Originally Posted by
mus27
So 91 is the recommended octane level in our cars? I have been putting in 93 since that's what my dealership told me.
No. What is "recommended" is on the inside of the gas door, or in your manual. In certain markets, like California, they don't have above 92-93.
Thus, car makers either detune the engine or they let the ECU control anything that happens with the lower than optimal octane fuel.
So, in Canada where you can't get above 91 and the recommended fuel is 91 octane, then all is well. However, if you were to use 93 octane you may actually see a boost in performance, if you're ECU is controlling engine operation with 91 octane.
Point is, using higher octane DOES NOT give you more power. Tuning an engine to achieve higher performance may require the advantages of higher octane fuel so that it can run at that tuning level. It's NOT the fuel that creates more power, it's the tuning.
I'm in the Chicago market where we get 92-93 pretty much everywhere.
91 would work just fine too.
To the OP:
Typically gas stations have 3 octane grades; regular, mid, high.
The difference it "most" stations is about $.10 between each one.
If you were to go with regular, you save $.20 per gallon.
Your Audi takes about 16 gallons to fill up the tank.
16 X .20= $3.20
mid grade: 16 x .10= $1.60
There is your answer.
Use the recommended octane.
