Results 1 to 10 of 10
    Aug 04 2007
    92 Jetta,2001 A4 2.8
    Cranston, RI/MA
    car sliding out of gear?
    Well today when i had my sisters little puppy in my car i had to break pretty hard and he hit the shiftnob and knocked it out of 4th..i was curious and when i got onto the high way i am able to pull it out of any gear(it doesnt take much effort) is this normal??
    ~Bo
    92 Jetta- daily-slammed,TP...to much to list
    01 2.8- project
    Feb 02 2008
    17 pure white vr6 Touareg sport tech
    Re: car sliding out of gear?
    I believe this is normal.. Somebody correct me if I am wrong, but as long as the tranny is not under load, ie pushing the gas pedal. You should be able to slip the tranny out of gear at speed. Just don't try to put it back into gear with out first engaging the clutch. ouch! Either way its probably not good for the transmission so I wouldn't make it a habit.
    Aug 04 2007
    Cranston, RI/MA
    once i noticed the puppy go forward i promply engaged the clutch and i wouldnt even think about changing gear without using the clutch i was just confused when it happend and curious
    ~Bo
    01 2.8- project
    Veteran Member Four Rings Burntaudi's Avatar
    Sold:1997 Audi A4
    Maplewood, Minnesota
    Normal.
    Alex
    Sold 97 Audi A4 Turbo Quattro Manual
    KO4/GIAC PC-16/GHL Exhaust/EVO FMIC/ Southbend Clutch/JHM Short Shifter & Linkage/Shifter Bushing/Koni Coilovers/Neuspeed Sways/17" OZ Superellegras/Ecode Headlights/VVME Hids
    Current ride 03 Tahoe Z71
    Dec 05 2007
    CA LA
    uummm i car upshift and down shift with ot the clutch. once you know the car you can start in 1st with the clutch then up and down shift it with no clutch you just got to rev match
    Senior Member Two Rings URSquattro's Avatar
    Jan 23 2007
    Waterwoooo, Ontario, Canada
    hard on synchro's regardless of rev matching, A4s or any other cars on the street dont have straight cut gears so don't do it.
    '98 Audi A4 1.8TQM- APR 1bar,APR cat-back, ECS coil-overs, ECS RA4 steel FW clutch kit, 320MM Brembo BBK,RS6 18s, B&M SSK, Recaro S4 Front seats, HIDizzles, some gauges? always need more..
    'K4 GSXR600-with goodies-SOLD
    '94 S4 with goodies-RAPED/sold
    Veteran Member Four Rings njm23's Avatar
    Feb 28 2007
    04 a4 USP ; ATS
    yeah, unless your drivin an 18 wheeler, don't do it.
    Veteran Member Four Rings dualaudi's Avatar
    Dec 13 2004
    allroad 2.7t
    san diego
    happens in 2nd gear sometimes if i'm careless... anyone know of a way to stiffen our shifters? (short shifter maybe?)
    (sold) 1999.5tqm :: gtrs, atp 3"TP, tweaked mika t3/t4 8k, adj. fpr, forge 004, MBC, neuspeed: catback exhaust, E-bay special FMIC! 9"x28"x2.75" - SOLD
    https://www.instagram.com/dualaudi/
    Senior Member Two Rings a4_1.8t_01's Avatar
    Feb 24 2008
    A4 1.8TQM 01
    I accidently popped it out once normal i guess. Ir your mounts are really bad though it then its worse I noticed.
    Unitronic tuned. love it.
    Need any services done in NYC area please PM me. I will diagnose and fix your car. Also do clutch replacements, Timing-belt services, Turbo upgrade/installation, Fluid changes, boost leaks and pretty much anything.
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    Quote Originally Posted by URSquattro View Post
    It makes no difference if it's a straight cut gear or not. The difference between a tractor trailer and an automotive trans is in the synchros. The helical cut gears we have and the straight cut gears they have only supply the gear ratio. The Dog Teeth on the gear are what engages the gear and has the power transfer through it.
    Pulling a trans out of gear while not under load, I.E. accel or decel, won't damage the trans. An immeasurable amount more wear, maybe.
    Matching the gears, rev matching, whatever you want to call it is what the synchro does in the trans. Shifting without the clutch, as long as it's smooth and not grinding, isn't doing that much, if any, damage to the trans. Yes, using the clutch would make it easier, and thus less wear in the trans.
    Anyways, back to the OP. That is normal, don't worry about it. As long as you're cruising or under a slight decel, pulling it out of gear should take the same amount of effort as when you use the clutch.
    This varies some based on what type of blocking rings are in the trans. Our tranny's have 75W-90 in them, so it won't make a difference. A trans that uses ATF, has different blocking rings(actual friction material instead of brass) in it, and it would be more difficult (typically) to shift through the gears w/o the clutch. Going from a gear to neutral, may not be more difficult, depends on the manuacturer.
