Originally Posted by
audimymind
BUT THERE IS A TRICK!!! now i dont know if its gonna work the same as it did for my hond headlights... but all you have to do is remove all the rubber you can from the headlight and throw them in the oven... yes.. the oven.. at 200' F for 8 minutes... lol when i had my civic... i baked my headlights one at a time on a cookie sheet... for 8 minutes... took them out and literally just pulled my headlights apart (well i had to kinda pop it open at the "tabs" where it locked into place).. and strans of seal/glue stretched from one piece to the otther like i split a grilled cheese sandwhich in half! now im not tellin anyone to put your headlight in the oven... but imma take a good look at my headlights and if/when i do this joey mod... ill be the one to test bake a audi headlight... and i will also try to install this citylight.. or create one... one with a bulb that i can change without having to "unglue" the lense everytime (cause thats wack)
think again. and read some joey mod threads. you aren't the first to try the oven... it doesn't work. that "glue" is more like RTV sealant (the stuff you use to make exhaust gaskets when you're feeling cheap) and your whole headlight would melt and burn before that stuff ever melted.
IT CAN BE SOFTENED, AND IS MUCH EASIER TO REMOVE FROM THE CLEAR PART AND THE HOUSING AFTERWARDS IF HEATED! i highly reccomend getting an old, sturdy knife, or a very thin-bladed screw driver and working your way around to remove it after you get the halves apart. it'll make your life SO much easier when putting it all back together.
but as for the bake-n-split.... unfortunately it doesn't work like that. there's this air tight seal that works like one of those "gripper pads" against the clear lens. the way it grips against the plastic, you have to work your way ALMOST all the way around and break that seal on the top AND bottom of the light. (if you do it, you'll understand)
the biggest "trick" do doing our lights is to get a good hook/pick set, and use that to work your way around quickly, while prying up as little as possible. using that method, and knowing what i was trying to do already - i got a headlight apart in about 45 mins... (while drinking a couple beers, so i prolly coulda done it faster lol... beer just helps to dull the pain of joey modding)
others here have done it in as little as 30 minutes i think.
