Results 1 to 11 of 11
    Senior Member Two Rings NoUDont's Avatar
    May 16 2007
    South Florida
    Car in Shop, need help!
    Took my 02 1.8T CVT to the shop.
    Problem: Vibration when accelerating. No vibration when I lift foot off the gas, vibrates again when I go to accelerate, shakes pretty bad. Feels like something is loose, if you know what i mean.
    Shop says the pump in the tranny going bad, car does take time to get into Drive when at a stop sign or going from Park to Drive or Reverse to Drive.
    They want me to get a used tranny, no price quote yet. Any feedback would be great.
    And how long can I drive on it til bust city?
    Thanks in advance.
    Registered Member Three Rings ChriS4's Avatar
    Nov 09 2007
    A red one. I hate red.
    Track Whore, CA
    Re: Car in Shop, need help!
    i'm not really familiar with auto trannies, but it almost sounds like you have either a loose wheel or an axel. I had a front wheel that was coming loose on my S4, and just cruising or decelerating there was nothing, but under load the car (mostly noticable in the steering wheel), would vibrate a ton.
    '00 B5S4 - Sold
    '95 Civic EJ1 - Stolen
    Good USA
    May 16 2007
    South Florida
    Thanks Chris4. Did you have the wheels removed and then put back on or could you just tighten it yourself?
    Dec 06 2007
    tranny mounts!
    -Kirk
    BetaAlphaTau Member #58
    May 16 2007
    South Florida
    Quote Originally Posted by AudiA4Turbo22 View Post
    tranny mounts!
    Is there a way to check if they are bad or do you have to tell them its the tranny mounts?
    Dec 06 2007
    does ur shifter clunk when u move from park into r,n,d???? if it clunks and the car vibrates then ur tranny or motor mounts are gone
    -Kirk
    May 16 2007
    South Florida
    That is whats weird. No clunking when shifting into drive. No vibrations when revving the engine in Park.
    Dec 06 2007
    motor mounts are shot!that causes tuns of vibrations!
    -Kirk
    Senior Member Two Rings has6's Avatar
    Aug 06 2007
    '21 SQ5 | '20 XC40
    Brooklyn, NY
    i know this sounds stupid but make sure your wheels are true and are sitting flush against the hub. I had a missing lug nut that was causing tons of vibrations because the wheel was moving left and right causing vibrations.
    remember...
    vibrations in the steering wheel are linked to your front wheels while vibrations in your seat are most likely caused by the rear tires
    Mar 07 2004
    '14 Q5 TDI Prestige & '14 Q5 TDI Premium Plus
    Charleston, W.V.
    Is it coming from the tranny or could it be a coilpack? I had a problem with a coilpack once that would only happen when the engine was above 4400 rpm's and accelerating.
    May 16 2007
    South Florida
    would a coilpack throw a code on the dash? man now u have me thinking...would that cause those violent vibrations though?
