Results 1 to 12 of 12
    Apr 07 2008
    96 A4 2.8, 99 Maxima
    Atlanta
    Re: AC freon VALVE? WHERE IS IT
    hey can u find out what they did cause i usually just use my high valve but I think my evaporator is leaking so i'm going to change that out but i would need to put in freon after that and the shops I toke it to couldn't figure anything out they just used the high side by the radiator. I have the same 96 A4. I figured you had to do something with the Low Pressure Switch but couldn't figure out what
    Active Member One Ring INFAMOUS9986's Avatar
    Apr 23 2008
    Audi A4
    Mass
    yeah I ended up finding the low valve but the freon attachment I had didnt fit so I went to the auto and bought an adapter kit which Im going to put on in an hour. You put it threw the high side? I was told not to do it that way, as to why I dont know, but was stressed to find the low valve. Ill let you know if the attachment works.
    Life passes most people by while they're making grand plans for it. Throughout my lifetime, I've left pieces of my heart here and there. And now, there's almost not enough to stay alive. But I force a smile, knowing that my ambition far exceeded my talent
    Established Member Two Rings Urbndevelopmnt's Avatar
    Jul 04 2007
    2005 A4 Cabriolet, 1996 A4 2.8
    East Rutherford
    You have to make the stem stick out more,then you can screw it on,after you unscrew the switch. thats how i got mine to work.
