Results 1 to 16 of 16
    Senior Member Three Rings oakenfolde's Avatar
    Jul 24 2007
    Las Vegas
    what size spacers to get
    http://www.ecstuning.com/stage/edpd/...ory=Suspension
    ok so i want to get 8mm spacers in the rear, the H&R's for aftermarket wheels doesnt come with different bolts. do i need them, and which ones do i need?
    Jul 24 2007
    Las Vegas
    Re: what size spacers to get
    Bump for suggestions
    Veteran Member Four Rings Phrost's Avatar
    Jan 24 2007
    1977 VW Type 2 Westfalia
    Wisconsin
    What offset are your 19x8.5 wheels?
    Ignorance is bliss.
    Jul 24 2007
    Las Vegas
    I believe they are +38..
    Jul 24 2007
    Las Vegas
    bed time bump
    Registered Member Two Rings
    Apr 03 2008
    Toronto, Canada
    if you have 8.5" wheels with ET38 then you are already sitting flush in the front and won't need any spacers; however you could add 5-8mm in the rears.
    Jul 24 2007
    Las Vegas
    yea understandable.
    i just want to have a low, wide look
    ok say im going to get 8mm H&R spacers.. do i need to buy extended bolts or anything? which kind?
    Veteran Member Three Rings tribe's Avatar
    Feb 15 2008
    lotsa tools
    Vienna, VA
    The kind of bolt depends on the wheels. OEM wheels use "ball seat" . The OEM lugs are 28mm long so add to that the 8mm or whatever size spacers you get
    '12 Phantom Black S4 P+ S-Tronic- Navi - 3M Clear Bra - KW Springs - REVO Stage I - AWE S-Flo Intake - Hotchkis sways (still in the box)
    Jul 24 2007
    Las Vegas
    so ill need 36mm lugs. hmm
    Jul 24 2007
    Las Vegas
    im confused they dont have 36mm and what is 14x1??
    closest i see is H&R ball seat 14x1.5x35mm wheel bolt
    Veteran Member Four Rings LAS's Avatar
    Feb 12 2004
    HI.
    after you get the wheels, suspension and alignment completed, measure the available space then you can figure it out from there.
    btw, sounds like you have aftermarket wheels, 'most likely' you'll need cone/conical/tapered type bolts.
    Jul 24 2007
    Las Vegas
    i do have aftermarket wheels
    Feb 12 2004
    HI.
    http://www.tirerack.com/wheels/tech/...jsp?techid=102
    http://www.tirerack.com/wheels/tech/...jsp?techid=107
    we use 14mm x 1.5mm diameter bolts. if no 36 +/- 1 or 2mm is safe, but better to go longer, but not too long.
    Jul 24 2007
    Las Vegas
    ok i appreciate ur help..
    so if im doing 8mm.. the closest to that is 35mm... which is shorter. will i be safe?
    Feb 15 2008
    lotsa tools
    Vienna, VA
    I would go with 38mm. If you change your mind and want to get 10mm spacers you don't have to buy new lugs.
    Jul 24 2007
    Las Vegas
    ahh.. i might as well do that then lol
