Results 1 to 21 of 21
    Senior Member Two Rings acbrooks2's Avatar
    Oct 10 2007
    2006 2.0T Quattro
    California
    Air Filter - necessary to change?
    I am having the Neuspeed exhaust system installed this week. Is it necessary to change the air filter to a K&N or is the stock ok? I am not ready to put in the Carbonio yet.
    2006 A4 2.0T Quattro 6-Speed, H&R Street Performance Coilovers, ECS Stealth Black Grille & Panel, De-badged, RS4 mirrors, Trunk Spoiler, Red LED Interior, Lumar Tint - 50% front 35% back, H&R Trak Spacers - 10/12mm f/r, Neuspeed Short Shifter, Neuspeed Snub Mount, REVO Stage 1, Neuspeed 70mm Cat-Back Exhaust, K&N Air Filter, Hoen Xenonmatch Fogs, PIAA City and DRLs, VAG-COM Seat Belt Chime, RotW lights & Door/Window Lock, color-coded sidemarkers, smoke side blinkers, Denison iPod to RNSe
    Senior Member Three Rings rlopez's Avatar
    Nov 09 2006
    Porche, AudiA42.0T (6M), Sport Suspension
    Denver Colorado
    Re: Air Filter - necessary to change?
    Stock is fine. There are no dynos to definitively show the gains on Carbonio but a lot of theoretical numbers. Personally, I don't think it's worth the expense of the gains...if any
    RLo
    Formula 1 window tint Premier Series, RS4 Reps, PSS9s, Velocity Snub Mount
    Oct 10 2007
    2006 2.0T Quattro
    California
    Thanks, that is what I thought. I have also heard the stock intake on the B7 is actually very good and well made.
    Established Member Two Rings themig90's Avatar
    Feb 12 2008
    2006 A4 2007 A8
    West Palm Beach, Fl
    Get a heat shield and a K&N cone filter, it will set you back about 130$ and you get cooler air plus that sweet sucking noise and the pshhhhh sound. I have it and you can deffinetly notice a little thorttle response difference.
    Veteran Member Four Rings agkellyboy's Avatar
    Feb 27 2007
    2010 S4
    Philly 2 Bmore
    Quote Originally Posted by themig90 View Post
    Less than $30 if you have some extra aluminum and heat reflecting material around. I recently took this setup up out of my car. While the noise was great and I would definitely say there was a shift in power (not necessarily a great increase in hp), my mileage has been crap and I wasn't going to take the chance of dealer issues in the future.
    FS - Dolphin B7 A4 Ti 2.0T MT6 Quattro Project 400R
    Established Member Two Rings smcgann's Avatar
    Apr 03 2008
    2007 A4 Quattro
    Macon GA
    I just put a K&N drop in filter yesterday (my first mod since purchase last Friday), and there is a noticeable (small as expected) differenced, reduced lag and stronger pull. If you put the two filters side by side you will see why. The factory filter is 3 or 4 inches deep made of the usual dense paper, where as the K&N is something like an 1.5 inch deep. I haven't noticed a sound increase as I hear happens but I also haven't really hammered it yet. Really worth the $50.
    Nov 01 2007
    B7 A4 2.0TQT
    PA
    where did you get your k&n?
    Apr 03 2008
    2007 A4 Quattro
    Macon GA
    Established Member Two Rings A4B7GA's Avatar
    Apr 20 2007
    A4 B7 5.5, 05 Exploder
    Bal Harbour, FL
    Amazon was $43 with free shipping.
    my mod list...really boring $!ht + APR
    Feb 12 2008
    2006 A4 2007 A8
    West Palm Beach, Fl
    Quote Originally Posted by smcgann View Post
    Im not talking about a drop in filter I am talking about completelty removing your stock intake and swapping it with a K&N cone filter which you can buy on amazon for 37$ just search for K&N 3 inch cone filter
    Apr 03 2008
    2007 A4 Quattro
    Macon GA
    My comment was not directed to you, but personally I doubt rigging a cone filter that is going to pull more warm under hood air is going to be much of an advantage. The stock box draws in cool outside air in a "ram air" type set up.
    Established Member Two Rings MrRevesz's Avatar
    Oct 08 2007
    2012 Audi Q7 TDI
    Mid-Coast Maine
    +1, I've heard way too many stories about the decrease in power from cones unless done absolutely correct (out of the engine bay into a cool area), but then that also comes with the caution of sucking up unwanted water....
    I have the K&N Drop in, it's all I needed. The stock box is great, + with the more flowing filter, I can't say I've noticed a vast if at all increase, but it's good to know it's not getting "suffocated" anymore
    Jul 04 2007
    Anchorage, AK / Chicago, IL
    I used to think intakes did nothing. I had a k&n drop in before then switched to a cone filter. BIG difference. I havent dyno'd it or anything but it feels a lot faster, i wouldnt say i gained a lot of power, its just that the delivery is a lot smoother.
    Veteran Member Four Rings RedS-line's Avatar
    Mar 19 2008
    2019 S5, 1990 944 S2
    anyone know the service life of the stock air filter? how long before you throw it out?
    2019 S5 BO.SS
    1990 944S2 Cabriolet
    2009 R8 6 Volt :)
    Nov 01 2007
    B7 A4 2.0TQT
    PA
    can somebody post a pic of their filter in their engine bay? i want to make sure I'm buying the right one
    Feb 12 2008
    2006 A4 2007 A8
    West Palm Beach, Fl
    Actually with a heat shield you are sucking in cooler air than you would with the stock box because you are still sucking fresh air from the front...
    Oct 10 2007
    2006 2.0T Quattro
    California
    I have heard that K&N's can mess up the MAF sensor on VAG cars - any truth to this?
    Veteran Member Four Rings whitevdub's Avatar
    May 10 2007
    Long island
    i've never heard of anything like that happening before...has anyone heard of BMC air filters though and do they make them for our B7's/ i heard you can really hear and notice the difference and it is a drop in filter
    Oct 10 2007
    2006 2.0T Quattro
    California
    Apparantly it is due to excess oil in K&N filters.
    Senior Member Three Rings BLACKa4QUAT's Avatar
    Mar 26 2008
    union city, ca/fort worth, tx
    i like my afe filter, was ~42$ when i got it, its oil-less and washable.
    nothing too noticeable with the filter, a little more turbo noise, and its just a drop-in
    http://www.afeproducts.com/gendesc.php?partno=31-10118
    2006 A4 2.0Tqm, S-line, tech, FH-P8000BT, 10" sub, 800 watt,
    VAG-COM mods (remote windows, no chime), revo stg 1 tweaked
    AWE pedals, HRS4 DTMs/Eagle GT, VMR TP
    193.7 awhp/232 ft/lb/91 oct pre-TP
    16MAR09DSWHTAW
    Veteran Member Four Rings supamannn99's Avatar
    Nov 15 2007
    Orange County, SoCal
    my butt-dyno tells me that i gained 100whp after installing the EVOMS[O_O]
    http://kalecoauto.com/index.php?main...products_id=41
    lawl @ the reviews
