUS parking lift
    Just one snub
    Need a hotel in Ottawa? Try Albert@Bay or Best Western Plus Ottawa Downtown
    PM me for AZ discounts !
    2020 XC 40
    2018 991 Cab GTS
    2020 AMG A35
    Previous rides: B5 A4, B6 A4 Avant, B7 S4 Avant, B7 RS4, TTS, B8 A4, S3, 2019 Targa
    Apr 27 2004
    2020 XC 40
    2018 991 Cab GTS
    2020 AMG A35
    Mar 02 2008
    Cleveland
    Quote Originally Posted by Stevelev View Post
    That's for a B5, right? Is ours the same? I never did find Eddiemans write up in the DIY, is his for the B6?
    Veteran Member Four Rings Eddie Man's Avatar
    Nov 05 2004
    Detroit/Clarkston
    Quote Originally Posted by S4B6Dave View Post
    Here ya go >>> MySnubMountInstall
    Within, you'll find my link to the B6/3.0 SnubMountInstall.
    It's very similar to the 4.2 but the V8 is just that much tighter in working quarters.
    I hope it helps :)
    2006 S4 Avant
    dolphin gray | 6speed | alcantara | premium | cold | bose | sirius | navigation | bluetooth | parktronic | ebony | carbon fiber
    >>> Got Mods?
    Mar 02 2008
    Cleveland
    Thanks Eddie, I'm sure there are many people on here that have used and appreciate you post!
    Mar 02 2008
    Cleveland
    I didn't get mine installed at the dealer, I had it added to the repair order when I dropped off the car, but neither the tech nor the Audi Service writer caught the change. Anyway, they had it pretty much back together before I called and asked them about it, so I could have waited until Monday to pick up the car(except I'll be out of town!), or get it Sat. morning without the snub. Since I was in withdrawal without the car, and didn't know when I could next pick it up, I told them I'd do it some other time. They did quote me 2 hours, and said they'd knock off a half an hour charge for me, so $150 to do it. I might try it myself if I get the time. But I wouldn't mind paying the money if it makes that big of difference?
    May 30 2007
    MA
    Its not bad - I did it yesterday. I didnt take off the bumper as I didnt want to have to deal with the washerhoses and lining that thing up. There was enough play for me to get my hands in there after loosening the bumper brackets.
    2014 R8 V10 - Gated
    Mar 02 2008
    Cleveland
    Quote Originally Posted by SuperAvant View Post
    So, how much time did you take? How much difference does it make?
    May 30 2007
    MA
    To remove the bumper, I dont know if it gives you much more room to work. People were complaining of scraped knuckles who removed the bumper so I am guessing it is still tight. Just get yourself a pry bar and a 2X4 and prop it up there. The thing that took the longest was the top bolt on the snub bracket. It took me approx 4 hours because I couldnt get the Torx bolts on the bumper brackets loose.
    If I were to do it again I could probably do it in under 1.5 hours.
    2014 R8 V10 - Gated
    Mar 28 2007
    B7 S4 MT6
    Bronx, NYC
    Just had the ECS snub installed along with a Corsa CB at Tyrolsport in Queens. The snub seems to have taken alot of the ropey slop out and I feel more positive engagement now. Everything just feels tighter if that makes any sense.
    '06 B7 MT6
    Veteran Member Three Rings Lugi20's Avatar
    Sep 24 2007
    Chicago
    Quote Originally Posted by ZONAWILDCATS4 View Post
    Think they'll honor the same price for me? I live around the corner from you.
    Oct 14 2007
    Mammoth Lakes, Ca
    which snub to get? APR, ECS? Are there any other brands?
    Apr 27 2004
    Quote Originally Posted by channad View Post
    Yup, Stern and Neuspeed. I went with APR because it was most convenient and had one on my B6 A4. No vibration at idle
    2020 XC 40
    2018 991 Cab GTS
    2020 AMG A35
    Oct 14 2007
    Mammoth Lakes, Ca
    Is there a best snub mount? Or do they all do the same thing? Just depends on which flavor you want??
    Apr 27 2004
    I'd suggest you call PureMS and ask what they recommend (they carry both the APR and Stern). I don't know for sure but am willing to bet the ECS one is made by Stern ...
    Lots of B6 A4 guys had vibration with the NS one so I'd rule that one out. Good luck !
    P.S. RS4 H-sports are on the way
    2020 XC 40
    2018 991 Cab GTS
    2020 AMG A35
