Results 1 to 3 of 3
    Registered Member Two Rings
    Apr 07 2008
    West Vancouver
    B7 Useing keys on a B6
    Hey,
    I was the B7 keys on eBay and since I need to get another key anyways I was wonder if they will work on a 2004? The guys says he knows it will work on a 2005. Has anyone upgraded to this key?
    And yes I know they have to be official Audi keys due to impurities in the metal.
    Thank you
    Registered Member Two Rings wifeysaudi's Avatar
    Apr 21 2008
    05 a4 1.8t quattro
    Brigantine NJ
    Re: B7 Useing keys on a B6
    yes but you will have to mod it. If you search under the the title you used you will find tons of info on a diy for this mod.
    Veteran Member Four Rings T0M3K's Avatar
    Sep 14 2007
    Valley Stream, NY
    Look for B7 key swap howto,
    all you need is to get a cut blade or re-use blade from old FOB, swap imo chips and you're set (unless your chip is glued in)
