Page 1 of 3 123 LastLast
Results 1 to 40 of 103
    Saint Cloud, Fl
    Revo Dyno = Failure W/Video
    I had the car dyno'd today. Complete failure !
    203 AWHP
    239 TQ
    SETUP
    • GT28R
    • 440CC INJECTORS
    • TESTPIPE
    • RACETEC FMIC
    • THERMAL RACE EXHAUST
    • CARBONIO INTAKE
    • VR6 MAF
    • REVO STAGE 3 SOFTWARE
    instagram ------------> low_enforcement
    Dec 06 2007
    Re: Untuned REVO Software = FAIL
    if thats the case i might be able to keep up! u should get about 300whp no??
    -Kirk
    BetaAlphaTau Member #58
    Veteran Member Four Rings Tgr_Clw's Avatar
    Jul 20 2005
    2003 Audi A4 1.8TQM
    Toronto, Canada
    Re: Revo Dyno = Failure
    Ummm. Yeah, something's definitely not right. I made 208whp/260wtq on a DynoJet with my setup.
    Appearance: OEM+
    Interior: B6 S4 Recaro Seats
    Performance: MTM Stage 3 / Milltek Exhaust+Milltek HFC / JJ TIP / ASP FMIC / SB FE SS
    Suspension: Vogtland Coilovers / HSport S4 Sways
    Braking: Stoptech 332 BBK
    Wheels/Tires: BBS CH 18x8.5, ET35 / GY Eagle F1 GSD3 235/40/18
    Saint Cloud, Fl
    Re: Revo Dyno = Failure W/Video
    what's your setup ?
    In Limbo Four Rings
    Sep 27 2006
    2005 Audi B6 1.8t Ultrasport
    New Jersey
    wow low 200's is that expected of a gtrs?!?!?
    Saint Cloud, Fl
    no
    Veteran Member Four Rings RLB6's Avatar
    Sep 20 2006
    '05 MV Agusta F4-1000
    MD
    Oh shit! Somethings not right. That GT28R should put down more power than that. Atleast in the 240 awhp range. Which REVO file do you have? 440cc or for the 550cc? I ask because you're using a VR6 MAF with 440cc injectors.
    Current: '23 etron-GT | Prestige
    Previous: S5 | Prestige
    Feb 17 2005
    Sarasota, FL
    Ouch! I feel ya unfortunately!
    Saint Cloud, Fl
    550cc file, my new injectors are in the mail, I still expected more than 200AWHP
    Saint Cloud, Fl
    Quote Originally Posted by A4ringedONE8T View Post
    So how can I tune this software ? Please tell me that I have a couple options. For $700.00 I better be able to tune this shit !
    Feb 17 2005
    Sarasota, FL
    Thats on a dynojet too! You need to come to Eurotreffen Friday!!!
    Sep 20 2006
    MD
    Quote Originally Posted by 7speed View Post
    At what boost was this and was it holding the whole way through?
    Sep 20 2006
    MD
    You need an SPS 3 for starters.
    Saint Cloud, Fl
    I don't understand it held 21lbs all the way to 7k. Where is all that boost going ?
    Veteran Member Four Rings A4 TSCHUSS's Avatar
    Apr 24 2005
    E55 AMG, CTS-V
    Jacksonville, Florida
    first off do you have a GTRS as in a GT2860r or a GT28R as in the turbo that comes in AWE's kit? Next what settings were you on for boost and timing and what fuel?
    ~David~
    Gone but not forgotten 437whp on 93 octane and washer fluid injection A4 12.2 best ET, 12.3@119 best overall
    480whp/500wtq E55 AMG 11.6@120
    CTS-V 9.6@148
    Apr 24 2005
    E55 AMG, CTS-V
    Do you have vag com? If so do a log and check 003, 020 and 031 and for the heck of it do 115 too even though you said you are holding 21psi. Better be careful and get this fixed or you are gonna have your Beta Alpa Tau membership revoked!
    ~David~
    CTS-V 9.6@148
    Saint Cloud, Fl
    Im screwed ! I need to get VAG and SPS 3.
    - The turbo is a GT28R
    Feb 17 2005
    Sarasota, FL
    Ive got an SPS Ill sell you if you want it
    Apr 24 2005
    E55 AMG, CTS-V
    o so you will only probably see 250 max or so for hp with a GT28r anyway so that isnt as bad. Do you have the AWE kit then switched software? And what fuel were you running and then im guessing you just have the software on the basic settings that they send it to you on?
    ~David~
    CTS-V 9.6@148
    Jul 20 2005
    2003 Audi A4 1.8TQM
    Toronto, Canada
    what's your setup ?
    K04-15 with all the trimmings.
    Appearance: OEM+
    Saint Cloud, Fl
    Quote Originally Posted by A4 TSCHUSS View Post
    o so you will only probably see 230 or so for hp with a GT28r anyway so that isnt as bad. Do you have the AWE kit then switched software?
    - Yah I have the AWE Kit and switched to REVO. I figured I would have the ability to tune, and option to use it with a bigger turbo in the future.
    Apr 24 2005
    E55 AMG, CTS-V
    I was off on the power, I did a quick search and found that with the AWE kit and their software with 100 octane on a mustang dyno a member did 263whp 254tq and on pump gas (93) 233whp 243tq think this was on a dyno dynamics machine.
    ~David~
    CTS-V 9.6@148
    Apr 24 2005
    E55 AMG, CTS-V
    I personally think you have no business running a 3" maf with that small turbo and with that software and injectors, that could be a problem first off.
    ~David~
    CTS-V 9.6@148
    Saint Cloud, Fl
    so you think the 3" MAF could be part of the problem ? I tought that the increased air flow would help ?
    Apr 24 2005
    E55 AMG, CTS-V
    it could be screwing up your air/fuel ratio. That is why I told you to log block 031 but you don't have vag com. Did you dyno on race or pump gas as well, please tell me pump? That dyno is still heart breaking though.
    ~David~
    CTS-V 9.6@148
    Saint Cloud, Fl
    It was on pump gas. The tech told me that my car was running lean. Something like 12.5 during the run
    Apr 24 2005
    E55 AMG, CTS-V
    I don't know if you have seen this thread a long time back but this is where I was getting info from on the 28r kit. Some pics don't work but there is some info there. AWE GT28r dyno
    ~David~
    CTS-V 9.6@148
    Apr 24 2005
    E55 AMG, CTS-V
    12.5 is ok, a little lean but still fine
    ~David~
    CTS-V 9.6@148
    Feb 17 2005
    Sarasota, FL
    3" MAF with 440's is most definitely causing the car to lean out, which is pulling all your timing
    Feb 17 2005
    Sarasota, FL
    12-12.5 I would say is perfect for under 300whp
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    A GT28r on pump gas is going to be lucky to make 225-235whp. Dont know why people say 300whp on the small GT28r. It is the turbo that APR/AWE/PES use and they all claim around 270-280 CHP.
    The B6 is not going to run lean at WOT because the car sets at target AFR which it will try its best to hit. The B6 doesn't run a wide band 02 for nothing.
    BTW the Revo BT tune uses a stock maf not a 3", that is going to throw off the load and timing. Also if you just get the BT tune you better talk to the person you got it from because after having a talk with David at Eurocode the BT tune has been for 550cc injectors for a few years now.
    Saint Cloud, Fl
    Yah Ill be getting a set of 550cc injectors here pretty soon. I honestly thought that I would be putting down atleast 250AWHP. I'm so dissappointed in the output of the kit.
    Dec 03 2005
    2 pedals 1FG
    connecticut
    How so? The APR 3+ uses a full GT28RS
    -Doug
    Apr 24 2005
    E55 AMG, CTS-V
    I already deleted my post I looked through the posts again and must have missed it.
    ~David~
    CTS-V 9.6@148
    Jun 30 2007
    Raleigh, NC
    wow -- good thing you're quick david, i was about to make all kinds of embarrassing comments after a couple quotes lol
    12.5 best ET -- 113 best trap
    The Awesome™
    BetaAlphaTau Member #42
    Forum Moderator Four Rings actlsub9's Avatar
    Jun 13 2005
    Audi
    Your using a larger MAF and smaller injectors then what your file was designed for, bad combo. You should probably sort that out first and see how it runs after that. Your fuel trim might be around +50%
    Greg - Moderator
    WWW.ACTLSUB9.COM
    Jul 20 2005
    2003 Audi A4 1.8TQM
    Toronto, Canada
    Mike is talking about the APR Stage 3 kit for the B5 A4. That kit uses the GT28r.
    Appearance: OEM+
    Jul 20 2005
    2003 Audi A4 1.8TQM
    Toronto, Canada
    APR stage 3+ kit puts out 245whp on a dyno dynamics. I don't see the AWE GT28r kit making 233whp/243wtq on a DD.
    Appearance: OEM+
    Saint Cloud, Fl
    Ill be switching back to my stock MAF
    Veteran Member Three Rings Carlitos's Avatar
    Sep 17 2006
    B6 A4 1.8T
    San Juan, PR
    let us know how everything works out!!
    FlexTuning
    Amulet 1.8TM
    BAT#46
