Results 1 to 22 of 22
    Veteran Member Three Rings in2thenightaudi's Avatar
    Apr 03 2008
    '03 A6 2.7T 6MT
    San Diego, CA
    Tiptronic question
    Is there any way to cancel the automatic shifting from 1st to 2nd when shifting "manually" or at least delay it? No matter how hard I stomp on it, it always shifts out of first around 2k rpm.
    Veteran Member Four Rings oc-drop's Avatar
    Nov 20 2005
    B7 A4, C5 A6, 79 Camaro
    Newport to Rancho Sta Marg
    Re: Tiptronic question
    it's a software mod you can program via vag-com ~ requires updating the code to enable sport mode
    but i don't know more about it since it's not an issue for me =)
    ~search is your friend
    ~Rick .. currently driving a B7 3.2 S-Line 6MT Dolphin Grey | DTMish | EuroGEAR CF Hood | H&R | sick halogen Ecodes | AZ Plate frame
    is it 4:20 yet?
    Senior Member Three Rings skiroad'r's Avatar
    Apr 21 2008
    2002 allroad Tip, 2005 Mazda 6 Wagon 5MT
    Central New Jersey
    That does not sound correct. A few questions:
    Are you driving in "D" or "S" or Tip mode?
    what year and model car is this?
    If I drive in "S"port mode, and accelerate hard, it holds first to the redline
    If I drive in TIP mode it holds first to the redline
    If I drive in "D"rive mode it won't hold to redline, not sure where it shifts because I never drive in D.
    '02 allroad 2.7T Tip
    ASP Flash, 034 Snub Mount (DIY), VAST EFK (DIY), H-SPORTS (Hard)
    Anrott Gen II Front Airsprings (DIY), Magnaflow mufflers with 3.5" tips
    Summers: Yokohama Avid W4S/RS6 Reps
    Fog DRL's, Toggable 628 Relay, Tip Override Recode, Remote Window Recode, Clear Corners (DIY)
    Timing Belt DIY (at 60K miles), Tiptronic Drain & Refill Service DIY (at 62K miles)
    GET OEM PARTS HERE: http://www.europaparts.com/
    Veteran Member Four Rings Gigi's Avatar
    Jan 23 2006
    2004 Audi A6 2.7T, 1999 Jeep W
    Charlotte, NC
    he said "shifting manually" so in TIP.
    It is defintely feasible and only takes 5 minutes with a VAG CMO or VAg Tool.
    Change your stock code from 01002 or 00002 to 32 at the end.
    It'll have the sport shifting and also hold 1st gear to red line.
    Have a great day, Brice
    99 Jeep TJ, 4" lift, Mikey Thompson rims & tires
    http://i157.photobucket.com/albums/t...i/photo-22.jpg
    http://i157.photobucket.com/albums/t...20TJ/Jeep2.jpg
    SOLD: 04 Blue [B]A6 2.7TStage 2 +: Many mods
    Apr 21 2008
    Central New Jersey
    In tip mode my only shifts at redline -- it did this even before I recoded the transmission. So, something still doesn't sound right to me.
    Jan 23 2006
    Charlotte, NC
    then get a tip chip ;)
    Apr 21 2008
    Central New Jersey
    Trust me -- it's on the list along with ECU flash.
    That one's been sitting on the list for a long time.
    Apr 03 2008
    '03 A6 2.7T 6MT
    San Diego, CA
    thanks for the info guys. i'm fairly new to moding audi's so dont know much about the vag com software. i had looked into the tip chip but wasnt sure i wanted to spend the 5-600 right now. i'll have to look into the vag com, what price range are you looking at there?
    Apr 03 2008
    '03 A6 2.7T 6MT
    San Diego, CA
    also, anyone else have issues searching the forums? when i try to do a regular search or an advanced search, no matter how many words i use in the search it gives me a message saying i need tosearch with atleast 3 words.
    Apr 21 2008
    Central New Jersey
    to buy your own VAG is expensive, a few hundred from Ross Tech. However a $20 to a friend w/ VAG or other compensation should get the recode done for you. Do that first.
    If you plan to mod you car, defintiely get your own VAG.
    Jan 23 2006
    Charlotte, NC
    Yeah find smoeone local to you with a VAG and have them do it. It'll take them 5 minutes and most guys are willing to do that. That's what I did, I posted a thread on the fourm asking for help locally. Gyus did it for free, I brought him a 12 pack!
    I just bought a VAG TOOL for a GB (Audizine GB section) for $200 shipped I am psyched! can't wait to get it!
    Jan 23 2006
    Charlotte, NC
    Quote Originally Posted by in2thenightaudi View Post
    Get the VAST tip chip, it is only $350 and much betetr than the GIAC one. Makes the most of the power, feels like yuo're putting more power down like on a manual. WORTH the $350!
    Jan 23 2006
    Charlotte, NC
    Quote Originally Posted by skiroad'r View Post
    No it IS right unfortunately,it is just the way the US Audis are set up. That's why that Vag Com mode is so popular.
    Nothing wrong wiht the tranny. 32 code will fix that
    Feb 01 2008
    Missouri
    Ok I recoded to 00022 and love it, but to me 32 just sounded too much like it is when its 00002 what is the 32 mode like? Does it auto upshift at like 4,000 rpm and redline when your on it. I like the 22, but often times it does get old, but if you let off after accelerating it upshifts for you.
    I recomend doing this I love droping it to 1st around a bend and banging it on the way out. It was wet today and I even got a little wheel spin!
    Mar 29 2007
    columbus, OH
    is vast available fot tip and ecu on a 4.2?
    Jan 23 2006
    Charlotte, NC
    yeah they do both
    Nov 20 2005
    non-dbw FTW
    is it 4:20 yet?
    Apr 21 2008
    Central New Jersey
    Quote Originally Posted by Gigi View Post
    Not the first time my memory fails me, my bad.
    Senior Member Two Rings votblindub's Avatar
    Feb 21 2007
    ballston lake, ny
    i was wondering about the same thing. i was able to force mine to hold it in first by holding the shifter down at the minus. ill ask around my area about a vag com. thanks guys.
    Jan 23 2006
    Charlotte, NC
    it is an awesome free 5 minute mod;)
    Registered Member Three Rings projectdarka4's Avatar
    Jun 08 2007
    2000 a6 2.7t tip
    illinois
    ok so here is my question and thread hijack... what are the possible codes to recode the tranny and what does each do? im going to get this done in the next couple days and i want to know my options
    Feb 01 2008
    Missouri
    You could do it with the cheap ebay cable... I still recomend buying the full version, but you can, just letting you know :)
