Results 1 to 9 of 9
    Registered Member One Ring kaotik411's Avatar
    Dec 21 2007
    01.5 A4 Qtip Brilliant Black
    SOCAL
    Loud clunk when decleration?
    It seems like the only time I need to Post anything is when Im having a problem.
    I did a few searches on this and only found threads related to manual transmissions.
    I have a 01 1.8Qtip with 113,000. (Stock)
    I have recently been hearing and feeling a loud thunking noise when I take my foot off the gas. Almost feels sounds like Im hitting a pot hole. It usually happens when the car is decelerating. It dosent happen all the time but just started happening. For instance this morning i was getting on the entrance ramp to highway i hit the gas and was up to about 65 and then let off the gas. about 2 sec later THUNK. The transmition is just left in the auto position Im not playing with it. It never happens when the car is speeding up. It also never (hasnt yet) happend at slow speeds. Seems to only happen when Im around 40-70mph.
    Also no codes have been thrown so I dont think its the speed sensor.
    Any ideas would be greatly appreciated.
    Veteran Member Four Rings zrowcool's Avatar
    Nov 09 2006
    2000 B5 A4 Quattro / 00 F-150 XLT S/C
    Bronx, NY
    Re: Loud clunk when decleration?
    check your engine or tranny mounts and also your snub mount which is in the front. sounds like a mount issue to me.
    2000 A4 1.8tq
    Running only on Amsoil fluids.
    Amsoil products at wholesale pricing... Ask me how!
    Jan 26 2007
    Bingo, NY
    if you go slow and hit the brakes hard do you hear it?
    Dec 14 2006
    Halifax, NS, Canada
    inner CV joint
    2001.5 1.8T Manual Quattro Celebration | Startup Racing Vogtland Coilovers | Giac X Chip | SPP A pillar with VDO Gauge | Boxster/A8 Front brakes S4 rears | Neuspeed Catback VMR Testpipe |
    NOW DEAD :(
    Active Member Four Rings bassed's Avatar
    Sep 24 2005
    always in design
    Under Decel. causing the thud, would make me look at Diff Mounts and tranny mounts. WIth that many miles the majority of the mounts and bushings are shot 100%.
    Dec 21 2007
    SOCAL
    I will check the Mounts tonight when i get out of work. What exactly am i looking for?
    I'm glad to hear that its probally not the tranny!
    Dec 21 2007
    SOCAL
    Quote Originally Posted by JoBuNY View Post
    Not really, But I'll play with it more tonight to see.
    Oct 26 2007
    '99 A4 Avant 1.8tqm / '04 S60R
    Nashua, New Hampshire
    Quote Originally Posted by kaotik411 View Post
    Loose bolts mostly. If you have anything that will work as a pry bar, see if you can get the mount or engine/tranny to move while attached to the mount. Do the same with any bushings, see if they are ripped on the inside (you'll know when you see it)
    Please take the effort to make me feel unworthy!
    Dec 21 2007
    SOCAL
    So last night after driving home I started braking hard to see if it would cause the noise. No dice. It only happens sometimes after gunning the gas some where around 40 or above mph and then taking my foot completly off. Then as gears back down, CLUNK.
    But well doing this I noticed my Speedo is SLOW. I never realized I how much I dont pay attention to that, but as the car increases in speed it takes a while for the needle to tell me what speed Im at. And it does the reverse when slowing down. If I slam on the brakes it takes a few seconds for the needle to fall. And to top it off the check engine light popped on. SO as soon as I get time to run the codes I'm going to guess that its the speedo sensor? I'll check the codes this weekend along with the mounts.
