Results 1 to 15 of 15
    Oct 01 2007
    Location, Location, Location
    Difference between Stage One and Two
    So i tried searching for this, but unfortunately the way its most commoly spelled is "stage II" where the II is under the search limit, so i figuered i would spell it differently for anyone who searches in the future for this topic... Anyway, the title basically sums it up, with APR (assuming i get an exhaust) what is the difference between stage one and stage two? I hear that stage two is more aggressive, but how much more and what exactly does that mean?? I like how my car drives with just stage one now, but will i be missing a lot not to go to stage two if i get an exhaust?
    Veteran Member Four Rings quattrosaint's Avatar
    Sep 24 2007
    Dallas
    Re: Difference between Stage One and Two
    Quote Originally Posted by masteroc View Post
    its more agressive, I felt the difference from the change over. I was happy with stge 1 but my goal is mid 13's so I had to do it
    2007 A4 Quattro 2.0T Tip
    Go Fast:Custom GIAC Tune & APR HPFP & AWE FMIC & AWE Exhaust & Labree DP & K&N Filter & Forge DV & Eurojet PCV
    Stop: ECS Stg 4 Porsche BBK
    Twisties: H&R Springs & RS4 Sway & Ti Rims
    Stunt: S4 Grill & S4 Rear & Cupra R Spoiler & TTS Wheel & 8MM Spacers & CF Trunk
    Now................Mostly parted out. Thanks everyone who participated
    Registered Member Three Rings era's Avatar
    Feb 01 2008
    2008 A4 2.0T Quattro TIP
    Brooklyn NYC
    What I want to know is, is a test pipe required for stage II setups?
    - Debadged - Blacked-out RS4 Grille - Prolumen 6000k HID - Llumar 35%/15% - Höen Fogs - CC Mod - VAG'd - Gun Smoked Tails -
    - Blacked-out Housing - VAG'd - CF DTM Style Spoiler - Painted Red Calipers - Red Interior LEDs - Stasis SS CO - Angel eyes -
    About to install:
    Senior Member Three Rings tivs31's Avatar
    Feb 07 2008
    Lemont IL
    yeah I'm kinda curious about that as well?
    Is stage 2 the following:?
    - intake filter
    - fuel pump
    - test pipe w/exhaust
    ? is there anything else I'm missing? or is the fuel pump even part of the stage 2? and is the test pipe crucial in the stage 2 or would a downpipe back exhaust still work as stage 2, lol
    The apr site is kinda wierd about it as well, not really straightforward.
    Oct 01 2007
    Quote Originally Posted by quattrosaint View Post
    Thats the only thing, i'm not really looking to get really low 1/4 mile times. I just need a good daily driver that can give me some good power. How much more aggresive do you mean? I'm trying to look at this practically because ill still have to be going through traffic and such every once and a while, but i still want to be able to open it up on the highway, etc.
    P.S. I kinda rethought my question and i think it would be better put as this: if i get an exhaust, do i have to do stage two to make it worth it, am i hurting the car (does stage one not handle an exhaust well?).
    Sep 24 2007
    Dallas
    to answer your restated question: no you dont have to go to stage 2 to make an exhaust worth it. Stage 1 handles it fine. To the person who asked about the test pipe. You do not need a TP to run stage 2 software, however stage 2 software will delete the CEL caused by the TP and Stage 1 will not.
    Sep 24 2007
    Dallas
    Quote Originally Posted by tivs31 View Post
    - intake filter
    - fuel pump
    Stage 2 is just new software and an exhaust. The other stuff just enhances stage 2. I consider a fuel pump stage 2 plus.
    Established Member Two Rings fD3S's Avatar
    Dec 08 2006
    3rd Gen Mazda RX-7 tt / 07 A4 2.0T 6MT
    SouthFlorida
    My understanding is that all stage II software does is:
    1. Prevent the CEL from coming on due to having a test pipe and/or exhaust. (fact)
    2. De-tunes the car to prevent boost spike and therefore preventing fuel cuts. I hope I am wrong, I have a test pipe waiting to go in, but if the stage II software is less aggressive for this reason, I won't install it. We need an answer from someone that knows for a fact.
    07 A4 2.0T 6MT Quattro - APR 93/100 - Stasis coilovers - Ecode TP
    93 Mazda RX-7 tt Petit ECU, Down pipe, Catback, ACT clutch, HKS bov, K&N filters; Tein lowering springs, 99 Front end
    04 Suzuki GSX-R600 Yoshimura pipe; K&N filter; Vortex Sprocket; HID conversion; Hotbodies undertail
    Sep 24 2007
    Dallas
    Quote Originally Posted by fD3S View Post
    1) correct about the CEL
    2)stage 2 does not detune. Stage 2 generally brings on fuel cuts due to more agressive fuel mapping
    Oct 01 2007
    What exactly does "more agressive fuel mapping" mean?
    I have also heard about the fuel cuts, i assume that to correct this you need a new fule pump?
    Veteran Member Four Rings RedS-line's Avatar
    Mar 19 2008
    2019 S5, 1990 944 S2
    (my theory) i think that the companies are intentionally vague about stage II because stage II is more about complimenting your mods then actually adding power. the map may be more aggressive, so im guessing you might see a few more peak hp/tq but then again just adding an exhaust or test pipe would do the same anyhow. throttle response, turbo spoolup, etc. might be better but i question how much more power youre really gonna see. I mean, what's the difference between revo stage 1 running full boost with the select plus switch and stage II? Once again, this is just theory; Ive never experienced stage II so i could be way off here...........
    2019 S5 BO.SS
    1990 944S2 Cabriolet
    2009 R8 6 Volt :)
    Veteran Member Four Rings VZWalex's Avatar
    Feb 21 2008
    09 Q5 Ibis White
    Los Angeles, California
    ^^ TRUE
    Stage 2 is a more agressive program.. generally you can upgrade to stage 2 with a Fuel pump upgrade and TP combo ... Most of the time peeps with TP's get a Stage 1 with tp software ... but since that program demands more fuel to benefit the TP mod , it generaly causes fuel cuts at higher RMPS/ or MPH I believe.
    From what I have seen at APR Dealers is
    -91/93 octane program
    -91/93 oct with tp
    -91/93 oct with Fp & Tp
    Above mentioned in both Trip Tranny program and 6 speed manual. Yes there is actually a file for the trip tranny and one for a 6mt in all of the above configurations. If Mike @ Apr would like to correct this please do! Your input would be great Mike !
    15 Mazda Cx-5 metero Grey - Stock for now ...
    09 Q5 Ibis White. Prem+, B&O, ZiZa Pure Yellow Fogs, Clear Bra,Prestige tint,Tunerdome LED Plate Bulbs, VIM, Vag'd
    06 MkV 2.0T - Sold
    05 XB Silvermist. - Sold
    www.EurovisionProtectiveFilms.com
    Veteran Member Four Rings supamannn99's Avatar
    Nov 15 2007
    Orange County, SoCal
    is giac-x stage 2?
    Feb 21 2008
    09 Q5 Ibis White
    Quote Originally Posted by supamannn99 View Post
    is giac-x stage 2?
    nope I had GIAC X b4 I switched to APR .. its basically the same as any other Stage 1 software *some hp and tq numbers may vary* since every car is different
    06 MkV 2.0T - Sold
    Nov 15 2007
    i think im gonna switch to either revo or apr but i dont know the cheapest way to do it
