Results 1 to 7 of 7
    Apr 19 2008
    ct
    help s4 boost problem
    i have a 2001 s4 i just bought the boost gauge goes to 5-6 pounds sometimes the car goes to 20 pounds but most of the time 5-6 i just switched the n75 valve still same problem the car has hyperboost diverter valves can someone please help if they had the same problem
    Active Member Four Rings RogueStatus's Avatar
    Nov 13 2007
    B5 S4 Avant
    Boston
    Re: help s4 boost problem
    pressure test for leaks. TBB mainly.
    Veteran Member Three Rings FlaS4's Avatar
    May 05 2008
    2000 B5 S4
    Miami, FL
    Your boost hoses may be expanding when boost is high and you are losing pressure. Stock hoses and diverter valves on the B5 can't take the added boost produced by an ECU upgrade.
    Dec 06 2007
    Calgary, AB, Canada
    ^^^I highly doubt that is the reason for him going into soft limp mode.
    Are your dv's splitters or true dv's?
    Do a boost leak test. Log block 115 using VAG com.
    Senior Member Two Rings Luca12's Avatar
    Sep 16 2007
    00 b5 s4
    jacksonville, fl
    I have the same problem... i think.
    Veteran Member Three Rings Paulyworld1432's Avatar
    Dec 07 2007
    Houston, TX
    Hey Jerbel, noob question what are splitters?
    Apr 18 2007
    b5 s4 nogaro , 1991 bmw 325is 5spd
    florida,wellington & hollywood
    ^ 50% boost into atmosphere ( blow off valve) 50% into recirculation :)
