Results 1 to 14 of 14
    Veteran Member Two Rings
    Dec 03 2004
    Illinois
    Unhappy RS4 Sway problem, help??????
    I was installing a RS4 sway bar last night and ended up breaking one of the bolts that holds the bracket on. The bolt was on the passenger side on top. Is there an easy way to get it out? I am pretty sure I crossthreaded it. Has this happened to anybody else, please help????
    Dec 03 2004
    Illinois
    Re: RS4 Sway problem, help??????
    Bump, nobody can help?
    Dec 06 2007
    drill it out!
    -Kirk
    BetaAlphaTau Member #58
    Dec 03 2004
    Illinois
    thats what I was thinking but I am pretty sure I wont' be able to get in there without taking the exhaust off. Just doesn't seem like there is enough clearance?
    Feb 15 2008
    AWE powered B6 1.8T
    Severna Park, MD
    To aid in clearance you could cut the bolt as short as possible, then drill with a right angle pneumatic(air) drill and then use an easy out... and if it is cross threaded you'll have to go back with the proper tapp to clean it up for a new bolt.. GL
    Veteran Member Four Rings JBM's Avatar
    NorFOLK, VA
    get one of the craftsman EZ outs.
    "Give a Man a Fish, Feed Him For a Day. Teach a Man to Fish, Feed Him For a Lifetime"
    '02 B6 1.8T, UnitedMotorsport Tuned FrankTurbo L21, 550CC, 3" MAF, BB Intercooler, 007, 034 HFC, Neuspeed Exhaust, B5 S4 Brakes, KW Suspension, S4 Recaro, and the list goes on.
    Veteran Member Three Rings Dos::Avants's Avatar
    May 30 2007
    Garage no more :-(
    'sconsin
    Can you post a pic so we can see what kind of clearance we're looking at?
    Otherwise, I'd agree with pondside36
    Avanta-Humpa-Lot
    Dec 03 2004
    Illinois
    I'll try and get a pic when I get home tonight.
    Dec 03 2004
    Illinois
    I don't have the right angle air tools but it looks like that might be the only option. I just cant see how I could get a regular drill in there. If thats the case I am going to have to take it to a shop. I was thinking to try and heat it up a bit with a pencil torch then twist it out with some vice grips. Any other suggestions?
    Feb 15 2008
    AWE powered B6 1.8T
    Severna Park, MD
    Ouch guy... I was just looking at the spot on my car but it wasn't on jacks so I couldn't see the back side.. does the bolt go all the way through? If it does you may have enough clearance from the back side to drill and easy out it... just go in the loosen direction or you'll draw it further into the hole. Also you may be able to find an electric right angle drill at Home Depot...
    Dec 03 2004
    Illinois
    Could anybody else chime in. I am going to try and tackle this tonight and want to have any and all ideas at my disposal. Thx, guys!!!
    Nov 13 2007
    02 A4 3.0QM, 84 Rabbit GTI
    Gaithersburg, MD
    You really need to take a look at the back of it. If the stud is pressed in to the bracket, you can heat it up and pound it out. If it's welded, you'll probably want to take it to a shop to have it drilled or ground out and replaced.
    Established Member Two Rings gotquattro's Avatar
    Jun 18 2007
    02 A4 3.0 Q / T / S
    Tallahassee
    Well, that's a nice one....
    Did you mess with it tonight? How'd it go?
    If it was mine, ........
    First thing I'd do would be to apologize to the neighbors....
    Then I'd pull the sway bar back off,
    and drop the exhaust mounts by the muffler tips, six bolts total
    Then, with all that room, bob's your uncle...
    Enough exposed you could try to back it out with vice grips.
    Cross-threaded & tight enough to snap, it'll take a bit of work to back out.
    Got a dremel tool? you could cut a slot, or better two flat sides for the vice grips to lock onto...
    Have fun!
    Got Quattro?
    02 Silver A4 Sport (sold)
    3.0 Q / T / S
    14851's | RS4 Rear Sway | Slotted F&R w/ Hawk HPS & Stainless lines | APR Snub
    2006 MazdaSpeed6 GT #3476
    - clicky-clicky for details
    Veteran Member Four Rings F16HTON's Avatar
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    Drill it out and use a new bolt with a nut on the backside. This is much easier than rethreading.
    You can go to a muffler shop at about 4:30 PM and they should blow it out with a torch for about 10 bucks.
