Originally Posted by
starfriend
thats a rather stupid post denver, that i could be without. This is a question regarding the SPS switch, and has imo nothing to do with the installation itself.
To you other guys, thanks.. can anyone please confirm this? :-)
Whats the SPS definition of STOCK? as mention in the product description?
thanks guys :-)
it was not in the least a stupid post...if you have not done enough research to know what differentiates a stock file, a BT "stock emulating" file, and the other assorted oct. specific files, how then am i to assume you have the accumulated knowledge necessary to even know what you are putting in your car, much less how to use an SPS 3 or any other device/software manupulation like in lemmi.
in a nutshell, there is no way in hell your car will run correctly with all of the tweaks or otherwise necessary to even try and get your fuel in line...forget boost, timing, and other VERY important factors involved here. there is a very good chance that running a 440cc file on stock injectors that you will run drastically lean based on the ECU's load calculation...i dont believe even with all the lemi in the world you could get that to balance out...there just isnt enough room in the ECU.
those are my thoughts as to why...if you want me to go into further detail as to how the fueling system of this car works...id be happy to...im dreadfully familiar with it.
p.s. running lean is bad.
