Results 1 to 12 of 12
    Active Member One Ring INFAMOUS9986's Avatar
    Apr 23 2008
    Audi A4
    Mass
    AC freon VALVE? WHERE IS IT
    I have a 96 Audi a4 I found the valve that has the H but I need to find the other one so I can Recharge the whole system. Looked high and low going crazy. I know its got to be in right in front of me. Can anyone help me out?
    Mar 09 2004
    99.5 A4 Avant, 01 allroad
    nw michigan.
    Re: AC freon VALVE? WHERE IS IT
    Under the false firewall cover near the cabin air filter and battery.
    Jim
    I Do Werk.
    Oct 30 2006
    B8 A4 Avant 6spd
    If you're in front of the engine bay its top left, two black caps. the refill cap will only fit one of those valves.
    -18 718 GTS
    Established Member Two Rings Urbndevelopmnt's Avatar
    Jul 04 2007
    2005 A4 Cabriolet, 1996 A4 2.8
    East Rutherford
    No, for the 96 (I just went through this fiasco) the low pressure is behind the false wirewall,By the cabin air filter. but there is a switch attatched to it,you have to remove the switch and use that, The high pressure is in front of the rad With a black cap on itto the left (If you are facing the rad)
    so...When they refilled my gas they had to do something to the hose to get it to work on there, but it did.
    I have no idea why the 96 is like this, but it is.
    Apr 07 2008
    96 A4 2.8, 99 Maxima
    Atlanta
    hey can u find out what they did cause i usually just use my high valve but I think my evaporator is leaking so i'm going to change that out but i would need to put in freon after that and the shops I toke it to couldn't figure anything out they just used the high side by the radiator. I have the same 96 A4. I figured you had to do something with the Low Pressure Switch but couldn't figure out what
    Apr 23 2008
    Audi A4
    Mass
    yeah I ended up finding the low valve but the freon attachment I had didnt fit so I went to the auto and bought an adapter kit which Im going to put on in an hour. You put it threw the high side? I was told not to do it that way, as to why I dont know, but was stressed to find the low valve. Ill let you know if the attachment works.
    Life passes most people by while they're making grand plans for it. Throughout my lifetime, I've left pieces of my heart here and there. And now, there's almost not enough to stay alive. But I force a smile, knowing that my ambition far exceeded my talent
    Jul 04 2007
    East Rutherford
    You have to make the stem stick out more,then you can screw it on,after you unscrew the switch. thats how i got mine to work.
    Apr 07 2008
    Atlanta
    okay i will deff. try that thanks. Can u just pull it wid a nose plier? and then fit the low side port on it
    Jul 04 2007
    East Rutherford
    the hose i used i used needle nose pliers and uncrewed the stem some so it stuck out more, dont know what yours is like.
    Veteran Member Three Rings bmags88's Avatar
    May 12 2008
    B6 1.8T A4 / 06 Lincoln Navigator(Ultimate)
    Massachusetts/S Shore
    Anyone know where to find it on a B6?
    - Mags
    2003 1.8T A4 Quattro
    18" B5 RS4 Gunmetal Reps / K&N Drop-in / Helix Ecode Reps / Forge DV / DTH side skirts / 6000K Lows / OEM S6 LED DRLs / CF Beltline Trim / Blacked-out upper/lower grills / Parrot MKi9200 / Podi (Stewart Warner) Gauge
    USP Lower Front / S4 Grill
    Jun 30 2015
    West Covina
    I had to take it in and have them put a low pressure Port on my low pressure hose because other then THered be no way wouldbw had to take to Audi get serviced
    Jun 30 2015
    West Covina
    But now something else !!! 😔😩
