Results 1 to 10 of 10
    Registered Member Two Rings Amish's Avatar
    Mar 01 2007
    Tacompton, Wa
    Upgrading turbos, need some advice....
    So, The turbos are about done and I am looking to upgrade to k04's. Car is currently Revo'd and all maint. has been done. I'm not trying to spend 7k on upgrades at once as this is one of 3 modded cars I own. I was thinking of picking up a set of k04's and inlets, maybe the bigger maf and FPR as Matrix told me was needed. I haven't heard back yet as to how well it will run off the revo program. My question is, does this route sound correct and is there anything else that should be done at the same time as far as the turbo setup? I've been told that this would be considered a stage 3- and should run off GIAC which "should make around 400hp" ANy help and advice would be great guys. Thanks- Mike
    2000 2.7t A6 6spd.
    Active Member Four Rings ///M3 TO S4's Avatar
    Feb 09 2007
    Charlotte, NC
    Re: Upgrading turbos, need some advice....
    Quote Originally Posted by Amish View Post
    please search, this topic is beyond beaten to death.....
    Learn MANTH America!
    Stage 3....blah...blah...blah... : Sold
    Now: E36 M3 TURBO (GT35R)
    Veteran Member Three Rings audiwop's Avatar
    Dec 11 2006
    2007 Audi RS4, 2010 Ford SVT Raptor, Toyota Tundra, VW Treg,Ducati Hypermotard 1100S
    Orange County,CA
    If that is the route you want to go then you will need a 5bar FPR, GIAC stage 3- file, or VAST stage 3- file. If your car is a 2000 then you will want to upgrade to the hitachi MAF. VAST can get you all setup with that. Good luck.
    Veteran Member Four Rings S4 in_lowplaces's Avatar
    Feb 09 2006
    2021 SQ8, 2000 AWE stg 3 s4, 2012 CTSV 730Whp, Sold: 2000 Stg2 S4 revo,Totaled: 2000 Stg1 S4 APR
    Huntington Beach
    your post is a bit confusing. Are you going to be using the same revo software you where using on your k03's, or are you going to be upgrading it to stage3 or 3-? if your sticking with the same software you where running on k03's then you do dont want a bigger maf, and fpr. wait till you go full stage or 3-.
    2021 Ocra blk SQ8 - Daily
    2011 CTSV coupe 730 WHP - Garaged
    2000 Silver B5 S4 AWE stg 3 - Garaged
    2002 Silver b5 s4 stage 2 revo - Totaled
    2001.5 silver apt stg 2 b5 s4. - Sold
    Veteran Member Four Rings jeremy@matrix's Avatar
    May 27 2004
    B8.5 S4, B8 S4, B7 A4A, B6 A4, B5 A4, Q7, 958TT, 955TTS, 997C2S, 996TT...
    Portland, OR
    Two options;
    Stg3- w/ K04's, inlets, hardware, 5bar FPR, Hitachi MAF, GIAC stg3- software
    ~400bhp
    Stg3 w/ AWE RSK04 kit(everything you pretty much need minus a few extra pieces of hardware we supply or (K04's, inlets, hardware, Hitachi MAF, stock 4bar FPR and AWE fueling kit w/ big MAF sensor, AWE/GIAC RSK04 software, etc)
    ~450bhp
    Larger MAF housing is ONLY used w/ stg3, not stg3-.
    Jeremy Williams
    Matrix Integrated Inc.
    www.matrixintegrated.cc
    Account Terminated Four Rings
    Nov 30 2006
    01.5 pearl white S4 6speed
    annapolis, maryland
    GT GT GT GT GT GT GT GT GT GT GT GT , their is a setup for you.. their always is.. theirs one for EVERYONE!!!
    lol no but in all honesty.. PM and ill give you some ideas other then telling you to stfa, which i would typically do
    Registered Member Three Rings updaboost's Avatar
    Mar 08 2006
    S4, 997 4S & S2000
    Chicago
    I ran my K04s on REVO for 9 months but it was lemmiwinked. Was good for 300whp. Just make sure to get a MBC and set it at 17psi to be safe. Anything higher may cause you to lean out. Without MBC you may get nasty boost spikes... Curious did your KO3s blow? Mine did, I believe, from REVO's shitty software.. And yes you want a 5 bar FPR... If you dont have GIAC I dont think its worth paying for the Stage 3- software unless you plan on later going with AWE fueling..
    01.5 Nogaro Blue S4, 6sp
    VAST Stage 3 - Piggies - Neuspeed - RS4 Clutch - Samco - Hyperboost DVs - AMS TBB - Stratmosphere SS - Flik Justice/SSR Comps - Vogtland - AWE DTS - H-Sport Sway
    360whp/400wtq
    Veteran Member Four Rings GURUMAN's Avatar
    Mar 13 2007
    2.9L PTE 6766 1000 Bhp single Monster !
    Montreal
    k04/rs6, same turbos that are on the space shuttle !
    Jul 17 2004
    Quote Originally Posted by GURUMAN View Post
    lolol
    Alex
    2001.5 Nogaro Blue S4, 6-Speed, ARD 2.7T 68mm HTA GT2868 Kit
    May 27 2004
    Portland, OR
    Quote Originally Posted by updaboost View Post
    No need for an MBC with GIAC stg3-.
    AWE/GIAC; same software used by the Tazmanian Devil.
    Jeremy Williams
