Results 1 to 40 of 47
    Veteran Member Three Rings eg6siR's Avatar
    Feb 06 2008
    1993 honda civic Si, 2004 Audi
    pittsburgh pistolvania
    APR STAGE 3+ ??'s
    ok, so i just sold my civic hatch (it will be missed) it could consistently run 12's on street tires all day every day. so now i have $8000 to dump into my A4. i want comparable times, even if the audi can only run 13's i will be happy.
    first question: APR 3+ or custom route? i can install everything myself, i have been a mechanic for many years now. so labor prices dont matter to me... and if i go custom i can fabricate whatever i may need.
    i know there are some BT and BAT who have done this already so i am looking for your opinions. i want 300+ whp for sure and i will build the motor if i have to. i already have most of the supporting mods sitting in my basement, front mount, neuspeed exhaust, test pipe, coilovers, and s4 brakes.. this has been my daily for a while now and i have been wanting to make it a monster, so please any input would be greatly appreciated.
    and anyone from the PA/ pittsburgh area know a good place to get my shit tuned once i install everything?
    snailspeed.net
    04 1.8t 6spd dolphin grey
    "you can go fast cheap but it wont be perfect, or you can build it right and go fast, but it wont be cheap"
    Veteran Member Four Rings yoogene83's Avatar
    Apr 27 2004
    2017 Pacifica Limited / 2014 BMW M5
    Seoul
    Re: APR STAGE 3+ ??'s
    get APR 3+ kit then...
    APR 3+ tune + custom lemmiwinks
    replace GT28RS with GT2871R
    add water/meth injection
    that is pretty close if not THE limit on the stock bottom end.
    Otherwise, i would go 2.0L, pistons, rods and a full rebuild for safety of mind, then use a 3071R and comparable injectors. only thing is you would need a custom tune or use Shawn's (a4ringedone8t) tune
    Jun 30 2007
    Raleigh, NC
    that money will go a lot further if you go the custom route.
    sounds like someone is about to join BAT. best of luck to you -- with that kind of money and most supporting mods out of the way, i'd start reading through shawn's build thread - and see if that's something you want to do. (3071 or 3076, 2.0L, built head, etc)
    12.5 best ET -- 113 best trap
    The Awesome™
    BetaAlphaTau Member #42
    Feb 06 2008
    what is APR 3++? i have seen shawns setup, looks/sounds mean as hell. what is he tuned on GIAC? REVO? i think the custom route would be what i would normally do, but it seems 3+ is pretty badass... i am gussing 3++ is a custom build stage 3 setup? like different turbo/injectors/ injector file?
    how much HP/TRQ can the stock bottom end handle?
    snailspeed.net
    Veteran Member Four Rings mtbrider's Avatar
    Oct 31 2005
    Virginia
    go custom, no questions asked
    Some fast things and some slow things
    ~Josh~
    Feb 06 2008
    Quote Originally Posted by mtbrider View Post
    thats how i usually feel, but i just wanna see what some gtrs and APR3+ guys have to say?
    anyone running apr3+ currently?
    snailspeed.net
    Veteran Member Four Rings aLeXliu911's Avatar
    Sep 14 2006
    2003 A4 1.8T QM
    Vancouver
    skip the apr stage 3+ get BAT instead.
    2.0L + GT3076
    BetaAlphaTau member #11
    2003 A4 1.8T 5SpdMQ Black
    545awhp, 477.4awtq
    Stasis Motorsport C/O
    Stasis Center Diff
    Stasis Rear LSD
    Stasis Alcon BBK
    Status Carbon Fiber Seats. ER Comp FMIC
    2008cc, AWM, Ported AEB Head, HTA GT3582R,Full Race Exhaust Manifold, INE Intake Manifold
    Oct 29 2005
    10speed
    San Francisco, CA
    Quote Originally Posted by aLeXliu911 View Post
    2.0L + GT3076
    thats such a solid setup... PM me if you have questions I did the 2.0 stroker this winter
    - Clint
    Veteran Member Four Rings A4 TSCHUSS's Avatar
    Apr 24 2005
    E55 AMG, CTS-V
    Jacksonville, Florida
    The stock bottom is good for roughly 325whp anything over that or power consistently at that level then you may have rod failure. Rods are only $350 through Integrated engineering. As far as turbo kit to do, if you are looking for a consistent 300 or little more at the wheels and have $8000 to spend buy the APR 3++ which is the APR kit with the GT28RS swapped out for a GT2871r. This will give you 300 or more on pump gas without having to fool with meth injection and the kit is great quality (no worries of cracked manifolds). Also you will slap it on and not have to tinker with boost and timing to get the power, its just put it in and go then you can always use a program called lemmiwinks which you can download if you search around for it and this was developed by REVO. With that you can adjust the timing to get some more power.
    As far as the GTRS you are gonna have to run meth injection with pump gas to get to 300whp and that is at max timing (controllable with the SPS 3 unit or newer Select Plus which I personally don't like since its more work to change things) and around 21psi (GTRS is good for 24psi max) and this is on a perfectly running car. I personally have got 300whp at 20psi and timing 9 (max timing on the REVO software) while running something similar to 100 octane (I had a few gallons of 93 and like 2 gallons of Toluene mixed in) and im all wheel drive and the dyno room was at like 90 degrees, but on the other hand another member only achieved 298whp at higher boost and max timing with a front wheel drive and if I recall this was on the same dyno as me.
    ~David~
    Gone but not forgotten 437whp on 93 octane and washer fluid injection A4 12.2 best ET, 12.3@119 best overall
    480whp/500wtq E55 AMG 11.6@120
    CTS-V 9.6@148
    Feb 06 2008
    did you do it in the parking lot at school too? making huge messes in public parking lots FTW!!!
    what internals did you use?
    ok, so where is a good place to pick up another engine for the build? i dont want alot of downtime.. atleast until i get a truck for a daily and to haul around my quads... haha
    snailspeed.net
    Feb 06 2008
    Quote Originally Posted by A4 TSCHUSS View Post
    i can fabricate my own tubular manifold so i am not worried about a cheap manifold, but 3++ sounds fucking tempting... I have a tubing bender, and a tig welder so maybe i will start fabricating..
    snailspeed.net
    Oct 31 2005
    Virginia
    there is a amb motor and trans in the classifieds for a good price right now
    ~Josh~
    Oct 29 2005
    10speed
    San Francisco, CA
    Quote Originally Posted by eg6siR View Post
    nah the build was during my winter break ha.
    Buy a spare 06A and build that up in the meantime... I did wiseco 9:1 83mm pistons, Scat rods, and an AEG crank... Read the FAQs youll have a built 2.0 for ~2k
    - Clint
    Feb 06 2008
    that sounds like what i want... IE rods look a little better than scat though... or am i wrong? that would leave me with 6k for the turbo setup... since i already have frontmount, TP, exhaust waiting for install
    snailspeed.net
    Veteran Member Four Rings Groove1797's Avatar
    Apr 08 2004
    Your mom on a unicycle
    Eating Cheese Curds
    APR 3++ is for a built bottom end, head, and uses a gt2871
    4Runner, Rs5 and Alfa Guilia QV
    Apr 24 2005
    E55 AMG, CTS-V
    It really would only take you a day to swap the rods, its actually pretty easy. You don't even have to take the cams out of the head to get to the head bolts so just take the valve cover off and pop out the head bolts then disconnect a few coolant hoses toward the rear of the head and a plastic coolant flange on the backside of the head which you can see a do it yourself with some pics from when I changed mine to see where bolts are which you cant really see when you are doing it. Then of course disconnect turbo from the mani and undo the timing belt and there ya go!
    ~David~
    CTS-V 9.6@148
    Apr 24 2005
    E55 AMG, CTS-V
    Quote Originally Posted by Groove1797 View Post
    you don't need a built head for a GT2871r
    ~David~
    CTS-V 9.6@148
    Feb 06 2008
    looks like i might be going with a built motor.... Any good cams with some nice long exhaust duration to get those BT's spooling faster? now i am getting excited
    this was my street/racecar for the last few years, it could consistently run 12's on street tires:
    all motor B16 setup 12.5:1 comp. ratio, 11k rpm redline, i miss it already and the guy hasnt even picked her up yet, but he gave me a nice deposit so i guess i have to say goodbye honda, and hello BT a4.
    snailspeed.net
    Apr 24 2005
    E55 AMG, CTS-V
    god damn 11k rpm I had an integra in the past but never went crazy with rpms
    ~David~
    CTS-V 9.6@148
    Veteran Member Four Rings AB18's Avatar
    Dec 17 2004
    US
    I am in the Pittsburgh area and can help you out with the install if you need it. Ive installed a couple turbos on my old B5 1.8T,one being Apr stage 3. If this is going to your daily driver, Apr stage 3 + is the way to go. I don't care what anyone says, it is a rock solid kit that isn't going to give you many problems, which is nice for dding. BAT setups will make more power, but won't be as drivable in this city, and won't be as reliable. The Apr stage 3 uses the disco potato, which is proven to be a great all around turbo. As far as tuning options around pitt, not really. All i have to say is, watch yourself around Next level tuning in Greensburg. They will come off as your best friend, but its far from the truth, thats all im going say. Apex tuning in wexfords deals with GIAC, they are legit.
    What are you located? I am just off exit 9 on 60 north, right near pitt international. I am out here going to flight school.
    2001 S4 6sp...has a few goodies...and JHM shifted
    Tons of parts for sale..
    GIAC A box ECU for sale-350shipped.
    http://www.audizine.com/forum/showthread.php?t=170072
    Feb 06 2008
    haha, yeah, its built for like 12k, fully balanced, and revs like a street bike, it made like 240whp all motor.... and i could drive it on the street with no problems... i drove it less than 5000 miles a year so it was emissions exempt and i ran a test pipe with the spoon n1 catback setup so it was loud as hell and sounded like a crotch rocket, and moved like one too...
    snailspeed.net
    Feb 06 2008
    AB18: i am in washington, so like 30 minutes from you... south on 79... i can install it myself no problem, but i would like to see that s4
    snailspeed.net
    Feb 06 2008
    but what about some long duration cams?
    snailspeed.net
    Apr 08 2004
    Eating Cheese Curds
    there software revs to 8+
    Veteran Member Four Rings rxrep's Avatar
    Feb 28 2006
    has nothing in it but memories.
    Pittsburgh-Philly
    I don't have time to read all the threads, but I'm APR Stage 3+ and in Pittsburgh. Go to the North East section, then to the "Pittsburgh People" thread.
    We're all willing to lend a hand or half a brain if beer is involved.
    No idea what I am at the wheels, but haven't found many cars in this podunk town that will keep up with me. Not being cocky, as I'm certainly not the fastest, but Stage 3+ in and of itself is pretty quick and damn near what you're looking to put out.
    With built bottom end and race gas, I'd bet you've got it and then some.
    I'm running race gas/93 mix but with Unitronics timing tweaked. Plus, I'm running TP and fully wraped/blanketed hot side and custom ducting.
    I'd venture to say I'm putting out a tad more than a standard GT28RS APR Stage 3+ kit, however I don't even care what that number is on paper. I only care that the other guy can barely read my license plate.
    My 2004.5 APR Stage 3+ is SOLD
    Oct 31 2005
    Virginia
    I'm in the Pittsburgh area all the time, the next time i'm up there I'll have to let you guys know
    ~Josh~
    Apr 24 2005
    E55 AMG, CTS-V
    Because your car can do 140mph does that mean you do it? I will leave you with that.....
    The car will only rev as high as you choose to rev it.
    ~David~
    CTS-V 9.6@148
    Feb 28 2006
    Pittsburgh-Philly
    Bring your bike. Some decent single track around here. Just go slow for me, lol. I raced in top percentage NORBA sport class, but then went through total knee reconstruction and now I'll bet I'm novice at best, lol. And do let us know on the "Pittsburgh People" thread (longest and most viewed thread on AZ), as we're always up for buying beer for out of town guests.
    Feb 06 2008
    i posted a few times in the pittsburgh people thread but my car is pretty stock right now... it was gonna be my daily driver, but i am selling the civic so i am gonna go all out on the audi, and get a beater truck for everyday and to haul my quad... my civic pulls damn hard, and i just want to have atleast that amount of power from my a4..
    RXREP: i would love to check out your stage 3+ car to see if its what i am looking for, or if a custom setup is more my route...
    snailspeed.net
    Oct 31 2005
    Virginia
    ^^will do
    ~Josh~
    Feb 06 2008
    i am talking about camshaft specs... i wanted to know if there are any good aftermarket cams that have a longer exhaust duration so that the turbo spools faster on a BAT setup
    snailspeed.net
    Oct 31 2005
    Virginia
    I'd talk to [email protected] about cams.
    ~Josh~
    Feb 28 2006
    Pittsburgh-Philly
    If I could've gotten in to what the BAT boys are now doing when I bought my kit, I might have gone that route. Simply because I spent that much money anyhow, why not have the biggest turbo around, lol.
    Although, I think my car with the GT28RS sports the best combination of quick... and top end.... for what I want it for. My lag is minimal, and it still pulls like a bitch to redline. I'm at that point where if I wanted that much more, I'd buy a different car to do it with.
    For SCCA and track events, the stage 3+ works awesome, while still being able to go well in a straight line if I wanted to, which I don't. Turning the steering wheel once in a while is what makes it fun for me. I don't live 1/4 mile at a time.
    I regularly beat up on the V8's around here, especially if there are turns involved.
    Anyhow, my car is just out of the body shop today, and I should have it all back together by the weekend. Hit me up sometime if you want to check it out.
    Dec 03 2005
    2 pedals 1FG
    connecticut
    I think Jordan (CO Avant) has the ultimate set-up. APR 3+ hardware with a GT2871R and a 2.0L stroker with fully built head and CAT cams.
    Clint did do is 2.0L stroker for a really good price. Mine will come out similar but I'm paying for the bottom end to be assembled whereas he did his himself.
    -Doug
    Apr 08 2004
    Eating Cheese Curds
    I was giving him background on the APR 3++ software... but good job on trying to look cool.
    An in response to cams.... most of the cams will shift the curve to the right and reduce spool time on a BAT.
    Apr 24 2005
    E55 AMG, CTS-V
    try to look cool give me break besides I know im cool .
    ~David~
    CTS-V 9.6@148
    Feb 06 2008
    rofl.. we drive audi's, we're all cool!! haha
    i am really considering the apr 3 + and building the motor after i find a truck for daily driving.. then maybe the 3++ or something...
    snailspeed.net
    Veteran Member Four Rings 20vturbo's Avatar
    Nov 24 2004
    2004 A4 2.1t, 2015 Q5 3.0t
    MOntreal
    I am selling my apr 3+ kit complete for 3500$ PM if interested
    BetaAlphaTau member #19
    Feb 28 2006
    Pittsburgh-Philly
    Well, the 3+ install in and of itself is very easy. I ripped my 3+ down to the block when I wrapped TP and put turbo in a blanket and I had it all out and back in in like 2 hours.
    There are some tricks I learned from the initial install that helped, so if you're going the 3+ route, let me know and I'd be glad to help out.
    There are some stupid things that you learn the hard way that are so easy if you'd know them up front.
    Apr 08 2004
    Eating Cheese Curds
    Quote Originally Posted by 20vturbo View Post
    is the software included or do you have to pay the 1200 to APR again?
