Page 1 of 3 123 LastLast
Results 1 to 40 of 112
    Jan 11 2007
    Salt Lake City, Utah
    Official GT S4 car consolidation thread.
    Rather than having to go out and search through tons of threads to find out which cars have a GT setup and what exactly they have done, if it's your car or you have extensive intimate knowledge of the car, please list the setup of the car (otherwise please don't). Also, if you don't have a GT setup completed yet, but are for sure going to do it, feel free to list your equipment. To keep it clean and readable use these categories:
    Engine bore:
    Rods:
    Pistons:
    Heads:
    Cams:
    Valves, springs, retainers, whatever:
    Headgasket:
    Compression ratio:
    Intake Manifold:
    Throttle Body:
    Diverter Valves:
    Turbo kit (ie. Tial, ASP, Vast, VAG, GenX, Custom):
    Turbos (use full model # like GT2560R-466541-1) :
    Wastegates (routed external?):
    MAF (brand and size):
    Injectors:
    Fuel Pump:
    Fuel Pressure Regulator:
    Air Intake/Filter:
    Tune:
    Clutch:
    Flywheel:
    Intercooler(s):
    Mounts (motor, tranny and snub):
    Exhaust:
    Which wideband:
    Miscellaneous (Y-pipe, bipipe, ported stuff, fuel rail, phenolic spacer, MBC, oil cooler, EFK, cutouts, standalone, whatever):
    If dynoed,
    AWHP:
    TQ:
    Gas used:
    Which Dyno:
    Ambient temp:
    Gear:
    So far I've heard of these cars that have/had/are planning a GT setup: generationjdm, Guruman, VAG's Nogaro car, Silver? Vast car, WMS Black beast (dead?), ASP's Laser, Tory's Cactus ASP, Bertwerks, Huminator, NYCVR6, lil' is 300, tommyrsko4, Eurocode, Greg @ SSP (2001S4NY), Eurocode, Slkdik, Mike@Vast, someone at WMS getting the TIAL kit, Johnny Bravo on his own car?, EPL getting Tial kit, Skydive@AI, ///M3 to S4, that white widebody avant
    Feel free to add/correct that list of people. Let's make this one good
    Awaiting Confirmation Two Rings
    Oct 06 2006
    Mt. Laurel, NJ
    Re: Official GT S4 car consolidation thread.
    we have built over 20 of them ;)
    Active Member Four Rings NYCVR6's Avatar
    Queens, NYC
    Quote Originally Posted by Frank@AutoSpeed View Post
    1/4 Mile times out of any of them? Just curious.
    Justin- 01.5' Pearl S4 24V VR6 Turbo Pow Pow
    034 Motorsport
    FFE Racing
    MoTec
    Tuned By Shane T
    Boost Factory!
    Drive your car, not your dyno sheet
    Oct 06 2006
    Mt. Laurel, NJ
    Torys car went 11.3@126, The eurocode car went 10.8 @ 131, Marks car we are still playing with, other than that no other customer has had any desire to drag race their car.
    Jan 11 2007
    Care to humor me and fill out my spec sheet for any of those cars you've built?
    and you NYCV6 as well? Or if people are keeping things on the DL, that's fine too.
    Feb 17 2004
    Sterling, VA
    Geez, that would be the second item on my list. Dyno would be first.
    I'm guessing that alot of the people who had them installed just whip them around occasionally and then put them back in the garage.
    Brett - Moderator
    Issue?: email me.
    _____________________
    Stage 3 2004 A6 2.7T 6M
    Veteran Member Three Rings Dowskeet's Avatar
    Aug 10 2007
    All that money and no 1/4 times.. :(
    Active Member Four Rings Jung's Avatar
    Jul 07 2007
    Tempe, AZ
    people that can shell out the money to do it all are mostly rich schloobs who drive them once a week to the grocery store
    '07 S4 Avant - The Purpetrator
    there's just something about her, maybe it's her awful accent but i've always wanted to tonguepunch her fartbox - cruz
    Senior Member Three Rings YBLEGL's Avatar
    Sep 22 2006
    2001.5 AUDI S4
    BOSTON
    Quote Originally Posted by jungb5s4 View Post
    You kidding they dont goto the grocery store they have there live in maids go for them =()
    MAINTENCE AND STAGE 3 INSTALLS DONE, PM ME, MASS/ RI LINE AREA
    2001.5 S4 SILVER 6 SPEED BUILT BLOCK AND SINGLE TURBO KIT WITH PTE 6262.
    Queens, NYC
    Thanks Frank.. I was just wondering if any others have hit the track since then, i know the strip isnt some people cup of tea, but its a great gauge of power.
    I will fill out the spec sheet i guess haha.. im lazy
    034 Motorsport
    FFE Racing
    MoTec
    Tuned By Shane T
    Boost Factory!
    Queens, NYC
    No reasont to keep secrets, everything comes out eventually..
    Engine bore:2.7L
    Rods: Pauter
    Pistons: OEM
    Heads: OEM
    Cams: RS4
    Valves, springs, retainers, whatever: Supertech
    Headgasket: 034EFI
    Compression ratio: 8.6ish:1
    Intake Manifold: Turks
    Throttle Body: Stock
    Diverter Valves: 710n
    Turbo kit (ie. Tial, ASP, Vast, VAG, GenX, Custom): Generations
    Turbos (use full model # like GT2560R-466541-1) : Not sure yet
    Wastegates (routed external?): External 44mm tials
    MAF (brand and size): 90mm ASP
    Injectors: 60ld for now
    Fuel Pump: 034efi bosch motrsports
    Fuel Pressure Regulator: 4bar
    Air Intake/Filter: RS4 box paper filter
    Tune: ?
    Clutch: ASP twin disc
    Flywheel: ASP
    Intercooler(s): ASP
    Mounts (motor, tranny and snub): RS4
    Exhaust: Borla
    Which wideband: Innovative
    Miscellaneous : Generations bi pipe, phenolic spacers, MBC, oil cooler, EFK
    No big tricks here, i just want something real fun..
    034 Motorsport
    FFE Racing
    MoTec
    Tuned By Shane T
    Boost Factory!
    Nov 19 2005
    Pair of (. )( .)
    i wish people here on AZ would be like you
    people so "top secret" about their build ups, like: "i have something but i am not gonna tell you what..."...
    Quote Originally Posted by NYCVR6 View Post
    No reason to keep secrets, everything comes out eventually..
    -Andrey
    Stanced and Tuned Brilliant Black RWD C5 A6 2.7T 6MT
    Jul 17 2004
    Justin, I didn't know you switched to Generations kit...or was that the plan all along?
    I will post up my "spec sheet" in a bit - I need to run to the machine shop and pick up my built heads before they close today!
    Alex
    2001.5 Nogaro Blue S4, 6-Speed, ARD 2.7T 68mm HTA GT2868 Kit
    Veteran Member Four Rings GURUMAN's Avatar
    Mar 13 2007
    2.9L PTE 6766 1000 Bhp single Monster !
    Montreal
    What I have for now:
    Engine bore:2.8L
    Rods: 034 Motorsports
    Pistons: JE 82.5mm coated
    Heads: 2.8
    Cams: 2.8
    Valves, springs, retainers, whatever: Supertech (034)
    Headgasket: 034 stock height
    Compression ratio: 8.5:1
    Intake Manifold: RS4
    Throttle Body: 75mm, from a vr6 i think (drive by cable conversion)
    Diverter Valves: Twin greedy BOV
    Turbo kit VagMotorsports
    Turbos GT2560rs .64 housing
    Wastegates :Tial Twin V-banded External 44mm
    MAF (brand and size): What MAF?
    Injectors: 900cc
    Fuel Pressure Regulator: Aeromotive
    Air Intake/Filter: Twin K&N filters
    Tune: 034 stand alone
    Clutch: CM FX600
    Flywheel: CM
    Intercooler(s): Vag FMIC
    Mounts (motor, tranny and snub): 034 track density
    Exhaust: Mangnaflow custom
    Which wideband: Twin Innovative + Autometer EGT'S
    Miscellaneous : aluminium pulley kit, 034 phenolic spacers...
    Queens, NYC
    Quote Originally Posted by kievskiy View Post
    I probably would have been like that too ten years ago though. Its mostly young kids who pull that secretive stuff, or someone who is fairly new to building fast cars. They think they are doing the newest most innovative thing around and nobody will beat them. There is ALWAYS a faster car lurking the streets. I used to clean up around my neighborhood with a 600whp street gti vr6, that weighed 2500 lbs.. I came across a grand national with the plates "justa6" and he annihilated me. After talking to him it turns out it was a low 9 sec street car. Now i build cars for me, and for the love of going fast. Everyone can take their secret builds and shove them, when the truth usually comes out, there was nothing special in the first place.
    034 Motorsport
    FFE Racing
    MoTec
    Tuned By Shane T
    Boost Factory!
    Queens, NYC
    Quote Originally Posted by GURUMAN View Post
    HEy buddy, im intrested to see how the 034 management works on your car. If im not successfull with stock engine management tuning, hen im goingwith stand alone. Either autronic or somehing like you.
    034 Motorsport
    FFE Racing
    MoTec
    Tuned By Shane T
    Boost Factory!
    Mar 13 2007
    Montreal
    To tell you the truth, I have a lot of great expectations about this 034 kit. Once it's tuned, i dont even mind sharing my maps... Anything to help fellow S4
    Queens, NYC
    Quote Originally Posted by lil' is 300 View Post
    There has been a change of plans, we had a ton of rouble fitting those 3071's, so i need to get the car back together oon and Shaun wasthe clear option.
    034 Motorsport
    FFE Racing
    MoTec
    Tuned By Shane T
    Boost Factory!
    Queens, NYC
    Thanks i appreciate that. I was the same way with my vr6, i must have sent DTA P8Pro maps to 50 people over the years. Im interested in if the cluster will work, performance obviously, i guess emmisions is out the window?, etc.... Thanks again, hopefully ill see you at waterfest again this year.
    034 Motorsport
    FFE Racing
    MoTec
    Tuned By Shane T
    Boost Factory!
    Jul 17 2004
    Great selection
    Alex
    Jul 17 2004
    Engine bore: 2.7
    Rods: Rosten
    Pistons: Stock
    Heads: 2.8
    Cams: 2.8
    Valves, springs, retainers, whatever: 034/Supertech, Inconel exhaust valves
    Headgasket: 034 (compression dropping)
    Compression ratio: 8.6:1 (approx)
    Throttle Body: W8
    Diverter Valves: 710N
    Turbo kit (ie. Tial, ASP, Vast, VAG, GenX, Custom): GenX
    Turbos (use full model # like GT2560R-466541-1) : GT2554R - 471171-3 (worked)
    Wastegates (routed external?): TiAL V44's (re-routed to downpipes)
    MAF (brand and size): TBD
    Injectors: TBD (probably 60's)
    Fuel Pump: 044 Bosch Motorsport (034 drop-in)
    Fuel Pressure Regulator: 034 adjustable FPR (might just use stock)
    Air Intake/Filter: TBD
    Tune: Will be disclosed after finished
    Clutch: South Bend Stage 4 Feramic
    Flywheel: OEM
    Intercooler(s): Evolution Racewerks SMIC's
    Mounts (motor, tranny and snub): 034 Street Density's + 034 Snub
    Exhaust: Burns Stainless 3.5'' (custom)
    Which wideband: Zeitronix
    Miscellaneous (Y-pipe, bipipe, ported stuff, fuel rail, phenolic spacer, MBC, oil cooler, EFK, cutouts, standalone, whatever): RS4 fuel rail, RS4 charge pipes and TBB, 034 phenolic spacers.
    Alex
    Veteran Member Three Rings OneSickSedan's Avatar
    Feb 23 2005
    2001.5 Audi S4 6-Speed WMS Stage 3-
    Southern California
    ^Hey Alex did you switch to gt2554's? I thought you were going to use gt2560's. Or does the gt2554-471171-3's which are worked, equivalent to gt2560's?
    Just curious because if I ever have the money to do a gt build, it will most likely be similar to yours but with gt2554's and all the other hardware you got with Motronic 7.1. I want mine to be a daily driver as well.
    Your build sounds awesome and can't wait to see how it turns out. Actually I can't wait to see how everyones gt builds turn out. The B5 S4 platform is advancing because of you guys. I applaud all of your efforts. Good luck to all.
    2001.5 6-Speed Santorin Blue S4 (WMS Stage 3-,mod list in my profile)
    "Who, after all, speaks today of the annihilation of the Armenians?" - Adolph Htiler
    Let's end the cycle of genocide by recognizing the Armenian Genocide and end the Darfur Genocide.
    "If you're not first, you're last." -Ricky Bobby from Taladega Nights
    "LIVESTRONG" - Lance Armstrong
    Jul 17 2004
    Quote Originally Posted by OneSickSedan View Post
    I made a last minute switch to GT2554R's with some special sauce.
    Alex
    Feb 08 2008
    01' 2.9L GT S4 racecar built for TA/GTS competition
    North Jersey
    I guess this shows how bad everyone wants to share their individual projects? I do appreciate you guys sharing yours tho :)
    Jan 11 2007
    Bump, anyone else willing to share their setup? (and out of general respect, please don't ruin this thread Dr. Duct)
    Account Terminated Four Rings
    Nov 30 2006
    01.5 pearl white S4 6speed
    annapolis, maryland
    very good thread jibber. This will give people more to read about involved!
    Justin.. Very interested to see what you do with this GT setup. you seem to do well with your setups in the past.
    p.s. I think you could possibly run with Jrocks (white one from h20) single turbo supra..even though you doubt yourself. Just bring race gas, I wont tell. lol
    Mar 14 2007
    michigan
    I will be running my GENX kit on the stock motor..
    GT2560ss
    stock cams
    stock intake manifold
    stock throttle body
    stock 2.7 heads
    GENX Bi-pipes
    Vag 85mm maf
    60lb injectors
    custom cold air setup
    3.5 inch exhaust with a cat
    Custom stage 4 clutch from CM with a R2 flywheel
    Vast intake spacers
    I'm sure theres many of missing parts, but this is the basic setup i will be running..
    Veteran Member Three Rings sfored's Avatar
    Dec 30 2004
    Engine bore:2.7L
    Rods: Pauter
    Pistons: JE FSR
    Heads: 2.7
    Cams: Revolver (crossing fingers)
    Valves (stock) , springs, retainers, whatever: titanium something but not sure about he brand
    Headgasket: Custom Copper (based on stock)
    Compression ratio: 9.0:1
    Throttle Body: 80mm, from a Ford something i think (drive by cable conversion)
    Diverter Valves: Single greedy BOV
    Turbo kit Custom
    Turbos Some funky setup of out of business Innovative T3/T4 with GT internals .36housing
    Wastegates :Tial Twin External 44mm
    Injectors: 630 Siemaens
    Fuel Pump: 044 Drop in
    Fuel Pressure Regulator: 034 Adj. FPR
    Air Intake/Filter: Twin HKS Mushrooms
    Tune: Autronic SM2 - Turbo Joe Tuned
    Clutch: CM Twin Ceramic Disk
    Flywheel: CM LWFW :(
    Intercooler(s): ER SMIC
    Mounts (motor, tranny and snub): Autospeed.. entire set (stiffest)
    Exhaust: Dual 3" into single 4" Mangnaflow and Borla exhaust
    Miscellaneous : Is this where we put the NOS etc ? :)) j/k
    2001 S4 GT28, 2001 S4 168K
    Long Island, NY
    Engine bore:2.7L
    Rods: ROSTEN
    Pistons: STOCk Coated
    Heads: 2.8
    Cams: 2.8
    Valves (stock) , CAT Springs
    Headgasket: 034
    Intake Manifold: Custom Tube Manifold
    Throttle Body: Stock Maybe or 80mm
    Diverter Valves: Forge
    Turbo kit: GenJDM
    Turbos GT2860
    MAF (brand and size): NO MAF
    Injectors: 60LB
    Fuel Pressure Regulator: OEM 4Bar
    Air Intake/Filter: Twin ITG Behind the Headlights with High Beams Cutout
    Tune: SSP
    Clutch: RS4 PP with Ceramic 8 Puck Disck
    Flywheel: STOCK
    Mounts: 034 Track Mounts
    Which wideband: Innovative LM1
    Jan 11 2007
    Quote Originally Posted by 2001S4NY View Post
    Tune: SSP
    Veteran Member Three Rings MiniRS4's Avatar
    Aug 11 2005
    Engine bore: dont
    Rods: worry
    Pistons: so
    Heads: much
    Cams: about
    Valves, springs, retainers, whatever: other
    Headgasket: peoples
    Compression ratio: builds
    Intake Manifold: and
    Throttle Body: worry
    Diverter Valves: about
    Turbo kit (ie. Tial, ASP, Vast, VAG, GenX, Custom): your
    Turbos (use full model # like GT2560R-466541-1) : own.
    Wastegates (routed external?): to
    MAF (brand and size): the
    Injectors: rest
    Fuel Pump: who
    Fuel Pressure Regulator: have
    Air Intake/Filter: shared,
    Tune: tread
    Clutch: carefully.
    Flywheel: you
    Intercooler(s): are
    Mounts (motor, tranny and snub): asking
    Exhaust: for
    Which wideband: trouble.
    If dynoed,
    AWHP: its
    TQ: called
    Gas used: theft.
    Which Dyno: get a clue.
    Ambient temp: thanx.
    Gear: that is all.
    Veteran Member Four Rings Audi S4 Turbo's Avatar
    Feb 11 2005
    E46 Bmw M3
    Encinitas,San Diego,California
    ^^ So what you're saying is that you are going to run bigger then gt2860s? Nice.
    -Justin
    EVT 700 997 Turbo 6MT
    TDI A3 Prestige
    Jan 17 2008
    louisville
    jeez, i asure am gonna travel to NJ to find this one specific mans car, break into it, not set off the motion sensor, pop his hood, remove his motor and steal his turbos one night while he sleeps.
    Aug 11 2005
    Quote Originally Posted by Audi S4 Turbo View Post
    no no. never that! that would be stupid (for me) as that is not what i am looking for. also, the bigger you go, the more shit you gotta get, ie. twinny clutch, fuel pump, etc, etc.
    Aug 11 2005
    Quote Originally Posted by nogaroblueaudi View Post
    dont be a fool and joke around like that, bc that is how it goes down. duH!
    Long Island, NY
    Some have to go to extreme measures in order to protect their car from being stolen
    People tried to follow me home a few times from meets
    Aug 11 2005
    thank you, my point exactly. most of these cars arent getting taken at the mall. the nicer ones are being taken from the owners homes. ie, DAS80, and many other successful and failed attempts.
    Mar 14 2007
    michigan
    Disable the car in 2-3 different ways
    Long Island, NY
    Quote Originally Posted by generationjdm View Post
    yes but if you attract people to your car you will have it vandalized inside, something stolen from the inside or engine bay, Have to fix the Door, Have to fix a window, have to fix the ignition switch = $$$$
    Mar 14 2007
    michigan
    theres no fool proof way, but if they steal the car and you don't have a separate riders policy to cover all the mods your screwed.. Leave the car unlock and you can save the window haha
