Results 1 to 11 of 11
    Senior Member Two Rings 215 Motoring's Avatar
    Oct 13 2007
    01 S4 Stg3 Bound, 05 R1
    The 215 & 302
    Question HELP Need to Re-Program with Vag
    Doing an engine swap and I have the vag com program. Was told that the whole car needs to be re-programmed (everything) cluster, abs unit, etc. do someone have a tech sheet or something, so I can set the right codes.
    I DON’T KNOW WHERE TO START
    Im asking b/c someone gave me the ross tech software, and they wont help since i didnt purchased thru them.
    Thx for your help
    Dec 06 2007
    Calgary, AB, Canada
    Re: HELP Need to Re-Program with Vag
    An engine swap or an ECU swap?
    Oct 13 2007
    The 215 & 302
    Quote Originally Posted by The_Jerbel View Post
    both, i already have the ecu for the car. had a H Box(6spd) got a J Box (Auto/Tip) i had installed a auto/tip tranny on a 6spd motor. the car is about 90% completed.
    Dec 06 2007
    Calgary, AB, Canada
    your cluster doesn't need a recode. I don't believe the ABS module does either, but I'm not positive about that. The ECU will already have the appropriate coding, no need to touch that either.
    Oct 13 2007
    The 215 & 302
    Thx. So once i start the car i wont get any fault codes? and if i do what do i enter using the vag-com?
    Dec 06 2007
    Calgary, AB, Canada
    If you do get any codes, post them up and I'll help you find the correct coding.
    Feb 17 2004
    Sterling, VA
    Quote Originally Posted by 215 Motoring View Post
    So wait, you ditched your 6-speed for a tip?
    Brett - Moderator
    Issue?: email me.
    _____________________
    Stage 3 2004 A6 2.7T 6M
    Oct 13 2007
    The 215 & 302
    Quote Originally Posted by Daft View Post
    Yes b/c at that time I didn’t know how to drive a 6spd. However, yesterday one of my customers with a 08 BMW 3 series taught me. I learned under an hour (the basis) now im kicking myself in the ass b/c it wasn’t that hard to learn
    Hope I run into another 6spd S4 at the auction
    Oct 13 2007
    The 215 & 302
    ok started the car today however here are the codes from my vag. please help me out
    Address 01
    18010- power supply terminal 30: voltage too low P1602-35-10--- intermittent
    18057- powertrain data bus: missing message from abs controller P1649-35-00
    17861- exhaust gas temp sensor 1 (g235): open or short to plus P1453-35-00
    readiness 0110 1101
    Address 02
    17125- torque converter clutch circuit perfomance or stuck off P0741-35-00
    18258- prowertrain data bus: missing message from ecu P1850-35-10-- intermittent
    18265- load signal error message from ecu P1857-35-10-- intermittent
    18249- engine control module/ transmission control module incompatible P1841-35-10--
    intermittent
    Address 03
    No Fault Codes
    Address 08
    Notes: Excessive Comm Errors
    Address 17
    00779-Outside Air Temp sensor (g-17) 30-10- open or short to b+ intermittent
    Address 45
    01377- Ultra Sonic sensor for alarm system: left (g170) 31-00- open or short to
    ground
    01381- alarm triggered by anti-theft sensor: rear right 35-00
    Veteran Member Three Rings SilverSurferS4's Avatar
    Jun 11 2007
    What I think you should do... This is just my opinion... If you got all these codes upon start up of the car, Maybe you should clear them all, Drive the car and then see what codes pop back up... and let us know..
    Also make sure you battery and ground connections are nice n tight..
    Oct 13 2007
    The 215 & 302
    Quote Originally Posted by SilverSurferS4 View Post
    i was thinking the samething, but wanted a second opinion. however i will chx all of the ground connections thx
