Results 1 to 13 of 13
Thread: B6/b7 Mpg
    Apr 16 2008
    New York
    B6/b7 Mpg
    ghhjklkl
    Veteran Member Four Rings Louis J.'s Avatar
    Dec 26 2007
    PNWR
    Re: B6/b7 Mpg
    Newer technology...largely FSI.
    Black B7 Titanium - Sold
    APR93 | Carbonio | Vogtlands | RS4 sway | Abt quad-tip | Podi | BBS RCs w/RT-615s | RS6s w/W300s
    Veteran Member Four Rings VZWalex's Avatar
    Feb 21 2008
    09 Q5 Ibis White
    Los Angeles, California
    Re: B6/b7 Mpg
    ^^ what Louis Said and ...
    pretty easy ... the 1.8t has to work harder to speed up and such ... as where the 2.0 doesn't have to work as hard.
    Study shows that the faster you get to the desired speed ( without flooring it of coarse ) and maintain the desired speed .. you use less fuel.
    I just did a trip this past weekend and combined city and highway I averaged 23MPG. Thats not bad considering there was a few *sprints* mixed in there and have the mods listed below. did I mention I had the car full of people and went through some mountains? Not bad huh?
    this is how I calculated the MPG
    drove 383 miles b4 filling up .. ( practically empty but light came on about 341)
    and we have a 16.6 gallon tank.
    383/16.6= 23.07MPG
    BTW @ $4.15 a gallon... It hurt a lil bit .. better start getting used to it !
    15 Mazda Cx-5 metero Grey - Stock for now ...
    09 Q5 Ibis White. Prem+, B&O, ZiZa Pure Yellow Fogs, Clear Bra,Prestige tint,Tunerdome LED Plate Bulbs, VIM, Vag'd
    06 MkV 2.0T - Sold
    05 XB Silvermist. - Sold
    www.EurovisionProtectiveFilms.com
    Sep 15 2005
    Norwalk, CA
    Re: B6/b7 Mpg
    i don't think that calculation is right.. you should fill up the car, reset the trip meter, drive until close to empty, fill up again, then take the milage driven and divide it by the number of gallons on the second fill up.
    you don't use all 16.6 gallons of the fuel, so dividing by 16.6 isn't accurate
    Peter
    Feb 21 2008
    09 Q5 Ibis White
    Re: B6/b7 Mpg
    Quote Originally Posted by peta8368 View Post
    Peter
    I guess I should have been more specific .... On my last tank of Gas .. that is what happened and yes i always reset my trip meter... so the mpg is based on that tank of Gas. I am still on the second tank of gas from my trip .. So I cant use that for this just yet. I am using the whole 16.6 gallons cause I lost the Receipt with the amount of gallons I filled up with .. I think it was like 15.87 or something like that... even though it gives me a 24.13MPG using the 15.87 gallons ... I rather use a lower MPG figure to be on the conservative side untill this tank is out.
    I can repost MPG Figures when I fill up again .. but I might have to fill up b4 empty since the weekend is getting closer and I only commute 12 miles a day regularly.
    06 MkV 2.0T - Sold
    Veteran Member Three Rings Unleaded20T's Avatar
    Mar 27 2008
    Ducati Streetfighter V4S
    Allen, TX
    Re: B6/b7 Mpg
    The 2.0T engine has many updates to make it more powerful and more eficient
    [Current] 22' S6 | Daytona Gray | BO | Prestige
    [Sold] 21' S5 SB | Glacier White | BO | Prestige
    [Sold] 19' SQ5 | Ibis White | Prestige
    [Sold] 2016 A6 | Moonlight Blue | 3.0T P+
    [Sold] 2011 A6 | Black | Prestige
    "If everything seems to be under control, you are not going fast enough." - M.A.
    Veteran Member Four Rings airbornerifleman's Avatar
    May 20 2008
    2013 Passat TDI
    Toronto Ontario, Canada
    Re: B6/b7 Mpg
    Anyone know how to adjust the readout of the average MPG or L/100KM on our B7 color DIS. Mine says I average 11L/100KM but when I did a manual calculation it said 9L/100KM. Here is how I calculated. Filled the tank up, reset the tripo, reset trip comp 2 and drove it for 470KM then filled up again. Basically I used 52 liters of fuel to drive 470KM. 470/52=9.03.
    2006 Audi 2.0T quattro Tiptronic
    APR Stage 2+
    OEM+
    _______________
    2013 Passat TDI
    Veteran Member Three Rings Zebman's Avatar
    Dec 25 2007
    '06 A4, 08 R6s
    Morgantown/Hurricane, WV
    Re: B6/b7 Mpg
    6spd manual/auto vs. 5spd manual (???spd auto)
    2006 A4Q 6MT Arctic White - StageII++
    STaSIS SS Coilovers, EVOMS Intake, APR 93, OZ Ultraleggeras 17x8, APR Exhaust w/034 HFC, GSG Intake Pipe, AWE Front Mount, APR HPFP.
    2008 R6s
    : Racebike, don't feel like writing it all out.
    I don't get on Audizine anymore, so if you need me... sorry.
    Veteran Member Four Rings EMAXX's Avatar
    Jul 12 2008
    Re: B6/b7 Mpg
    I just back home this weekend and the whole highway trip, I averaged about 32 miles per gallon, cruising at about 85-90 the whole trip.
    2015 Audi S4 Prem+ Sepang Blue/Magma, 6MT, Eurocode Alu Kreuz, Eurocode Transmission Brace, Eurocode Sway Bars and Endlinks, RocEuro Intake, AWE Touring Exhaust
    Veteran Member Four Rings elwigglero's Avatar
    Sep 04 2008
    B7 S4 DTM, B7 A4 2.0T Ti
    Lansdale, PA
    Re: B6/b7 Mpg
    I get 25-27 with a mix of around town and highway. If it's an all highway trip, I'll get over 30mpg. This goes down if there's added weight in the car though.
    Senior Member Three Rings B7 Projectile's Avatar
    Aug 06 2007
    07 Audi A4 2.0T
    Lancaster, PA
    Re: B6/b7 Mpg
    Quote Originally Posted by elwigglero View Post
    Accurate, I get this with a stage II chip FMIC and Exhaust.. If you are doing 60 on the highway constant, I have gotten over 33MPG trip log.
    2007 Ibis Audi A4 2.0TFSI Ti Package
    Vorsteiner CF Hood.APR K04.APR HPFP.AWE Exhaust.AWE FMIC.034 HFC.KW-V2 CO's.Forge DV.3000k HID Fogs.Smoked Tails.Custom Intake.Heatshield.CC Mod.35%Tint.Blacked Rings.RS4 Rear Sway Bar.Podi boost gauge.
    Ah...so many pedestrians, so little time...
    Aug 08 2008
    2017 Q5
    Houston, TX
    Re: B6/b7 Mpg
    yeah, i get decent numbers on the trip log too, but when I take my miles per gallon at the pump its pretty weak sauce. haha oh well. and I drive like YOUR grandmother. =T and by your...i mean EVERYONE's. Because I know them all. =T haha
    Veteran Member Four Rings p1nk50ck's Avatar
    Sep 18 2008
    06 Audi A4 S-Line
    Arlington, VA
    Re: B6/b7 Mpg
    when i had the fwd b7, i got just a hair over 500 miles on a tank, with pure highway driving (ie - fill up and didn't stop or get off the highway until i had to fill up again) and cruise control on at about 65. the most i've gotten with the awd b7 is 465, but it wasn't purely highway. both cars are stock w/ manual gearbox
