Results 1 to 4 of 4
    Registered Member Two Rings
    Apr 05 2008
    1996 Audi A4 2.8 Quattro
    Engine Check Light - Diagnostic
    The Engine Check light came on, on my A4 a few days ago. It's on solid, not flashing.
    Canadian Tire quoted $108 to pull the code.
    What alternates do I have?
    It appears I could buy an OBD2 (I think) Diagnostic Tool for roughly the same price, but how does this differ from a "VAG-COM"?
    Additionally, from what I've been reading it seems possible to purchase a cable, hook it up to my laptop, and diagnose the car via the laptop?
    Dec 01 2007
    Markham, Ontario
    Re: Engine Check Light - Diagnostic
    check with independant tuning if you are in toronto
    it won't cost $108 and they can fix ur problem as well
    Veteran Member Four Rings zrowcool's Avatar
    Nov 09 2006
    2000 B5 A4 Quattro / 00 F-150 XLT S/C
    Bronx, NY
    the obd2 is a code reader for any car that is obd2 compliant 1996+. It will give you a code that you can lookup and see. Vag-com is connected to a computer and although it can be more pricey than an obd2, it can be used to record logs, recode certain channels of your ecu, as well as check codes and clear them. only thing is its tailored to vag vehicles where the obd2 is universal.
    2000 A4 1.8tq
    Running only on Amsoil fluids.
    Amsoil products at wholesale pricing... Ask me how!
    Apr 05 2008
    Quote Originally Posted by evilgabbie View Post
    I'm just outside Oshawa.
