Results 1 to 40 of 55
    Jan 10 2008
    Midwest
    Help! Symphony II+ Install, unit won't Turn on =(...
    So i finally got around to ordering the adapter and harness to retrofit the Symphony II+ into a B6 A4, i went ahead with the install like this.
    1. Disconnected the Neg Battery Cable
    2. Put removal keys in old Symphony II headunit and proceeded to slowly pull it out.
    3. Disconnected all the cables from old unit.
    4. Connected old cables into new harness and adapter
    5. Connected harness and antena adapter to Symph II+
    6. Reconnected the Neg Battery Cable
    7. Turn ignition on.
    & Then... NOTHING Happens
    I hear the unit doing the cd dance but neither the display nor lights turn on. Everytime i disconnect and reconnect the harness it does the same dance but no lights or anything.
    Car is an '02 A4 w/ Bose.
    Anyone got a suggestion?
    Thanks,
    Ado
    Established Member Two Rings gotquattro's Avatar
    Jun 18 2007
    02 A4 3.0 Q / T / S
    Tallahassee
    Re: Help! Symphony II+ Install, unit won't Turn on =(...
    This is so stupid I even feel bad for asking....
    but, with the details you listed in your post, this one thing was missing, so.....
    You did reach over & tap the power button, right?
    I know, but had ta ask....
    Got Quattro?
    02 Silver A4 Sport (sold)
    3.0 Q / T / S
    14851's | RS4 Rear Sway | Slotted F&R w/ Hawk HPS & Stainless lines | APR Snub
    2006 MazdaSpeed6 GT #3476
    - clicky-clicky for details
    Dec 19 2007
    York, PA
    ^haha, keep it "simple stupid" right?
    Jan 10 2008
    Midwest
    Quote Originally Posted by gotquattro View Post
    Yes I did numerous times hehe
    Jun 18 2007
    02 A4 3.0 Q / T / S
    Tallahassee
    k-
    First thing I'd do then is put the OEM back, just to be sure everything original still works
    Then I'd reinstall as before & test
    If needed, next I'd double check the cables & all connections, with a meter, even as simple as just checking continuity through the aftermarket adapter. Also dbl chk the pins. It's entirely possible the adapter is funky, maybe even pinned incorrectly.
    May need to bench test the new unit to be sure it's good...
    Got Quattro?
    3.0 Q / T / S
    Veteran Member Three Rings Shak's Avatar
    A4 B6
    Northern VA
    I had the same exact problem when I was putting my unit in. Turns out that the RNS-E connector by default is not wired correctly for SYM II+ units. I had to basically rewire the harness on both ends so the wires were connected properly.
    I've already PM'd you these diagrams, but it'll be helpful in the future.
    Connector B Wiring:
    Connector C Wiring:
    Connector D Wiring:
    2002 A4 Quattro Tiptronic w/ Sport Package
    Mods:
    Cleared Corners; Headrest Mod; Symphony II+; Aero Wiper Arms and Blades; Painted Lowers; RS4 Rear Sway Bar, 35% Window Tint
    Jun 18 2007
    02 A4 3.0 Q / T / S
    Tallahassee
    huh, go figure.....
    I was just winging it....
    Nice post Shak!
    Got Quattro?
    3.0 Q / T / S
    Senior Member Three Rings drevil2k2's Avatar
    Aug 29 2007
    GTA
    Fuse maybe?
    Dec 25 2004
    Earth
    Shak is 100% correct!
    The RNS-E adapter is not correctly setup to plug & play the SII+ into most B6 A4's.
    Its all about matching the wiring harness adapter from the SII+ to your specific Audi.
    Bose-Non Bose....
    Phone-No Phone...
    CD Changer-No CD Changer....
    You'll have to move wires inside the harness, and maybe add or remove wires and individual connectors. BTDT!
    P.S. Ya do not need to disconnect the negative battery cable at all!
    When you disconnect the radio from its harness, power is "safely" removed like pulling a plug from a wall socket.
    I've R&R'd mine several dozen times, and never once touched the battery.
    Got the 4-digit security code for the SII+?
    Is the SII+ in "transport-mode?"
    Jan 10 2008
    Midwest
    Quote Originally Posted by MikTip View Post
    Yep got the Code & the SII+ was in transport mode. Do i have to remove transport mode or?
    Dec 25 2004
    Earth
    The problem sounds like the harness adapter...
    Senior Member Two Rings Adam 1.8's Avatar
    Jul 07 2007
    Audi S4
    Ottawa, Canada
    Bose-Non Bose....
    Phone-No Phone...
    does the disc info show up on the dash as well? if so do you have any pics?
    I wanty.
    A4 B6
    Northern VA
    Yup.
    The song you're playing shows up on the DIS, but only like the first 8 letters or so. Sadly, titles, artists, etc.. don't scroll back and forth on this unit.
    Mods:
    Jan 10 2008
    Midwest
    I will be attempting the rewiring tomorrow heh its supposed to rain and i have nothing better to do . i have printed off the diagrams (Thanks Shak! ) and hopefully all will go well.
    Thanks for everyones input!!
    -Ado
    Jan 10 2008
    Midwest
    So i tried to do the rewiring by following the diagrams and it didnt work. None of the wires from the B connector can plug into the sii harness because theres nothing in to holes for them to plug into...
    Now neither the sii or the sii+ will turn on
    Anybody got ideas? is there any place or anyone that sells plug and play harness for sii to sii+ ?
    Help please, no music sucks!
    -Ado
    Dec 25 2004
    Earth
    Contact TeddyBGame.
    He builds custom adapter harness's
    He can be found here-
    http://www.navplus.us/forums/
    Jan 10 2008
    Midwest
    Contact TeddyBGame.
    He hasnt logged onto navplus or AZ since 4-16-08, but i did e-mail him and added him on msn so hopefully he sees it.
    Can i get this adapter ? https://www.euro-parts.us/product.ph...cat=263&page=1 It Says SII to SII+ , i bought the SII to RNS-E Adapter and that one didnt work .
    Veteran Member Three Rings scorneil's Avatar
    Oct 27 2007
    Oakville, ON, Canada
    sounds like your harness, here is a good write up if you haven't already seen it
    http://forums.audiworld.com/audio/msgs/59261.phtml
    2010 B8 S4 Quartz Gray S-tronic Black Alcantara MMI
    2003 B6 A4 Canvas Beige 1.8T Tiptronic 1+ SOLD
    A4 B6
    Northern VA
    Oh, as a side note -- when I was rewiring the harness, I had to move a few pins around, take some out, and even put two wires to one pin for one of them.
    Mods:
    Jan 10 2008
    Midwest
    Quote Originally Posted by scorneil View Post
    Yea but what i dont get is why doesnt the SII work now
    Dec 25 2004
    Earth
    Here's some more onfo, given to me by others who installed a SII+:
    When I first test installed my Sym II+, it did the same thing. I found that the "safe" wire needed to be connected to ground via the Comfort and Convenience Module. There is a circuit in the mini ISO connector for this connection. The wire needs to be added from the quad-lock to the mini ISO to complete the safe ground connection from the HU to the CCCM. Do you have the pin out diagram for the Sym II+?
    A connection from quadlock T8h/14 to mini ISO, "Multi-pin connector III, 8-pin, (T black". T8/2 provides for the connection to " Anti-theft warning system ground from Comfort System Central Control Module J393". IE, Quadlock T8h/14>mini ISO T8/2. The +vdc "Safe" connection you refer to is provided by a jumper wire at the quadlock from pin T8h/16 to Th8/15, so that connector terminal needs to be added into the quadlock at T8h/15, with the pigtail crimped to the wire at T8h/16.
    Quadlock connector. IE, from the Black B6 ISO connector T8/3 > Sym II+ Quadlock T12m/7.
    The wire swap refers to the difference between the retro upgrade ISO <> Quadlock terminal assignments for the ISO <> RNS-E Quadlock adapter when used for the Sym II+ instead. In addition, the B6 ISO terminal T8/2 > Quadlock section D, T8h/14, (note departure from terminal pin ID assignment convention here,) is the terminal connection to ground at the central convenience module T20g/19, and is used for the "installed/not installed state switch for the HU security lock, is needed. Not used with the RNS-E, but implemented hard wired direct on the Sym II+, even though the pin-out on the HU says "not used". Installed in the B6, if T8h/14 is not connected to ground, the HU won't boot up. Finally, for Bose systems, Quadlock T12f/5 > ISO T8/1.
    Dec 25 2004
    Earth
    I bought my harness from Kufatec in Germany:
    http://www.kufatec.de/shop/product_i...usbauwerk.html
    I had to move 2 wires, and add a wire, to get my SII+ to work with Kufatec's harness
    Does your Audi have Bose? Phone? CD Changer?
    Mar 11 2004
    Boston
    Contact TeddyBGame.
    I'm here. Ado, i'll send you a note via email.
    -Ted
    TeddyBGame
    [email protected]
    Custom integrated RNSE, Symphony II and Symphony II+ wiring harnesses:
    http://www.navplus.us/forum/viewtopic.php?t=1880
    Lots of good RNS-E stuff and other C5 upgrades via here:
    http://account.audiworld.com/users/32631.phtml
    Jan 10 2008
    Midwest
    Update:
    Got the SII to work again (thank god) so i have audio again in the car , i blew the 20A Radio Fuse.
    I'll be shipping the RNS-E Harness to Ted to get rewired for the SII+ . I'd Try this myself but i broke all the plastic adapter ends off...
    Hopefully i'll have the SII+ workin by 1st week of May
    Jun 08 2007
    Orlando, Fl
    Quote Originally Posted by -=Ad0=- View Post
    Get that adapter ^^ I have it and it works, shipping was extremely fast as well.
    BetaAlphaTauMember #39 GTRS Powered/Revo Tuned
    Oct 21 2012
    United States
    My Harness has all the wires correct in the following images except the ones below:
    Missing Blue Wire: SymphII/ III 1 - Symph II+/ B5
    Missing Dark Purple Wires:
    Symph II/ I4 - SymphII+ / C3
    Symph II/ I5 - SymphII+ / C9
    I forgot to mention I have a audi a4 B6 NON- BOSE system if that makes a difference. If i get these wires and connect them in the appropriate places will my sympII+ radio work?
    Where can i get those wires with the correct terminal connectors? Does anyone have part numbers for those wires?
    Veteran Member Four Rings Docwyte's Avatar
    Feb 02 2005
    '03 911 Turbo, '15 Cayenne Diesel
    I had no problems with my adapter, but in my Bose S4 and non Bose A4. It was literally plug n play.
    '15 Porsche Cayenne Diesel ** Wifes DD
    '03 Porsche 911 Turbo 6 MT **
    '18 Land Cruiser ** My DD
    '17 KTM 690 "Adv"
    Nov 22 2012
    Toronto, ON, Canada
    Does anyone know if this will work with the steering wheel controls? I have a b7 but the old symphony II, i bought the wrong adaptor (for rns-e) but read it could be rewired for the symphony II+ if anyone can give digrams of which connecter is which on the other end connecting to the car)
    Established Member Two Rings Stig's_Cousin's Avatar
    Apr 08 2012
    East Alabama
    Quote Originally Posted by sao33 View Post
    It's right up there at the top, take a closer look at the pics and your harness and see what needs to be moved over.
    Sep 16 2010
    Central Wash
    Quote Originally Posted by Stig's_Cousin View Post
    Mine S2+ doesn't work with my B6 MFSW. Volume controls actually work, but the rest dont- and the control module registers all the commands, so everything is hooked up OK.
    Oct 21 2012
    United States
    Just got a symphony ii+ Bose harness...installed it in my non Bose b6 a4...it works but I get no sound from front speakers.... Anyone know how to fix this issue?
    Sent from my Nexus 7 using Tapatalk 2
    Nov 22 2012
    Toronto, ON, Canada
    Quote Originally Posted by A4Dit View Post
    the site is down now :( can someone confirm if the rns-e adapter steering wheel functions will work? once the adapter is rewired?
    Is there a better diagram?
    Mar 09 2013
    United States
    I have a RNS-E non bose harness, and and long story short I am installing a Symphony 2+ unit. Can anyone help me out? non of these situations seem to mirror mine exactly. ....please as I have no radio and a lot of frustration
    Deactivated One Ring
    Jan 23 2013
    Medina, Ohio
    Quote Originally Posted by Vishio View Post
    I just did the same thing last week, maybe I can help. What's going on?
    Mar 09 2013
    United States
    Quote Originally Posted by 3rob3 View Post
    Awesome! What do I need to change in my RNS-E harness? I plug in the symphony2+ and get nothing but the CD changer moving around. Also...do i need VAG-COM to finish this install? or after I re wire my harness it will all be plug and play?
    orrrrr is there an adapter where I dont have to mess with my RNSE harness? ...like a RNSE to Symphony 2+ ....I may be dreaming
    I have a 2008 8p A3 -- the original radio was the RNS-E navagation.
    Jan 23 2013
    Medina, Ohio
    Oh jeez, I have no idea about a 2008 A3. Why are you posting in the B6 A4 forum? On a B6 you have to add power to one of the empty pins, and move the K-line to a different pin.
    Aug 26 2005
    Quote Originally Posted by teddybgame View Post
    -Ted
    Good to hear you are still around, Ted.
    Vorsprung durch Technik
    Aug 26 2005
    Update:
    Ted fabricated my Sym II+ adapter harness. My adapter includes Sirius and RCA Auxiliary input. Ted will get your harness adapter sorted out for sure.
    Mar 09 2013
    United States
    Because i believe they are the same harness and because this forum was here lol
    Aug 26 2005
    Quote Originally Posted by jiinxsta View Post
    Bose setups use only low level signals from the head unit to the amps, Front R/L, and Rear R/L. Therefore, you need to add the front low level wires to connect the low level out front R/L, from the Sym2+ to the mini ISO connectors, where the Bose system chassis side harness has the wires for the front R/L low level connections to the amp. The non Bose setups use the internal head unit amp for the front R/L channels. This is why the harness adapter is missing the front R/L low level channel wires, and instead carry the front R/L audio signals on high level wires through the harness adapter. Consequently, without the front R/L low level signal wires connected through the harness adapter, there is no audio from the front R/L channel speakers. Both non Bose and Bose systems use low level Rear R/L audio signals to the rear and sub amp, that is why the Rear R/L audio channels are working.
