Results 1 to 8 of 8
    Veteran Member Three Rings windyctyaudi's Avatar
    Jul 30 2007
    '12 S4 prestige DSG
    Chicago
    Oil in spark plug holes
    I did my compression test today and everything was fine except when i took out my coil packs there was oil in each of my holes for the spark plugs it looks like my valve gasket is leaking??? i think?? could this be causing my car to smoke white from the exhaust? I know white smoke is coolant and the smoke even smells lilke coolant but my coolant and oil are fine. here are some pics of my spark plugs that have less then 10k on them and look how much oil and dirty they are. any thoughts. My only other though are my seals are goin bad on my turbo and that is whats causing it to smoke. I only have 51k on the car.
    Dec 06 2007
    Re: Oil in spark plug holes
    valve cover gasket needs to be changed!
    -Kirk
    BetaAlphaTau Member #58
    Jul 30 2007
    '12 S4 prestige DSG
    Chicago
    How hard are they to replace? I thought i seen a DIY on here somewhere but i cant find it now.
    Dec 06 2007
    ^^easy check Audiworld.com! it's loke a few nuts and then it's off i think the part is like $20.00!
    -Kirk
    Mar 07 2004
    '14 Q5 TDI Prestige & '14 Q5 TDI Premium Plus
    Charleston, W.V.
    Just remove the coilpacks, loosen a few nuts and move a few hoses. Make sure you clean the cover well and on the gasket you'll see a few places that are wider than others (on the corners I think) where you can put some RTV sealant.
    Veteran Member Four Rings jrau13's Avatar
    Mar 12 2006
    02 Mercedes ML, 04 Avant 1.8t
    Costa Mesa
    Got my valve cover gasket from MJM for under $20, fast shipping!
    Still haven't done mine yet though
    I'll keep my money,
    My Guns, My Freedom,
    & you can keep the CHANGE
    Registered Member Two Rings
    Dec 06 2006
    minnesota
    Yup^^^
    Be thankful you have the car you do. The same job on my Lincoln LS was impossible to get at...therefore cost around $450 at the dealership. Our cars are nice for this kind of replacement.
    Jul 30 2007
    '12 S4 prestige DSG
    Chicago
    Thanks I just ordered mine. Can i just go t auto zone and pick up that regular liquid gasket stuff that i have to use with it or do i have to you a special one.
