Results 1 to 4 of 4
    Senior Member Three Rings zbrock06's Avatar
    Oct 15 2006
    '04 USP A4 1.8TQ
    Stamford, CT
    B7 Wheel into B6 question
    i am looking at installing a B7 wheel and i won't use the Multi-function because i won't have RNS-E so do i still need the control module and SC ring? Can i just install it and splice the airbag wires and wire it up for one stage deployment? Can i just do direct swap with airbag harness and 4-pin connector?
    Control Module - 8E0-953-549-R www.autopartsnationwide.com $209.49
    S/C Ring - 4E0-953-541-B www.autopartsnationswide.com $323.21
    4 Pin Connector - 4E0-972-133 www.autopartsnationswide.com $4.58
    Airbag Wiring Harness - 4F0 971 589 A (Only required if not supplied with airbag) - www.autopartsnationswide.com $36.46
    these are the parts that are listed as needed for the swap when using the multi-function with an RNS-E. Also, if i'm not using the RNS-E i don't need VAG correct?
    just making sure because if i still need the SC ring and control module it's not worth it because i won't be using an RNS-E, i'm going to go with the AVIC-D3.
    if it does work then i will have a B6 USP wheel w/ airbag for sale.
    USP CLUB MEMBER #94
    Veteran Member Four Rings GTMRS4's Avatar
    Sep 14 2006
    New York, NY
    Re: B7 Wheel into B6 question
    I did it with the RS4
    BetaAlphaTau # 18
    2007 Q7 4.2 Premium
    2007 997 Midnight Blue
    2005 Lotus Elise Magnetic Blue
    2004 B6 APR STGIII+ (SOLD but not forgotten)
    Oct 15 2006
    '04 USP A4 1.8TQ
    Stamford, CT
    you did what, just the steering wheel & airbag and no SC ring or control module?
    USP CLUB MEMBER #94
    Oct 15 2006
    '04 USP A4 1.8TQ
    Stamford, CT
    anyone??
    USP CLUB MEMBER #94
