Results 1 to 13 of 13
    Veteran Member Four Rings aytheory's Avatar
    Oct 28 2006
    A4 1.8tqm 99.5 aeb ndbw
    Los Angeles / Santa Barbara
    Engine bottom block build attemp.
    My plan is to drop forge rods into my engine aeb with my next timing belt change.
    I don't need any cleaning or bore it down if the compression is good - i just want to take it out get it back in and change all that valves and gaskets.
    Question is how much time and money will this cost me.
    I assume i would need a engine cherry picker and a engine stand.
    reason i want rods is because i want to go gt3076r - and doing this by the most cost effective means
    Veteran Member Four Rings t1demont1's Avatar
    May 08 2007
    1999 1.8tqm gt3071r
    Orlando, FL
    Re: Engine bottom block build attemp.
    If youve got skills, you could probably put new rods in without pulling the motor. Ive seen it done in a b6. Dealing with the oilpan and the subframe is the hardest part.
    BetaAlphaTau Member #40
    1999 2.0 hx35 dbw conversion
    Oct 28 2006
    did their engine explode - doesn't it need to be balanced
    Oct 27 2007
    2001 Golf 2004 A4 USP
    In the lab
    based on your first two posts in this thread you need some serious redirection or otherwise need to pay someone to do this for you... i'm not picking on you, just trying to help you not make a mistake
    Feb 27 2005
    North Wales, PA
    if the engine is in good shape, you can get away with just replacing the rods and reusing the bearings and piston rings. Not the best way to do it though. Just check clearances and make sure the ring gaps and bearing clearances are in spec. you will have to pull the head, drop the sub fame, and remove the oil pan. to me its much easier just to pull the motor. It beats crawling under your car all the time.
    Oct 28 2006
    Quote Originally Posted by 317ssayzarc View Post
    yah - i saw what happen to the last guy - if i do take it to someone - i will take the engine out and bring it over for work - to have them bore it, with new rings, and bearing then balance the crank - and clean everything
    but i am poor so i need more innovative ways - might get myself into trouble with this one
    Oct 27 2007
    In the lab
    pm me your email, i have some nice documents that could point you in the right direction and they could be a tremendous help for you
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    Quote Originally Posted by aytheory View Post
    If you need someone to do the work let me know because I can line up the work to be done at Eurocode.
    Mar 09 2004
    99.5 A4 Avant, 01 allroad
    nw michigan.
    I did this years ago without pulling the engine. Got lots of pics too if you want to see them.
    Start HERE and work backwards. I lightly ported the intake manifold and head, pulled the head, dropped the subframe, and swapped the rods, rings, oil pump, and some other odds and ends.
    Jim
    I Do Werk.
    Registered Member Two Rings a220vt's Avatar
    Dec 03 2006
    '97 A4TQMS, '97 GTI
    Broomfield, CO
    I've done this without pulling the engine as well, but only because I already had a fresh hone on the cylinders. If you're doing new rings, you should really pull the block and have it honed or bored at a machine shop.
    Veteran Member Four Rings Euro-Tuner's Avatar
    Jan 06 2007
    NH
    there is on cheap way to prepare your engine for a GT30r. either you skimp in the beginning and end up having to go back in a fix and replace things that you neglected the first time, or you do it right the first time. Take this from someone who is wrapping up their build and doing it right the first time, unless you have loads of $$ to throw around, think twice. Also when you get a custom tune, the tuner will (or should...) tune specifically for what you have done to your car, so if you decide your ginna do cams a couple months down the road, and then do a different compression later, and so on and so forth, your tune will be all out of wack...do a lot of research before just jumping in, it is nowhere near as easy as it sounds.
    Mar 09 2004
    nw michigan.
    Here is the rub. There is no way to balance an engine without taking it out of the car. The whole point of rods is to let the engine make more power but the big turbos need revs to do that. Revs and unbalanced engines don't play well for long.
    The best plan is to swap the rods in the car and get the thing running with the larger turbo. Then build up a second engine on a stand and do everything the right way. Swap it in and sell the original built engine.
    Jim
    I Do Werk.
    Jan 06 2007
    NH
    ^^ thats how to do it if your not allowed a lot of downtime, if you have the luxury of having a second car, just do it right on our engine and save some $$ and effort.
