Results 1 to 9 of 9
    Veteran Member Four Rings chunkyckn's Avatar
    Bay Area
    FS: Unlocked 8G Iphone used for 2 months
    FS: 2 Month old Unlocked 8gb Iphone.
    I switched over to Sprint so I have no need for a $400 paperweight.
    Comes with 3 if not 4 cases (need to find the 4th one).
    No dead pixels. Has a slight bump on the bottom side by the right speaker. Also, the number buttom does not work, so when texting you cannot get into the number or symbol area.
    Make me reasonable an offer.
    Oct 22 2005
    Reppin the Mitten.
    Re: FS: Unlocked 8G Iphone used for 2 months
    do you have the receipt? where did you buy it?
    Bay Area
    I don't think so, let me try to find it.
    Just to clarify. You can make calls on the phone, all the numbers work, but it's the bottom Symbom button that takes you to the numbers when texting that does not work.
    Oct 22 2005
    Reppin the Mitten.
    you have pm
    Mar 07 2004
    '14 Q5 TDI Prestige & '14 Q5 TDI Premium Plus
    Charleston, W.V.
    Warranty it then sell it.
    Veteran Member Four Rings ABanT's Avatar
    Aug 07 2007
    B7 ABT Avant
    I don't see how that is possible. It's all software, if it doesn't work just do a restore and unlock it again. They have programs now where you just do a one click unlock, you don't have to go through the step by step unlocking anymore.
    If it's not software related then it is you digitizer that doesn't work, which would render that part of the screen useless regardless of the program you are using.
    Senior Member Two Rings MassS4B5's Avatar
    Jun 01 2007
    Stage 3 B5 S4
    east coast
    how much bro?
    Black S4 6 speed
    Vast built motor w/ cams, valve springs, rods, clutch fan delete, electric fan, tial 650's, rs4 ic's, x-1 intake, cm stage 4 clutch, light weight flywheel, hb dv's, efu 4u, zoldman 02's, avalon ock, stasis track sports, stasis motor mounts, oem trans mounts., asp tsb, asp 3" down pipes, asp true dual
    Jan 20 2007
    so what's going on with the phone? do you have a number that i can call and talk about this?
    Veteran Member Four Rings nimski62's Avatar
    Mar 11 2008
    2005.5 B7 S4 6mt, 2002 b6 3.0Q
    Pierceton, Indiana
    ill offer 300
