Results 1 to 10 of 10
    Senior Member Three Rings 11move's Avatar
    Nov 25 2007
    Constant Power in engine bay????
    Hey there I am looking for a wire that I can tap into that has constant power with ignition on and once ignition is off there would be no power. I need this source to be in the engine bay, I thought I had the wiring diagram for the B5 but I dont and can not find this info, I was thinking into taping into the ignition coil but that would be my last choice any other ideas?
    Mar 09 2004
    99.5 A4 Avant, 01 allroad
    nw michigan.
    Re: Constant Power in engine bay????
    What are you wiring in? Does it draw a lot of current? You could run a wire through the ECU firewall opening to the 75x tap.
    Jim
    I Do Werk.
    Nov 25 2007
    The fog lights, as I have to install a relay control and need power to run the module for the DRL's
    Sep 11 2007
    Dirty Jersey
    um, how about the battery?
    Nine [O_O] Eight Tuning
    custom work, fabrication, bumper shaving, fender rolling, plastic & fiberglass fabrication and repair
    Turbo charged and lowered for better grocery getting :screwy:
    Account Terminated Four Rings
    Oct 28 2006
    GT30r'd A4 on Meth, 01 Durango
    Quote Originally Posted by Vreihenmotor6 View Post
    the battery always has constant power and doesnt turn off with the car so it cant be used to run fogs
    Nov 25 2007
    Yeah I would run the power source dry then :D thanks
    Nov 25 2007
    Bump
    anyone???? Does anyone have the B5 wiring diagrams?
    Established Member Two Rings oneighty's Avatar
    Aug 30 2007
    just get a meter and put it on 12VDC and poke around, im sure youll find something.
    -Jonathan
    '00 A4 1.8T K&N | InMotion Tuning | Forge004 | AutoMeter boost gauge | Eibach ProKit | ST sports | Avus S4 | 6000K HIDs
    Mar 09 2004
    nw michigan.
    Run a wire through the ECU firewall opening to the 75x tap and use it to trigger your relay.
    FWIW, this is how I ran power to my headlight motors.
    Jim
    I Do Werk.
    Veteran Member Four Rings Mawhitey's Avatar
    Jan 20 2005
    99 AJL TQS
    UK
    wire the relay up inside the car and then just run the wires to the fogs/ DRL, easy to place the realy out of the weather and connect to the x75 and or x30 pins,dependant what you need
    -Mark -
    .2008cc Stroker, K04064, ME7.5, Miltek, and other goodies
    My k04064 , ME3 DBC to ME7.5 DBW build thread
