Results 1 to 7 of 7
    Veteran Member Three Rings d_maniac's Avatar
    Sep 16 2006
    99.5 A4 1.8T Q, 2004 A4 1.8T
    Bronx, New York
    clutch install question
    i just had my stage 2 awe clutch installed and when i drove the car the rpms would shoot all the way to redline and the MPH wouldnt move with it. Its like the clutch wasnt catching. what could be the problem
    later on i go stuck in traffic and now the clutch seems to be ok....
    should i have the shop check something over, or does the clutch adjust itself?
    Sep 16 2006
    Bronx, New York
    Re: clutch install question
    no replies?
    Established Member Two Rings busakiller's Avatar
    Dec 18 2007
    Pittsburgh,PA
    Quote Originally Posted by d_maniac View Post
    no replies?
    I would call the shop... Just my .02...
    Veteran Member Four Rings A4 TSCHUSS's Avatar
    Apr 24 2005
    E55 AMG, CTS-V
    Jacksonville, Florida
    did you slip the clutch real bad before you noticed that it revved up without moving you at the same rate? If so you may have got the clutch hot and glazed the clutch and caused it to slip until it cooled down and then from driving normal it wore the clutch in again allowing it to grip.
    ~David~
    Gone but not forgotten 437whp on 93 octane and washer fluid injection A4 12.2 best ET, 12.3@119 best overall
    480whp/500wtq E55 AMG 11.6@120
    CTS-V 9.6@148
    Sep 16 2006
    Bronx, New York
    yea i reved it up a few times, but what caused it is my concered, i dont want it to happen again down the line
    Apr 24 2005
    E55 AMG, CTS-V
    you are not supposed to go tear on a new clutch. You are supposed to drive several hundred miles like 500-1000 of normal driving shifting gears to break it in and seat the clutch. If you went out and did a 6000rpm clutch drop than you probably did like I said and glazed the clutch. Just drive as normal as posible for a few hundred miles shifting frequently (dont get on the interstate and put it on cruise for 200 miles then think its broke in). You need to be engaging and disengaging it many many times.
    ~David~
    CTS-V 9.6@148
    Buncha motorcycles
    Memphis, TN
    what he said ^^^
    any clutch needs break in but any high performance clutch needs at least 500 miles of straight city driving with lots of engagement/disengagement or 1000 miles of mixed driving... i put 1000 on my FE SS before even starting to drive it hard and 1500 before i dumped it at 5k
    APR Stage 2/AWE Intake
