Results 1 to 10 of 10
    Active Member Two Rings sotirakis's Avatar
    Feb 04 2008
    philadelphia
    please help with avic navigation
    please help me guys. i have my avic installed in my 04 s4 and i can't get the nav to work. it's picking up 3 satellites which sucks but at least it's working. everything works except the nav. i even hooked up the speed sensor wire. i drive around town and it doesn't move at all. first it was staying put in new york (i live in philadelphia) until i changed the location to my house. but still, nothing happens when i'm driving around. what's the deal? oh, and i thought it might have been bad reception so i put the antenna on the dash to test it out but still the same thing.
    Veteran Member Three Rings likewater's Avatar
    Sep 18 2006
    2012 Honda Pilot, 2005 F150 FX4
    So Cal
    Re: please help with avic navigation
    For the guys that will really know how to help you, go to > http://avic411.com/ and check in the forums.
    Current - 2011 B8 S4 DSG Presitge - APR Stg 1 | RS4 Grill | Magnaflow Xpipe and Mufflers | K&N | Apikol Rear Diff Mount (Race)| H&R OE Sports | Avant Garde M310 19X9.5 ET 40
    SOLD - 2005 B6 S4 6MT with many mods.
    Registered Member Two Rings scabdc's Avatar
    Feb 05 2008
    06 A6 4.2 06 E55 AMG
    MD
    Quote Originally Posted by sotirakis View Post
    I had the same issue. You need to move your GPS antenna (in my case I had to move it closer to the center of the car) and this should solve it. Did for me.
    Established Member Two Rings notachance's Avatar
    Sep 08 2007
    2005 B6 Audi S4
    North Jersey
    Not sure the answer to your question but I have a question. For those that have the D3 and the bose sound system do you have any problems with it or does it hook up fine. And is there anything i need to make it work ?
    Sep 18 2006
    So Cal
    It works perfectly with the Bose and actually makes it sound much better - really wakes it up.
    Feb 04 2008
    philadelphia
    i'll try moving the antenna to the center, but i don't know how that's gonna work cause it's resting on my dash now.
    Veteran Member Three Rings UBERS4's Avatar
    Sep 18 2006
    2005 Arctic White S4
    Earth
    My antenna is located in the fuse box as there is a little cubby hole which is a perfect fit for it. Once the unit gets situated when driving, my navi works fine. My biggest problem has come from a grounding issue that has caused a strange, low pitched noice
    '05 Audi S4
    |Europrojektz|
    Midwest Director
    Sponsored by-
    |Dunlop Tires|DPE Wheels|Oettinger|Rotora|Tein|GIAC|Supreme Power|
    Feb 04 2008
    philadelphia
    had it in the fuse box. seemed like a perfect place for it but it wasn't working. could there be a problem with my antenna? i've even held it out the window and nothing
    Veteran Member Four Rings b00st's Avatar
    Oct 17 2004
    04 B6 S4, 08 RX350
    St Charles, IL
    Quote Originally Posted by likewater View Post
    10x on that.
    The RIDES:
    2015 M3 - BM3 stage 2
    2011 335 Msport - FBO + E85 sold
    04 S4 - JHM 93oct Tune | JHM Piggies | FI CB | JHM Intake Spacers | JHM Stage 4 Clutch | JHM LWFW | JHM LW Rotors | Snub | K&N | 034 Density Motor Mounts |SOLD
    99.5 A4 PC16 K04 - SOLD-
    http://www.cardomain.com/ride/2404758
    AMA Member
    JHMFTW!!
    Oct 17 2004
    04 B6 S4, 08 RX350
    St Charles, IL
    your best bet is avic411.com or time to take it into a shop who knows how to install it.
    The RIDES:
    AMA Member
    JHMFTW!!
