Results 1 to 28 of 28
    Veteran Member Three Rings Alan's Avatar
    Jan 22 2007
    1998 2.8QM 1988 Corvette
    Pittsburgh, PA
    Turning down boost
    With increasing gas prices and 21 lbs on my K04, I've decided that I want to turn down my boost. I dont really drive fast anymore, and I dont want to put the constant strain on my turbo when passing, or going up hills.
    I'm APR tuned, so can the chip be detuned to say 12 psi? Or what are my options to turn down boost a bit. I don't want to be at the stock 8lbs, it's just too slow.
    Established Member Two Rings blkb6a4's Avatar
    Feb 24 2008
    2001 audi a4 1.8t quattro
    Minnesota
    Re: Turning down boost
    you should be able to use a MBC or EBC or even swap out your wastegate/wastegate spring, but I would do MBC or EBC becuase then if you ever do decide to have some fun at an auto-x or dragstrip you can very easily just turn it right back up to 21psi
    Veteran Member Four Rings VTAudiA4's Avatar
    Oct 20 2007
    if you want a mbc, i have one for sale. pm me for more details
    Dec 14 2006
    Halifax, NS, Canada
    apr k04?
    2001.5 1.8T Manual Quattro Celebration | Startup Racing Vogtland Coilovers | Giac X Chip | SPP A pillar with VDO Gauge | Boxster/A8 Front brakes S4 rears | Neuspeed Catback VMR Testpipe |
    NOW DEAD :(
    Registered Member Three Rings Rhinop21's Avatar
    Mar 04 2008
    West linn, Oregon
    sell me your setup and ill give you my stock turbo and ecu?
    http://i200.photobucket.com/albums/a.../dopeaudi3.jpg
    1998 A4 sold
    1995 Talon tsi awd. 6 bolt swap.
    Jan 22 2007
    Pittsburgh, PA
    I have a K04, with APR K03 tuning. I dont want to sell my setup, but I just want to turn down boost. 21 psi isn't helping my transmission situation at all, or my gas mileage.
    Veteran Member Four Rings audiness's Avatar
    Jan 26 2007
    Charleston SC
    if you have a GIAC chip, just get the flashloader, and put your car back to stock.
    I do it to mine all the time.
    Dec 05 2007
    CA LA
    uummm iwe al have MBC bult into our cars. the more you push the gas pedal the higher you boost. so dont push it so hard and your get a nice 30MPG
    Veteran Member Four Rings Tiluleshpingen's Avatar
    Nov 14 2006
    97 AS4 ,08 A5 MKVI Jetta
    Land of the Eagles
    Quote Originally Posted by legionvr6 View Post
    tried it dont work !!!!!!!!!!
    GIAC-X, STASIS TS,VAST,034 MS
    Senior Member Three Rings Solaris's Avatar
    Feb 01 2006
    NC
    I don't know if a MBC would really be a help. I'm using a Boost Machine inline with my N75 to raise peak boost and it has made the turbo spool up sooner on lighter loads. The PC16 would naturally stay in vacuum until a considerable load was put on the engine. Pulling out into traffic and trying to stay out of boost can be difficult sometimes now. I agree with legionvr6's suggestion, just be smarter with the throttle. Watch the boost gauge and stay in vacuum as much as possible.
    Veteran Member Four Rings sean1.8t's Avatar
    Sep 17 2006
    I wish I had a garage.
    SLC, UT
    im not entirely sure if the APR chip is non N75 friendly. but if it is,
    step one: remove n75
    step two: install MBC..
    Current:
    '16 Mercedes-Benz C450 "AMG": Stage 2 w/downpipes & 19" BBS CH-R's
    '88 Harley-Davidson Sporty 880: 1200 bottom - Ported & Cam'd top - S&S In - Screamin' Eagle Out
    Previous:
    '02 Audi A4 1.8TQM: Full GT28RS on meth w/everything else.
    '01.5 Audi A4 1.8TQMS: Tune and exhaust.
    '99 Subaru Legacy Outback wagon Manual: Bone stock.
    I don't even want to remember the others
    Veteran Member Four Rings UN-PIMP-Z-A4's Avatar
    Jan 29 2007
    MR VTEC Lives...
    Yes We Can!!! Obama N Beyond!
    I have a stage 3 and i hardly boost unless im trying to catch a light or im on the highway...
    I get good gas mileage...
    I would never want my boost turned down!!!
    NEVER!!!
    Homebrew PES Powered Stage 3 A4 1.8TQM It can be yours for only $5k PM for details
    I have a JUSTINTERCOOLER 27 X 6 X 2.75 WITH 2.5" inlet / outlet (Brand New in Box) FMIC for Sale $90
    QUOTE OF THE YEAR:
    "Another thing, dont go flashing 15 second timeslips!"
    Jan 22 2007
    Pittsburgh, PA
    I have APR. You CANT accelerate at a reasonable speed without boost. With my mom in the car, she will hit at least 8-10 to get it moving. I tried to keep it out of boost once going up the highway, and I had to do 40. Especially because the area aroudn me is hilly, it's hard to stay off the throttle.
    I need a way to physically limit the boost.
    Feb 01 2006
    NC
    Quote Originally Posted by Alan View Post
    What RPM do you usually shift at?
    Jan 22 2007
    Pittsburgh, PA
    It's an automatic. And it likes to rev high.
    Jan 29 2007
    MR VTEC Lives...
    damn rev happy slushboxes
    QUOTE OF THE YEAR:
    Dec 14 2006
    Halifax, NS, Canada
    if its apr couldnt u put it in stock mode?
    NOW DEAD :(
    Nov 19 2005
    WA
    Just like an MBC can be used to raise boost levels, it can also be used to cap boost levels.
    Unfortunately, I forget how you need to install it to work as a cap. I'm sure someone around here though will be able to help you on that.
    2017 Platinum Gray Metallic Golf Alltrack SEL
    Mar 09 2004
    99.5 A4 Avant, 01 allroad
    nw michigan.
    I see no reason for any of this. I understand your situation but all you need is better throttle control. I accelerate around town at 0-5 psi all the time. I can hold it at 10 or 15 psi easily as well. Boost is a response to demand and you have control over it. You will probably be in positive boost up hills but you should also be in vacuum going down the other side. There isn't much that can be done about your terrain. The only place a MBC or other control will actually lower your boost is on cruise control. That is because that is the only place your right foot isn't in charge.
    When I pull away from a stop at 0 psi I'm even with most other traffic. Average mpg in town is never lower than 23 psi and sometimes as high as 28. Highways (55 mph) are usually 30-40mpg and freeways (75 mph) are 25-27 mpg.
    Jim
    I Do Werk.
    Jan 29 2007
    MR VTEC Lives...
    ihave a stage three and i hardly ever go over 5lbs
    QUOTE OF THE YEAR:
    Veteran Member Three Rings jm121189's Avatar
    Jun 05 2007
    Portland, ME
    Quote Originally Posted by UN-PIMP-Z-A4 View Post
    Thats not surprising assuming you don't drive around smashing on the gas since your turbo probably starts to boost when you shift.
    Couldn't you just get the stock program and shift between the two depending on your mood?
    2000 1.8t A4 qtm gone but not forgotten
    2008 R32
    2015 S4
    Jan 22 2007
    Pittsburgh, PA
    Quote Originally Posted by onemoremile View Post
    You dont understand. I set my cruise control at 65 on the turnpike, and 60 on the highway. I ease into boost, and still am averaging 18-19 mpg. To accelerate with traffic, I need at least 5 psi. I dont have control over it if I need ~5 psi to accelerate. It's an automatic, I can't control the revs very well, and it builds boost almost off of Idle. On cruise control, I use ~3psi to get up the highway.
    I have new plugs, coilpacks, fuel filter. My mileage shouldn't be this bad.
    Mar 09 2004
    nw michigan.
    No, I understand perfectly. My car accelerates the same way but 99% of cruising is done in vacuum. The poor mileage is likely due to an inefficiency elsewhere. Alignment is usually the culprit. Also check the air filter and maybe even change the lubricants in the transmission and diffs. Those can make a surprisingly large difference.
    Jim
    I Do Werk.
    Jan 22 2007
    Pittsburgh, PA
    Ok, Ill check everything. I appreciate the help. It does pull to the right a bit, but Im getting my summer wheels on today, so it'll be realigned.
    Veteran Member Two Rings 0000_a4's Avatar
    Aug 03 2004
    Chi-Town
    +1 on this. You will see a big difference on your gas milage. Also check your tire pressure every week.
    K04|Custom FMIC|310cc Injector|GIAC PC-16|APR Inlet Hose|2.5" Scorpion Exhaust Turboback|EVO MS DV|South Bend Stg II Clutch|Unorthodox LFW|18" BBS CH|RS4 Look Front|S4 Rear and Side skirts|Koni Coilovers|A.W.E. Drive Train Stabilizer| 6000k 50w HIDs|Valeo 1 piece Headlights| Stratosphere SS
    Jun 05 2007
    Portland, ME
    How long since your last oil change? I just changed mine and it was in there for about 5k miles(yes i know a little too long) and my fuel economy has improved since the change.
    2008 R32
    2015 S4
    Jan 22 2007
    Pittsburgh, PA
    I am pretty fanatical about maintinence. Ill be getting an alignment, and Ill change the oil this weekend. Ill get another air filter and try that as well. Everything else I can think of is new.
    Senior Member Three Rings Mad_Audi's Avatar
    Mar 06 2006
    97 Amulet Red Audi A4 1.8T
    Greenville, NC
    Could Alan run the stock mode option on this APR chip?
    FlipSwitch
    Enables you to swap between two or more engine programs on-the-fly using the cruise control stalk. All cars have stock and standard chipped program versions available. Valet, race-gas, and other specialty programs are available for some models.
