Results 1 to 40 of 67
    Oct 10 2007
    B6 1.8T USP
    GIAC Large Injector Program
    I'm hearing that the most recent GIAC large injector program is giving a pain to us. Does any know about this? I'm trying to choose between GIAC and APR.
    Veteran Member Three Rings Carlitos's Avatar
    Sep 17 2006
    B6 A4 1.8T
    San Juan, PR
    Re: GIAC Large Injector Program
    with correct injectors there should be no problem.
    FlexTuning
    Amulet 1.8TM
    BAT#46
    Veteran Member Three Rings scorneil's Avatar
    Oct 27 2007
    Oakville, ON, Canada
    i have GIAC BI and have no idea what you're talking about. have had it for 4-5 months now.
    2010 B8 S4 Quartz Gray S-tronic Black Alcantara MMI
    2003 B6 A4 Canvas Beige 1.8T Tiptronic 1+ SOLD
    Oct 10 2007
    B6 1.8T USP
    Quote Originally Posted by scorneil View Post
    This is what I am talking about.
    Quote Originally Posted by oregonaudi View Post
    giac puts a firewall on their newest software that makes it impossible to tweak the file via lemmiwinks. Not only does this limit your ability to alter your file for personal preferences, but it also prevents an east fix to the aggressive timing on the giac big inj file. This means that once you go giac and you experience engine pinging (a common problem, I would post a link but my phone does not copy/paste), you are essentially stuck with it unless you swap plugs or something to compensate for the mild detonation. In my case, plugs didn't work and I am currently running a file that is conservative.... and I just consider myself lucky to have a good tuner that cared enough to help me out and stop the pinging
    sorry for the ramble
    Quote Originally Posted by Carlitos View Post
    Will TT225 work without any problem?
    Oct 29 2005
    10speed
    San Francisco, CA
    there were a few threads on this, there was a plug that was found to fix everything... and I can run lemmiwinks with my BI file
    - Clint
    Oct 27 2007
    didn't know anything about that. i am running TT225 and haven't experienced any pinging.
    would be good to know what plug we're talking about, i would probably throw that in to be safe
    Oct 10 2007
    B6 1.8T USP
    Please let me know if you find something. I do not have much luck with the SEARCH.
    by the way, I go to Toronto frequently since my parents are there :)
    Oct 27 2007
    cool man, tons of peeps around here and AW from Toronto
    Veteran Member Four Rings diztek's Avatar
    Sep 20 2004
    2016 S3, RETIRED: Audi A4 1.8TQ usp
    Paradise Valley, AZ
    The new file is paired with a boost controller function in the file.
    You can use this to set the boost to a safe level for your car and
    hardware. The upgrade is 100 dollars since it is only paired with the
    boost controller function. I should note that you will need a vagcom
    cable to adjust the boost.
    2016 AUDI S3 Prem+ Monsoon Grey
    RETIRED:Audi A4 1.8t UltraSport - USP CLUB MEMBER #90
    Apikol Snub Mount-United Motorsport stage 2-Bosch 440cc-VR6 maf-034Motor Mounts-AWE Exhaust-RS4 Rear Sway-OEM DSMIC-Evo Billet DV-Podi Boost Gauge-Stasis SS Coilovers
    Oct 10 2007
    B6 1.8T USP
    Quote Originally Posted by diztek View Post
    At this point, I'm not trying to do much stuff, such as controlling the boost level. All I want to do is having a large injector program and have fun. No more headaches.
    Here is my question. If I go to GIAC dealer and have large injector file + TT225 and 710N DV Valve changed, will there be other items that I have to correct in the near future? It seems like I can walk away with that setup with APR Stage 1+. I just do not want to have a headache after doing a chip upgrade at this point.
    All I want is have the large injector file and walk away with smile :)
    Veteran Member Four Rings Tgr_Clw's Avatar
    Jul 20 2005
    2003 Audi A4 1.8TQM
    Toronto, Canada
    A truly bulletproof stage 1+ setup will need the following:
    - exhaust
    - test pipe or high flow cat
    - upgraded DV
    - upgraded intercooler
    - upgraded clutch
    - upgraded turbo inlet pipe and throttle body hose
    - upgraded clamps all around
    After that you'll have 0 problems.
    Quote Originally Posted by wychoi36 View Post
    Appearance: OEM+
    Interior: B6 S4 Recaro Seats
    Performance: MTM Stage 3 / Milltek Exhaust+Milltek HFC / JJ TIP / ASP FMIC / SB FE SS
    Suspension: Vogtland Coilovers / HSport S4 Sways
    Braking: Stoptech 332 BBK
    Wheels/Tires: BBS CH 18x8.5, ET35 / GY Eagle F1 GSD3 235/40/18
    Oct 10 2007
    B6 1.8T USP
    Quote Originally Posted by Tgr_Clw View Post
    - exhaust
    - upgraded DV
    - upgraded clutch
    just tell me to buy S4 or something lol
    i'm not looking to spend that much money.
    Jul 20 2005
    2003 Audi A4 1.8TQM
    Toronto, Canada
    Have to pay to play.
    Appearance: OEM+
    Veteran Member Four Rings QuattroRocket's Avatar
    Sep 01 2004
    2103 S4, 2014 Nissan Pathfinder
    Vancouver Canada
    I have been running the GIAC fx file for years now with great results. The best results came after a plug swap to a Porsche plug and a reflash to a more recent revision of the software a while back.
    I am selling off the injectors now and moving on but I am staying GIAC, never regretted the decision once.
    Gone but not forgotten : 2000 A4, 2002 A4, 2004 A4, 2013 S4 Premium, 2013 Q7, 2017 SQ5 Dynamic Edition
    Current Audi : 2017 RS7
    Oct 10 2007
    B6 1.8T USP
    Quote Originally Posted by QuattroRocket View Post
    I'm sorry, I don't quite get it. When you say "plug," do you mean the spark plug?
    Sep 01 2004
    Vancouver Canada
    Yes I replaced the plugs a few times till I got a setup that has worked 100%. Do a search for posts from me and you will find it.
    If you need injectors lemme know :-)
    Oct 10 2007
    B6 1.8T USP
    Thank you for the information. I do have TT225 injectors in front me. :)
    thankx
    Oct 27 2007
    Here is the thread
    http://www.audizine.com/forum/showthread.php?t=162328
    Apr 16 2008
    Utah
    After having GIAC FX for a year, and getting no resolution to my pinging (no help from GIAC either), I finally bit the bullet and switched to APR 1+.
    I couldn't be happier. Pinging is gone. Plus, APR gave me the fully loaded (all the programs) software for $500. APR isn't as aggressive up front, which is where i was having the pinging issue. But it makes up for it later on.
    Also, APR 1+ doesn't screw up your MPG display, like GIAC FX does.
    I would 100% recommend APR over GIAC, even if you have to drive to a farther dealer to get it.
    Oct 10 2007
    B6 1.8T USP
    Quote Originally Posted by rccks96 View Post
    Thank you.
    Here is my current situation.
    GIAC: abour 1hr drive. $720.00 Cash for Flash + Injector install + DV install
    (I bring my injectors and DV valve)
    APR: 3hr drive. $600 + Tax. Flash + Injector install + DV Install
    (Same. I bring the parts.)
    money wise, I APR gave me a better option as well
    so now, i'm debating lol
    Feb 15 2008
    AWE powered B6 1.8T
    Severna Park, MD
    Just throwing this in there... the DV install is super staight forward, it only took about 30min if you are looking to save money on install fees...
    Established Member Two Rings Rich4114's Avatar
    May 22 2007
    Nazareth, PA
    I think I may have this same issue with the pinging. I have the GIAC 1+ file with BKR7E-IX plugs and have strange issues if it's too cold or too warm outside. If I'm idling for example, my idle will sit steady at 800 RPM's but then drop down to 600 and spike up to 1200 and settle back down. Is this considered pinging? AWE told me I'm supposed to run the stock B6 plugs in my car with that file but it seems like so many people have to run something else.
    Current
    | MY 2013 S4 | Premium Plus | Estoril Blue | 6spd manual | Sport Differential | NAV | B&O | Black/Magma Fine Nappa | Audi Advanced Key | Carbon Atlas | 19" Wheels |
    Sep 13 2007
    04 Atlas Grey A4 1.8TQ Avant
    Quebec, Canada
    Rich, GIAC themselves told me to run stock plugs with stock gapping. I had misfires at high load so I tried BKR7E-IX @0.028" and they were too cold for my climate. One morning the car wouldn't even start anymore, the plugs were full of carbon. Tried BKR6Es @ 0.028" and I had less power and it was still shaky under load. Now run new stock plugs @0.030" and all seems well.
    That being said, there are people who successfully run other plugs. I guess it depends on how you drive, and what climate you live in...
    FXK03 - Stasis SS Coilovers - Forge DV - Forge TIP
    Apr 16 2008
    Utah
    I run BKR6E's in winter, and BKR7E's in summer.
    APR 1+
    Registered Member Four Rings audipotential's Avatar
    Sep 24 2007
    Woodbridge, Ontario
    Quote Originally Posted by gtimart View Post
    Did you try this in winter or summer? I dont think PQ and ON climate is that far off and was considering going to a colder plug
    Veteran Member Four Rings chris@penskeaudi's Avatar
    Apr 28 2004
    Audi A4, Q7 s-line, B8 A4
    La Verne, Ca / PENSKE AUDI
    I say with the right fuel injectors you should be fine.. GIAC would no release a rogram that would have issues
    EVOLUTIONRACEWERKS
    G.I.A.C fx k04 + TT225 injectors/k04-15
    Evolution Racewerks FMIC (black comp)-Evolution Racewerks Test Pipe-Evolution Racewerks Turbo Inlet Pipe
    Neuspeed Power Pulley-Neuspeed snub mount-Neuspeed Exhaust + misc mods
    Audi West Covina
    (AKA luvmshavd)
    Veteran Member Four Rings cuco33's Avatar
    Feb 20 2005
    2005 white a4 usp 6spd quattro
    Kearny, NJ
    I'm going stage 1+/2 soon. Def this year and I was leaning GIAC. I need to get injectors cuz everytime for local dub shows the vendors can't get the injectors in time... then again I usually ask a few days before the show
    http://img.photobucket.com/albums/v4...itled3copy.jpg
    http://img332.imageshack.us/img332/8615/44rdkk2bz9.png
    paul miller audi = the suck
    USP CLUB MEMBER #21
    LIVE / PSN: cuco33
    eurosoccerlounge.com
    eurokult
    Feb 15 2008
    AWE powered B6 1.8T
    Severna Park, MD
    I just made my appointment to GIAC FX for Monday and I'll give you a review after I drive around for a bit since it will be the newest version...
    Sep 20 2004
    Paradise Valley, AZ
    Quote Originally Posted by chris@penskeaudi View Post
    Are you running the stock plugs? Also, GIAC recommended the seimen 380cc injectors. do you think the tt225 injectors work better? thx.
    Oct 16 2006
    Naperville
    why is APR 1+ 600 bucks???? i got my flash for 500 for 2 programs.
    Senior Member Two Rings BangHatch's Avatar
    Feb 29 2008
    ToronCouver
    Could someone/anyone explain that? With the GIAC the display is "inaccurate" but with APR it is? How so?
    Veteran Member Three Rings A4Avant02's Avatar
    Feb 05 2008
    '02 A4 Avant, '74 Triumph TR 6
    Folsom, Cal
    Take a look at this thread for some info on adjustments to the mpg display.....
    http://www.audizine.com/forum/showthread.php?t=200418
    Sep 13 2007
    Quebec, Canada
    audipotential, I think there is a climate difference, unless you live in northern Ontario
    Anyway, I guess a lot has to do with your driving style. I have a wife and two children so 95% of my driving is relatively conservative. It's that 5% I'm alone where I mash it at times. It's probably not enough for colder plugs, and I was running them in winter too (silly me).
    Now that I'm back to stock plugs, I'll have to wait for hot summer days to see if I still have misfires. In the current setup, I feel the engine is a bit rough when under full load on the highway, but I have no misfire codes so it's probably normal.
    I have the Siemens 380cc injectors by the way.
    Also, I highly doubt that any program using bigger injectors would "not screw up the MPG display" as this is computed using injector opening. Bigger injectors = more fuel belched during the same period. The MPG computation doesn't know about it.
    Follow the indicated link. I did it and it is closer to reality, although not quite there.
    May 22 2007
    Nazareth, PA
    I'm running the Genesis 380cc injectors with BKR7E-IX plugs and under accelleration I'll notice a slight rumbling when I hit like 2800-3600RPM's. Also I seem to have more power/torque if I don't got WOT until I get the RPM's to like 2600 (is this because I need to wait for boost to build up or something).
    I'm going to try and just put the stock plugs in at the factory gap and see if there's a change. There's always that fear in the back of my mind though that there's a slight boost/vac leak or my N75 valve shit the bed though.
    Current
    Apr 16 2008
    Utah
    I've got APR 1+ spot on with my MPG display. They must have put something into the ECU software to correct it.
    With GIAC FX, i was on the max setting (115) and i was still off by about 3mpg. For example, if my display said i was getting 25 mpg, i was actually getting 22 mpg.
    After having APR 1+ for a few weeks, I had to back the setting down to 105, and now it is spot on.
    Don't ask me how APR did it, but they did.
    Sep 20 2004
    Paradise Valley, AZ
    i think im gonna try the stock plugs again. does anyone know what the part number is for the stock plugs? lol, its been so long since my car ran stock plugs.
    Oct 10 2007
    B6 1.8T USP
    Quote Originally Posted by manguyen View Post
    $600 is flash + installing injectors and DV Valve. Not sure whether I can get 2 programs for 500. I guess I can ask for it, since even ECS tuning is selling 2 programs at 500 bucks. Thankx for the information.
    by the way, do I need a special program or part to switch programs back and forth using cruise controller if I have more than 2 programs?
    Thank you,
    Feb 29 2008
    ToronCouver
    Quote Originally Posted by A4Avant02 View Post
    Thanks! So with GIAC it is fixable...
    But the with the APR program, there's no need to adjust anything? It "knows" youre running a bigger injector?
    Buncha motorcycles
    Memphis, TN
    1+ really needs some supporting mods like intercooler, exhaust, TIP and at some point clutch... i did logs right after i got it and my IATs easily pushed into the 160 degress range, now with my intercooler they stay 10 degrees above ambient....
    I love my APR program and it was $500... i got my injectors from manguyen in two days at a lot less than what APR/GIAC was wanting for them!
    APR Stage 2/AWE Intake
    Veteran Member Three Rings oregonaudi's Avatar
    Oct 06 2006
    I run the mods in my sig and had significant pinging with every plug known to man... even QuattroRocket's Porsche plugs.
    I definitely feel that GIAC is more aggressive than APR (could just be "spikier"), but I have articulated my fair share of pinging warnings. BUT, I live in the PNW, and we are known to have shitty gas... so I'm sure that had a little something to do with it.
    Modded 2003 1.8TQM - GONE
    NOW - 2007 Ibis S-Line Avant 6MT
    RAI KOR-GT ** S3 Injectors ** 034 TIP/Custom CAI ** Uni Tune ** APR HPFP ** Racetech FMIC ** 034 HFC W/ Labree Downpipe and Custom Exhaust ** BSH Stage 2 PCV Fix ** Southbend Stage 3 Daily ** DTM 25th S4 Front W/ DTM CF Splitter ** Painted Vorsteiner Hood ** iForged DTMs W/White Lips
