Results 1 to 38 of 38
    Veteran Member Four Rings Kyle H's Avatar
    Sep 21 2006
    98 A4 1.8tQM
    San Diego, CA
    Boost Factory SMIC ---> too big for k03?
    Boost factory has developed a replacement Side Mounter Intercooler that outperforms the top FMIC's out there with the advantage of keeping everything stealth and in the stock location with little to no trimming. Here's what we've found: The proper way to test a intercooler has more to do with the temp diferential between the inlet and the outlet than most people realize.You cannot draw any conclusions with just the intake temp logs. The proper way to test this is to measure the max temps of the inlet and outlet on the intercooler and ambient outside temp.This can be done with a K type thermocouple and a good multimeter thats designed for use like this. Once you get these measurements you can use this formula. (temp in-temp out / temp in-temp ambient)* 100 = Thermal efficiency Here are the real #s that were collected today during the test. BFSM temp in = 235deg F temp out = 85deg F Stock SMIC temp in = 235deg F temp out = 105 deg F Anbient temp = 35deg F So what do we have? BFSM (235-85=150 / 235-35=200) =.75 * 100 = 75% Stock SMIC 235-105=130 / 235-35= 200 = .65 *100 = 65% Another side note is the 4+ psi pressure drop of the stock cooler and the unmeasureable drop of the BFSM. Another interesting link is the APR site that has enough info for you to draw some interesting conclusions.I do notice they dont mention the ambient temp or the intercooler efficiency.My conclusion from this is that it would take all the same info they provide+ some damm hot ambient temps to equal the BFSM We tested this BFSM and found it to flow 491cfm@1psi pressure drop This intercooler is good for 400hp *Keep in mind that these units usually take about 2 weeks to make as they're custom orders. Specifically developed for the Golf/Jetta mk4, however now also for the B5 Chassis cars such as the Audi A4 and VW Passat. Measurements: 6" x 8.1" x 8" Flow: 491 Cubic Feet Per Minute (CFM) Choosing the correct MAP sensor size: SMALL-2000-2003 including VW GTI/Jetta 1.8T/TDI, VW GTI 337 (NOT 20AE) LARGE-2003 VW GTi 20AE, 2004- VW GTI/Jetta 1.8T/TDI including GLI We will now ship all Golf/Jetta SMIC's with an adapter sleeve to fit both small and large map sensors.
    http://boostfactory.net/product_info...products_id=77
    I've heard they're big enough to support GT28R's, but their product description makes it sound like they can be run on k03's. If it's a 400hp core I know I should generally have those mods... soo is this thing too big for a k03?
    If it is, what are some other options for lowering IAT's on a k03? I know of w/m injection and intercooler misting.
    "Einstein: Any man who can drive safely while kissing a pretty girl
    is simply not giving the kiss the attention it deserves. "
    because racecar.
    Sep 17 2006
    07 cbr600
    Re: Boost Factory FMIC ---> too big for k03?
    might wanna change the title to SMIC.
    Senior Member Two Rings a4_1.8t_01's Avatar
    Feb 24 2008
    A4 1.8TQM 01
    I dont understand why people with k03 want to change their intercoolers. There will be no noticable gains. Not worth it.
    Unitronic tuned. love it.
    Need any services done in NYC area please PM me. I will diagnose and fix your car. Also do clutch replacements, Timing-belt services, Turbo upgrade/installation, Fluid changes, boost leaks and pretty much anything.
    Sep 21 2006
    98 A4 1.8tQM
    San Diego, CA
    Quote Originally Posted by a4_1.8t_01 View Post
    Not for power, to reduce loss of power. It gets over 115 degrees here in the summer regularly.
    because racecar.
    Veteran Member Four Rings aytheory's Avatar
    Oct 28 2006
    A4 1.8tqm 99.5 aeb ndbw
    Los Angeles / Santa Barbara
    Re: Boost Factory SMIC ---> too big for k03?
    DOOOOOOO IT - it is good for future upgrade
    Veteran Member Three Rings jm121189's Avatar
    Jun 05 2007
    Portland, ME
    I'm thinking about getting one of these in the next few weeks.
    2000 1.8t A4 qtm gone but not forgotten
    2008 R32
    2015 S4
    Sep 11 2007
    Dirty Jersey
    I have it on my k03
    I've not suffered any noticable power loss, or MPG loss
    infact the cars seems to go into boost much faster now
    I bought it cause I'm planning for the future which includes a non k03 turbo
    I've got nothing but positive things to say about it, I installed it a few weeks ago and I haven't had to change one thing about it
    install took a grand total of 45 min too
    Nine [O_O] Eight Tuning
    custom work, fabrication, bumper shaving, fender rolling, plastic & fiberglass fabrication and repair
    Turbo charged and lowered for better grocery getting :screwy:
    Jun 04 2007
    01' A4 1.8TQM;15' Wrangler
    Austin/DFW, TX
    although I have a fmic I think I'm going I get this sooner or later
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
    Sep 21 2006
    98 A4 1.8tQM
    San Diego, CA
    If I'm thinking about this right, the BF SMIC can support those bigger turbos because of higher flow, not higher volume, correct? And the bad thing about running big fmic with a k03 is that they have a huge volume that the k03 can't fill... right?
    because racecar.
    Sep 11 2007
    Dirty Jersey
    I don't claim to be an expert on these things, but I don't think that the BF sidemount has less internal volume than most front mounts
    the pictures you see may not accurately portray the size of the unit
    its almost cubic in shape
    Registered Member Two Rings SilverB5A4's Avatar
    Jan 19 2007
    RIP '01 A4 1.8TQM, 96 VR6 GTI
    GA
    I would love to run one of these for the stealth and ease factors, but i am still leary of just how good it is. Proper ducting could really help i would think.
    GIAC chip - Koni coilovers - Purems Boxster calipers and A8 rotors - CPP Adjustable Front and Rear upper control arms - H sport sways - B7 S4 BBS CH 18" - 2.8 transmission
    Mar 26 2005
    01 A4 1.8t avant; 04 B6 S4
    All over the Bay Area
    this has been added to my list of mods :] thanks
    TEAM|AXION
    Forum Moderator Four Rings docurley's Avatar
    UK London
    Note cars with headlight washer may have issues fitting this and may have to fit a the smaller non washer bottle to get this in.
    Avus Audi RS4 2007 |Stock| Black optic | intake pipe| Android RSN-E| carbon knob Handbrake Airbag| LED interior & puddle lights
    Mar 09 2004
    99.5 A4 Avant, 01 allroad
    nw michigan.
    The washer reservoir are the same size. I've had both since I eliminated my headlight washers and switched to the other res.
    A K03 or K04 need a good intercooler as much as a gt28. The little turbos go out of their efficiency range and start blowing hot air quickly. A few hot laps on the track and my K04 maxes out around 5-6 psi with the stock SMIC.
    Jim
    I Do Werk.
    Veteran Member Three Rings fikes's Avatar
    Aug 04 2007
    2001 Audi S4 Sedan
    Perkasie, PA
    I have done allot of research on this before as I was planing on upgrading to a bigger smic because I like it to be stealth. The boost Factory is good but the Tyrol Sport is even better you might want to check it out. Its more money but It might be worth it. http://www.tyrolsport.com/index.php?...d=45&parent=95
    Looks smaller in the pic than it really is.
    There is also this pic which shows what it looks like in size difference but this one if for a beetle.
    http://www.tyrolsport.com/index.php?...d=53&parent=67
    1997 Audi A4 Sedan 1.8t- Sold
    1999.5 Audi A4 Avant 1.8t- Sold
    2001 Audi S4 Sedan- Current
    Sep 17 2006
    07 cbr600
    Quote Originally Posted by fikes View Post
    For the price of the tyrolsport you can get a racetec front mount for 800. I think they'll even paint it black for you if you want to be "stealth".
    Aug 04 2007
    2001 Audi S4 Sedan
    Perkasie, PA
    Ya I know what your saying but some people want it to be stock stealth and to now have to trim up their bumper. I think I am going with the racetec when I get the cash seems thats the most preferred one if you don't mind spending the money on a good one other than ebay.
    Sep 11 2007
    Dirty Jersey
    Quote Originally Posted by SilverB5A4 View Post
    when I put mine in I sliced up the stock duct and made it fit the new intercooler, I'm also using a S4 fender vent
    Quote Originally Posted by docurley View Post
    I think that was just Robbie's weird 2001.5 car
    it fit no problem in my 97 with the 2 part washer bottle
    Sep 21 2006
    98 A4 1.8tQM
    San Diego, CA
    I just read through the car classifications for SCCA auto-x, and an upgraded intercooler bumps me up into the next category (with all non-stock-turbo cars!). I could probably get away with saying the bf smic is stock, but that would be cheating...
    Are there any other options for lowering iat's other than w/m injection and intercooler misting?
    because racecar.
    Sep 11 2007
    Dirty Jersey
    unless you told them it would be hard for them to tell
    expecialy if you painted the endtanks in a black wrinkle finish paint
    if its only for auto X maybe you just get a small c02 bottle with a handheld wand nozzle to stick in your lower grill and cool down your stock IC between runs
    if a modded IC isn't legal I can't see how water injection would be
    Apr 05 2005
    2010 Audi S4, 2013 Ford F150 , 1987 Grady White 206G Overnighter
    Baahstin MA
    Quote Originally Posted by onemoremile View Post
    Huh? It sounds here like you're disputing docurley's point that cars with the single, larger sized washer fluid reservoir will have trouble fitting this. He's right. The larger reservoir takes up SO much space in that bumper that the BF BAMF SMIC is pushed forward, down, and to the left so you can't make it fit.
    I've got an uninstalled intercooler that agrees with me on this one.
    Photographic evidence, FTW.
    Current: 2010 S4 Prestige, 2010 A4 Premium Plus, 1987 Grady-White Overnighter 206G
    Gone: 1999 Wrangler Sport, 2001.5 A4 1.8TQM w/GTRS, 1997 Wrangler Sport, 1990 Corrado Stage IV Corrado g60
    Mar 09 2004
    nw michigan.
    There must be more than two different reservoirs out there then. The two I've used were the same volume and same shape with the exception of the headlight pump mount.
    Jim
    I Do Werk.
    Veteran Member Four Rings UN-PIMP-Z-A4's Avatar
    Jan 29 2007
    MR VTEC Lives...
    Yes We Can!!! Obama N Beyond!
    last time i checked there wasnt any documented stats out there that this upgraded smic lowered iat as much as a true fmic.
    If any one has logs i would love to be enlightened because i have inqquired since 05.
    Homebrew PES Powered Stage 3 A4 1.8TQM It can be yours for only $5k PM for details
    I have a JUSTINTERCOOLER 27 X 6 X 2.75 WITH 2.5" inlet / outlet (Brand New in Box) FMIC for Sale $90
    QUOTE OF THE YEAR:
    "Another thing, dont go flashing 15 second timeslips!"
    Sep 11 2007
    Dirty Jersey
    well, I have the smic, and vag com
    I don't really know how to do logs though, if you wanna walk me thru it I'll do my best
    Sep 11 2007
    Dirty Jersey
    Quote Originally Posted by RobbyB413 View Post
    I was gonna give it my best try on sat, oh well
    Apr 05 2005
    Baahstin MA
    Quote Originally Posted by Vreihenmotor6 View Post
    Yeah, but I have standing comitments on sat, or else I'd defiently be down to see what we could do to that tank to make the IC fit... including hack sawing of course.
    Quote Originally Posted by onnemoremile
    it could be just another case of the 2001.5 screwing the owner, but what I was told when I checked a person who works the parts counter and is ususally spot-on when it comes to this sort of thing. He said there were just two setups... single tank (mine) and dual tank (older?) and he thought it was something that went along with the face lift.
    I haven't delved into ETKA too much myself on this, as I was just going to replace the tank and lose the washers. At a bare minimum, before anyone tries this they should pop the bumper off and see which tank they have.
    Dec 20 2007
    1999.5 Audi A4qm AEB
    iowa
    http://www.germanautoparts.com/Audi/A4/Body/174/2
    There is 3 different jugs for the b5 a4 as far as I know 3.5, 4.5 and 6.5 gallon jugs.
    Sep 11 2007
    Dirty Jersey
    Yeah, but I have standing comitments on sat, or else I'd defiently be down to see what we could do to that tank to make the IC fit... including hack sawing of course..
    well, I do have that plastic welder to "uncut" things with
    I will still maintain my it will fit as is position untill I myself have tried
    Veteran Member Three Rings killa's Avatar
    Sep 23 2006
    500whp A2 vw 16v gti, 97 Audi
    Jersey
    Not trying to be biased here but you have no facts to make your judgement on, put them side by side with all things being equal if you want to get good data, otherwise your oppinion is just as vadid as the next guys, et, etc, etc.
    BT and Tyrol both use Bell cores, the rest is up to you to decide as the numbers are out on both sidemounts.
    Hope that helps.
    Veteran Member Four Rings sean1.8t's Avatar
    Sep 17 2006
    I wish I had a garage.
    SLC, UT
    ^yeah, i was going to ask that guy where he gets his info from?
    forum knowledge i tellz ya
    Current:
    '16 Mercedes-Benz C450 "AMG": Stage 2 w/downpipes & 19" BBS CH-R's
    '88 Harley-Davidson Sporty 880: 1200 bottom - Ported & Cam'd top - S&S In - Screamin' Eagle Out
    Previous:
    '02 Audi A4 1.8TQM: Full GT28RS on meth w/everything else.
    '01.5 Audi A4 1.8TQMS: Tune and exhaust.
    '99 Subaru Legacy Outback wagon Manual: Bone stock.
    I don't even want to remember the others
    Jan 29 2007
    MR VTEC Lives...
    Quote Originally Posted by killa View Post
    Hope that helps.
    Can you post some numbers up from the BF UGSMIC on a a4 or passat application?
    I heard good things in reference to the transverse applications but have yet to see data from the longitude engine.
    If you have stock vs bf or bf vs tyrol or stock vs bf vs tyrol i would love to see.
    Plus I would how effective it would be especially since not that much air is getting to it and even with vents in the liner is that enough circulation.
    Not trying to be a prick just i have been curious for quite some time.
    QUOTE OF THE YEAR:
    Veteran Member Four Rings m5racer's Avatar
    Nov 20 2006
    anyone think there would be enough intrest in a Group Buy for the boost factory SMIC? Im highly concidering one
    01.5 A4 1.8t sport
    Jun 05 2007
    Portland, ME
    I'd be interested in a group buy if it could happen in a few weeks.
    2008 R32
    2015 S4
    Veteran Member Four Rings maxspeed's Avatar
    Dec 14 2005
    Shakedown street, NY
    Quote Originally Posted by UN-PIMP-Z-A4 View Post
    x 2, everything ive read on this unit is that its a waste of money
    2000 Audi A4 1.8TQM - RIP
    1999 Subaru Outback
    When your spirit is floating down that tunnel, towards the light, You know what's behind the light?
    It's not God, it's me. And I'm gonna kick your poncey soul All the way back down the tunnel 'till you choke on your own fucked up ribs! Now, Wake the fuck up!
    Jan 19 2007
    GA
    It is never going to be as effective as a FMIC of similar quality, the whole thing that makes a FMIC better is that it gets more direct airflow and has more frontal surface area.
    Mar 09 2004
    nw michigan.
    You guys really need to do some more learning on how intercoolers work. For normal driving they are as much a heatsink as anything. The opening feeding it only needs to be 40-60% of the area of the intercooler itself for great efficiency. There are a great number of reasons that the cars like the B5 RS4 and Porsche 911 Turbos come with dual SMICs instead of a FMIC.
    Jim
    I Do Werk.
    Apr 05 2005
    Baahstin MA
    Quote Originally Posted by Toyotatech View Post
    Yeah, three tanks, like I said...
    Older style = dual tank, one in the fender, one under the intake mani
    Newer stile = larger tank in fender
    Sep 11 2007
    Dirty Jersey
    that and packaging, as in how to fit all that stuff in a small space
