Im stg 3 on stock intercoolers(for 2 more weeks) and have k04s, 60#injectors, epl MAF, and epl tune. I had a bad O2 sensor so I just changed both of those and swapped new plugs in and its still hesitating most noticably in 3rd and 4th gears around 4 to 5k rpm. It holds 21 lbs boost even when it hesitates. It like it cuts out a little then it takes off again a second later. Im not getting any misfire codes and the car runs fine other than that. I have some logs and will log again tonight but I dont know how to put them into graphs. Any ideas??
