Results 1 to 21 of 21
    Active Member Two Rings seannb78's Avatar
    Sep 18 2007
    2013 Audi TT RS, 2013 Mercedes GLK350
    Land O Lakes, FL
    Noise from new brakes and rotors on b7, FWD A4.
    I had my new cross dilled and slotted Zimmerman rotors and PBR ceramic front/ Hawk ceramic rear pads installed last Friday and I have a humming noise coming from my left front wheel area.
    I took it back to the shop that did the install and they reinspected and said everything looks okay and they feel that it is probably extra road noise from the new rotors and pads. I asked if it could be a wheel bearing and they said it was very unlikely. My question now is, what do you all think. I havent taken the car to Audi to have them inspect, but what could this new noise be.
    It is heard the loudest going 60-65 mph and almost completely goes away under 20 mph. Over 65, you cant really hear it. Could it be a warped rotor? Is my pad constantly rubbing on the rotor and if so is there some type of adjustment to back the pad away from the rotor a little?
    Give me some ideas here before I take it to Audi and get the "you didnt have the work done here" lecture.
    Also, it should be mentioned that all of this was ordered from ECS, and I did have some issues with the order being changed multiple times due to availability, but the did ship for free due to these issues.
    Registered User Four Rings Mike@PureMS's Avatar
    Jul 19 2007
    San Diego, CA
    Re: Noise from new brakes and rotors on b7, FWD A4.
    Humming is common when braking with x-drilled rotors. Doesn't sound like anything to be concerned with.
    Sep 18 2007
    Land O Lakes, FL
    The humming happens when I am driving though, not when I am braking.
    Established Member Two Rings baungS4's Avatar
    Jul 05 2007
    Queens,NY
    I have the similar issue with new setup - dimpled and slotted rotors with porterfield pads.
    When i go above 45 I hear the noise and when i brake from 60/65 to 30.. Everything looks go so far but I cant figure out what the noise could be.
    Veteran Member Four Rings jeremy@matrix's Avatar
    May 27 2004
    B8.5 S4, B8 S4, B7 A4A, B6 A4, B5 A4, Q7, 958TT, 955TTS, 997C2S, 996TT...
    Portland, OR
    Quote Originally Posted by seannb78 View Post
    Does the humming change depending on what speed you're going?
    PS--Those most likely are Zimmerman drilled rotors that they had slotted as well.
    Jeremy Williams
    Matrix Integrated Inc.
    www.matrixintegrated.cc
    Jul 05 2007
    Queens,NY
    yes. below 20, i barely hear it but once i go above 40, its noticable. also when i am braking from above 45 down to 20ish, i can hear it
    May 27 2004
    Portland, OR
    Quote Originally Posted by baungS4 View Post
    Ok, but does the humming increase as speed increases?
    Jeremy Williams
    Jul 05 2007
    Queens,NY
    No. The noise is pretty much the same noise frmo 45 and on. Its more like scratching/hissing than humming actually.
    Its also noticable when I apply brakes and it goes away if i am under 20mph
    I have porterfield r4 pads with slotted/dimpled rotors from Adam@SPP. Not sure if I need to bed the breaks in more.
    May 27 2004
    Portland, OR
    You have Porterfield R4 pads? That's a race pad, no wonder they're making noise!!
    "The Porterfield R-4 Carbon Kevlar pads have a unique, integrally molded ceramic heat shield designed specifically to minimize heat transfer in high temperature applications keeping caliper temperature at proper levels. These state-of-the-art materials offer tremendously high friction levels while at the same time extending rotor life."
    Jeremy Williams
    Jul 05 2007
    Queens,NY
    but its only coming from the front wheels. Is there anything to reduce the noise?
    May 27 2004
    Portland, OR
    It's because you're running race pads. Race pads don't = quiet.
    Why did SPP sell you race pads (I assume your car is a daily driver)?
    Jeremy Williams
    Jul 05 2007
    Queens,NY
    Ic. I guess i either get new pads or live with it.
    Its just strange to me that I hear it even when I am not applying brakes and its only coming from the front wheels.
    Not sure why they sold me race pads but I didnt think it would make this much noise.
    thx
    May 27 2004
    Portland, OR
    thx
    If your car is a daily driver you should not be running race pads on the street. They'll take longer to warm up (so cold braking won't be great). Once they're warm I bet they stop like no one's business though.
    Remember that race pads are much more abrasive than street pads, hence noise all the time.
    I'd contact them and ask what happened. I bet you were supposed to get R4S's(street pads) and you got R4's(race) by mistake.
    Jeremy Williams
    Jul 05 2007
    Queens,NY
    Came home and checked. I have R4-S. Thats what the box said. SO is R4-S suppose to make this much noise on slotted n dimpled rotors?
    What else could be the problem here? Not enough bedding?
    thanks
    May 27 2004
    Portland, OR
    thanks
    Ok, R4S are the fast street pads--that's good news.
    You can certainly try bedding the brakes again.
    Jeremy Williams
    Veteran Member Three Rings jayuuey's Avatar
    Aug 22 2007
    SF Bay Area
    isn't it normal to get humming like noises with cross drilled and/or slotted rotors?
    Jay
    Current: Ibis White A4 Avant S-line TI 2.0T MT6 (JHM STS, Unitronic Stage1)
    Sold and quickly forgotten: 09 Forester XT Limited
    Sold and will be missed: A4 2.0T Quattro, 6-speed manual, APR Stage 2+
    (old) norcal audizine GTGs, etc. http://www.flickr.com/photos/jayuuey/sets/
    May 27 2004
    Portland, OR
    Quote Originally Posted by jayuuey View Post
    Usually a whirring noise when stopping.
    Jeremy Williams
    Aug 22 2007
    SF Bay Area
    i am also hearing a slight whirring while driving. i am running hawk hps pad with slotted/dimpled rotors. i will be taking my car back to the shop today.
    Jay
    Aug 22 2007
    SF Bay Area
    i went back to the shop today and my mechanic mentioned that you may hear some noise from the slots/dimples in the rotors while driving. he also mentioned that it might go away or quiet down after the initial pad material is rubbed off the rotors. anyone else experience this?
    Jay
    Jul 05 2007
    Queens,NY
    I am also having this issue. I re-bedded my brakes the other day and i think the noise has gone down alittle but i can still hear it.
    I am going to try to bed it again this wkend with a couple of runs from 80mph->40mph and then a couple of 45->20/10..
    Aug 22 2007
    SF Bay Area
    any updates on your noises? im thinking about redoing the brakes again because its still making the whirring noises after 300+miles.
    Jay
