Results 1 to 20 of 20
    Veteran Member Three Rings 2k1audiS4's Avatar
    Oct 30 2007
    Pasadena, MD
    What could these codes mean??? And what could this sound be? (With video)
    I am thinking of buying this 2001.5 S4. I ran the codes on it and this is what came up:
    P0300
    P0507
    P1136
    P1138
    It sounds like there is a shhhhhhhhhhhhhhing noise in the back of the engine. Like there is air blowing out of a hose. Its constant and does not fluctuate when you press the gas. Would this just be a vac hose that is off or could it be a turbo going bad? Turbos sounded fine when i revved it and there is no white smoke or anything. It has 95k miles on it and it does have 710n's. Please any help would be appreciated. I am getting the car pretty cheap(under 10K) because i have access to wholesale dealer auctions so i can put a little into fixing what ever it is. I just dont want to have to replace the turbos if that is what this noise is. The sound is noticeable if you have the hood up but not noticable if the hood is down. Here is my cell phone Video:
    http://www.youtube.com/watch?v=BVXV-tYPkJs
    2001.5 S4 Silver 6MT......GIAC X, APR Bi-Pipe, FMIC, "Custom" UUC VM1, RS4 Clutch, APR R1 DV's, AWE DTS, K&N, Eibach pro kit, D3........SOLD
    2000 S4 Black 6MT.....Stock........SOLD
    2000 A6 2.7T 6MT.....Stock..... SOLD
    2001 S4 Sport Black 6MT.....Stock......SOLD
    2001.5 S4 Santorin 6MT....Stg2.....SOLD
    2001.5 S4 Sport Santorin 6MT....Stg2....SOLD
    2001 S4 Sport Silver 6MT.....Stg1....ACCIDENT THEN SOLD
    Veteran Member Four Rings S4 in_lowplaces's Avatar
    Feb 09 2006
    2021 SQ8, 2000 AWE stg 3 s4, 2012 CTSV 730Whp, Sold: 2000 Stg2 S4 revo,Totaled: 2000 Stg1 S4 APR
    Huntington Beach
    Re: What could these codes mean??? And what could this sound be? (With video)
    P0300 cylinder misfires
    P0507 idle control system running high
    P1136 bank 1 is running lean
    P1138 bank 2 running lean
    with that many miles you'll have to replace turbos soon anyways, there really no way of knowing how much longer they will last.
    edit: probably needs a tune up. that might clear the codes. as for the noise, i cant tell ya sorry.
    2021 Ocra blk SQ8 - Daily
    2011 CTSV coupe 730 WHP - Garaged
    2000 Silver B5 S4 AWE stg 3 - Garaged
    2002 Silver b5 s4 stage 2 revo - Totaled
    2001.5 silver apt stg 2 b5 s4. - Sold
    Oct 30 2007
    Pasadena, MD
    But could that shhhhhhing noise be a turbo or is it likely just a boost leak?
    And could those codes be fixed with a couple o2 sensors?
    Veteran Member Three Rings Jsmooth65's Avatar
    Aug 10 2007
    '15 BMW M235i, '04 A4 1.8t
    Castle Rock, CO
    pressure test that biotch
    2004 Audi A4 Sedan, Auto, Black, 1.8T Beater
    SOLD - 2007 Audi S4 Sedan, 6spd, Sprint Blue, JHM tune, JHM trio, JHM LWFW and stg3 clutch, Magnaflow RS4 exhaust, LED tails, TTRS SW
    DEAD - 2000 Audi S4 Sedan, 6spd, Laser Red, FRANKENTURBO Stage 3 VAST Fueling (25psi), ER Intercoolers w/shrouds, SSAC DP and Twin 2, JHM trio, APR Bipipe, VAST Stage 3 clutch and LWFW, Sterns mounts, 034 ICM delete/coil conversion, Vogtland coilovers
    Oct 30 2007
    Pasadena, MD
    I wish I could but its not possible before i buy it. Thats why im trying to get a sense of if it is a turbo or not.
    Feb 09 2006
    Huntington Beach
    well since the turbos dont have load on them i woudl think that sound isnt the turbos. It's probably a vacum leak. you just need to realize that its very hard to tell how long that leak has been there, making the turbos work harder to produce the boost that is being requested. Also, I'm not a tech, that noise coudl be somthing else.
    If it was the 02 sensors you woudl see a code for 02 sensors which you are not seeing so.......
    go to audi world and type in each code in the seach engine and read through them, that WILL help you.
    Oct 30 2007
    Pasadena, MD
    Anyone else? Sorry to sound pushy but i really need the help. I am buying this car soon. I cant find anything on what the codes or the sound might be. Thanks for everyones help.
    Veteran Member Three Rings RuS4ty's Avatar
    Mar 13 2006
    VA / MT
    Brake booster hose
    *NEW Addition: Misano Red RS4
    01.5 S4
    For sale(pm me for details):
    FRONT AIRBAGS !CHEAP!
    Stock S4 swaybar
    "I'd have one of those... if I were the sort of person that looked at my sister and thought, mmm..." - Jeremy Clarkson about the Roush Mustang.
    Jun 14 2007
    2000 S4
    Connecticut
    WG line from turbo?, lol just throwing it out there ive seen that recommended before!
    Jun 14 2007
    2000 S4
    Connecticut
    Quote Originally Posted by RuS4ty View Post
    Brake booster hose
    thats a huge vac leak if it is, the idle would be ASS probably [O_O]
    Oct 30 2007
    Pasadena, MD
    It idles fine thats the weird thing. You would think that it would idle like crap if it has that big of a vac leak.
    Mar 13 2006
    VA / MT
    true. Just threw it out there since it was from that area and sounded like a vac leak.
    01.5 S4
    Stock S4 swaybar
    Veteran Member Four Rings AMC's Avatar
    Jun 15 2007
    '19 Spektrum Golf RS, '18 Audi TTRS
    check the spider hose connections, they make that noise when loose and from the video it sounds like its comming from that area
    Driver Supply
    Current
    '19 Spektrum Golf RS DAZA
    '18 Audi TTRS
    Sold
    '07 Stage 3 2.7t swapped B7 A4
    '01.5 Stage 63463 Silver S4
    '13 black Audi S7
    '03 Porsche 911T
    Oct 30 2007
    Pasadena, MD
    What/where are the spider hoses?
    Jun 15 2007
    Quote Originally Posted by 2k1audiS4 View Post
    see that hose that goes into the firewall right between the firewall and y pipe, follow it and check it
    Driver Supply
    Current
    '18 Audi TTRS
    Sold
    '13 black Audi S7
    '03 Porsche 911T
    Oct 30 2007
    Pasadena, MD
    Any other ideas about what could be causing the codes?
    Dec 06 2007
    Calgary, AB, Canada
    Wow, I'm surprised nobody has recommended doing a boost leak test yet. Do one.
    Nov 17 2006
    b5S4, b8.5 Allroad
    Las Vegas
    Quote Originally Posted by AMC83189 View Post
    id bet on teh spider hose too.. the plastic gets britle and usually cracks.
    if you look on both sides of your valve covers theres a breather port on the outside that has 2 of the 'legs' of the spider hose. the meeting point for them is under your y-pipe/accordian hose. check it
    Mar 30 2008
    01 Black S4
    Ohio
    It's probably a vacuum leak. That would explain the lean codes and idle code. The idle air control bleeds air to control idle speed. It'll just shut down to compensate for the high idle caused by a vacuum leak. On fuel injected cars the idle doesn't necessarily get terrible with a vacuum leak. Fuel is added to try and compensate for the lean condition. But only so much will be added at idle. At cruise is where the lean condition is most often picked up by the ECU.
    Senior Member Three Rings archimense's Avatar
    Jan 16 2006
    Vancouver, Canada
    Quote Originally Posted by S4 in_lowplaces View Post
    I second this opinion.
    Probably a boost/vacuum leak. It needs to be pressure tested. Boost leaks cause the turbos to work harder to maintain requested boost -> killing the turbos.
    2001.5 Audi S4 stg 3
    K04s, 85mm MAF, 60lb injectors, custom software
    ASP DTS/Tru-Dual/Downpipes
    Stasis Tracksports/4:1 Centre Diff
    Neuspeed 19mm rear sway - CPP rear end links/tie rod ends/front upper control arms
    VAST ceramic clutch, RS4 pressure plate, JHM shifter
    RS4 engine/trans mounts, Stern rear diff/snub mounts 55 watt HIDs, Odyssey PC680 battery, Innovate Wideband
