Results 1 to 20 of 20
    Veteran Member Four Rings gotboost's Avatar
    Nov 04 2007
    Minnesota
    B5S4 Front Brake Upgrade Question
    Just wondering if all i need is...
    -B5S4 Rotors
    -Calipers
    -Brake pads
    Or is there anything else i need. thanks
    Current:
    2002 A4 Avant - Eibach Pro Dampers | Rev Motoring Springs | 034 Motor Mounts | 710N DV | Apikol Snub Mount | 18" S4 Peeler's
    2001 Imola S4 Satge 2+
    2003 A4 GT2871r 303 AWHP 291 AWTQ
    Veteran Member Four Rings Condo's Avatar
    Jan 30 2007
    2001 S4 Avant
    Cincinnati, OH
    Re: B5S4 Front Brake Upgrade Question
    You'll need to pick up some brake fluid too.
    Nov 04 2007
    Minnesota
    So brake fluid and thats it, what about my stock brake lines? Will those work?
    Current:
    Jan 30 2007
    2001 S4 Avant
    Cincinnati, OH
    Stock brake lines will work just fine but I upgraded mine since I was already doing the work.
    Nov 04 2007
    Minnesota
    And i can use my stock calliper carrier too right?
    and condo, did it make a big differance in stopping power after the upgrade
    Current:
    Jan 30 2007
    2001 S4 Avant
    Cincinnati, OH
    The carrier is built into the B5S4 calipers. The brakes felt a lot better after the upgrade and a lot less fade.
    Nov 04 2007
    Minnesota
    Thanks, what kind of break pads do u recomend?
    Current:
    Veteran Member Four Rings JBM's Avatar
    NorFOLK, VA
    I would get the SS lines and I run the Mintex pads. I have to say that the brakes have truly saved my life sometimes. If I had my stockers I would have been dead.
    "Give a Man a Fish, Feed Him For a Day. Teach a Man to Fish, Feed Him For a Lifetime"
    '02 B6 1.8T, UnitedMotorsport Tuned FrankTurbo L21, 550CC, 3" MAF, BB Intercooler, 007, 034 HFC, Neuspeed Exhaust, B5 S4 Brakes, KW Suspension, S4 Recaro, and the list goes on.
    Jan 30 2007
    2001 S4 Avant
    Cincinnati, OH
    Quote Originally Posted by gotboost View Post
    I've been running Hawk HPS pads for over a year now. Great bite and low dust.
    Nov 04 2007
    Minnesota
    are u runing those in the front only or both front and back..... those are the pads i used to run in my RSX...
    Current:
    Jan 30 2007
    2001 S4 Avant
    Cincinnati, OH
    Front and back. I like to keep my wheels clean.
    Veteran Member Three Rings scorneil's Avatar
    Oct 27 2007
    Oakville, ON, Canada
    does anyone know if B5S4's fit under stock 16's
    2010 B8 S4 Quartz Gray S-tronic Black Alcantara MMI
    2003 B6 A4 Canvas Beige 1.8T Tiptronic 1+ SOLD
    Nov 04 2007
    Minnesota
    and also will they fit under my rs4 reps, 19x8 with a 42 offset
    Current:
    NorFOLK, VA
    they fit under 17" 5 star stockers
    Dec 03 2005
    2 pedals 1FG
    connecticut
    I have the stock rubber lines and Mintex pads at all four corners. Stock rear brakes and B5 S4 front brakes. For daily driving with some spirited runs and heavy braking it works perfectly fine for me. Much better improvement over stock.
    -Doug
    Oct 16 2006
    Naperville
    why not get the b6 s4 brakes I got for sale.??
    Veteran Member Four Rings B6driver's Avatar
    Sep 14 2006
    XBOX LIVE GAMER TAG: b6driver
    Eagle Rock, LA, Ca
    Quote Originally Posted by manguyen View Post
    cuz they are 3x the price... i got my b5s4 brakes for $220 (rotors, new pads, calipers + ss lines and some fluid too! lol)
    2004 A4 1.8 Turbo 5 speed gone...
    2010 Candy White VW CC R-Line
    Nov 04 2007
    Minnesota
    so will they fit behind my rs4 wheels??
    Current:
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Which RS4s? B5 replicas or B7 replicas?
    They fit behind my VMR B7 RS4 replicas with plenty of room.
    -Doug
    Nov 04 2007
    Minnesota
    They are B7 repps from lakeshore wheel and tire, size is 19x8 et42
    Current:
