Results 1 to 35 of 35
    Jun 04 2004
    fairfield cnty, CT
    J31, no FMIC, dumb idea?
    How bad will that be?
    (some people run stage3 with the stock smic)
    Veteran Member Four Rings 94jedi's Avatar
    Dec 07 2004
    Oly Platform, Pendlay bar, bumpers, squat rack, rings, Prowler
    Ocean Shitty Maryland
    Re: J31, no FMIC, dumb idea?
    Quote Originally Posted by ModifiedA4 View Post
    I would say so. you're going to have timing pull like a mofo. J31 turns the k04 into a flame thrower.
    can it be done? probably. is it advisable? NO!
    The harder I practice, the luckier I get.
    - Gary Player
    maybe you could run a water/meth kit instead ? just a thought.
    contact via email please.
    Veteran Member Three Rings khj677turbo's Avatar
    Dec 25 2007
    Tampa
    Where did you find a j31 file?
    Correct me if im wrong but it is a canceled file right?
    Current: 13 A4 P+ Sport, K04 etc, 18 SQ5
    Gone: 04 A4 1.8t USP 6-speed Avant
    Gone: 00 A4 1.8t K04'd
    Feb 27 2005
    North Wales, PA
    PV = nRT says not a good idea.
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    Quote Originally Posted by k0mpresd View Post
    Haha, too bad the stock SMIC will glow like the turbo.
    I would never suggest running the stock SMIC with the J31 file since it runs way more boost then the K05 file he already runs.
    Veteran Member Four Rings Rosati's Avatar
    Nov 17 2004
    B5 Brilliant Black A4 1.8TQM
    Northern New Jersey
    For a reference point, It took me 2-3 hard runs to soak up the stock I/C w. my 28RS at 23 psi
    I think your a bit of a nerd modified so you can do the math
    Honestly, id only do it temporarily
    i remember driving aliel's car (pc16) and this thing was a blast to drive and w/o a fmic its def not gonna be as fun. Price isnt the factor thats holding you back, ill bet its the b/s piping that is.
    * Gone but not forgotten - BTA4 GT28RS w/ all mods 400chp
    https://www.facebook.com/media/set/?...1463643&type=3
    Current: 1994 Mazda RX7 Chaste White
    DIY B5 Head Replacement Guide: http://www.audizine.com/forum/showth...al-and-Install
    Jul 07 2004
    socal
    Quote Originally Posted by Rosati View Post
    Problem is that the J31 runs more timing and 28+psi. At that boost the IAT's coming out of it are much higher then what is coming out of your GTRS at the same boost level.
    The APR stage 3 owners would heat soak the stock SMIC by 3rd gear when drag racing, seen it with my own eyes way back in 2001 at Dubwars.
    Veteran Member Three Rings Grangalan's Avatar
    Sep 27 2007
    Stage III 2001.5 S4
    Clearwater, FL
    heat soak
    --Black 2001.5 -S4- 10secS4 Tuned
    Veteran Member Four Rings VTAudiA4's Avatar
    Oct 20 2007
    You can run it....sorta...not really. Just set your boost low until you do get one.
    Quote Originally Posted by khj677turbo View Post
    You can find them in the classifieds. Thats were I got mine.
    Veteran Member Four Rings Devious27t's Avatar
    Mar 02 2004
    2001.5 S4 Avant on Corn
    Orange County
    it will likely ping.... i would strongly advise against it
    2018 Navarra Blue S5 Sportback
    2001.5 Blue Raspberry S4 Avant w/ hybrids on E85
    Past Audis:
    2015 Glacier White Allroad 2.0T
    2012 Ibis White S4
    2001.5 Nogaro Blue AWE/GIAC Stage 3 S4 16,500 mi
    Fast Intentions Wide Mouth DPs and custom 3.5" exhaust
    2000 Silver A4 Avant 1.9tqm 217k mi.
    2000 T28 A4: SOLD
    Veteran Member Four Rings maxspeed's Avatar
    Dec 14 2005
    Shakedown street, NY
    idk, not to play the devils advocate but we got some pretty gasoline here on the east coast
    2000 Audi A4 1.8TQM - RIP
    1999 Subaru Outback
    When your spirit is floating down that tunnel, towards the light, You know what's behind the light?
    It's not God, it's me. And I'm gonna kick your poncey soul All the way back down the tunnel 'till you choke on your own fucked up ribs! Now, Wake the fuck up!
    Oct 20 2007
    ^ Fo Sho
    Nov 17 2004
    Northern New Jersey
    I see so its not the amount of charge air, its the temp of the charge air
    Yeah thats what i mean, a few runs (gears)
    Jun 04 2004
    fairfield cnty, CT
    got it used. i think everything "B5" is on the verge of being cancelled. [O_O]
    the car is old.
    Jun 04 2004
    fairfield cnty, CT
    based on the replies, i think ill restrain myself from installing the chip until i get an ic solution running.
    In the mean time i want to log a ton of baseline runs so I can compare before and after.
    Dec 14 2005
    im really curious to see how block 20 compares between the two, as its supposedly where all the power comes from
    1999 Subaru Outback
    May 13 2004
    New Jersey
    I ran J31 in the past, and from my experiance I know that you wont be able to even run the motor past 3.5-4krpms since it get heatsoked so fast and it gets throttle cut. I know because i drove the car for a day before i put the fmic on. But besides the point J31 is one of the most fun files, instentanous boost, and if i remember correctly i ran 13.9 at the 1/4 mile track.
    Jun 04 2004
    fairfield cnty, CT
    Quote Originally Posted by maxspeed View Post
    block 20 is just the CFs, I think that requested load (and therefore boost), overall timing, and injector on-time is what im going to get looking at.
    Jun 04 2004
    fairfield cnty, CT
    Quote Originally Posted by marcini View Post
    good to know! what was max req boost in vag com? 2,500mbar?
    Jul 07 2004
    socal
    the car is old.
    I dont know if they converted the J31 file when they went to flash tuning on the 2000. But it isn't like the B5's are being left behind, GIAC is working on doing BT and BAT tuning for the B5.
    Jun 04 2004
    fairfield cnty, CT
    development has mostly died across the board. maybe there are some second tier vendors picking up the slack in some areas, but soon you'll see part shortages and rising prices. (see valeo e-codes)
    Deactivated Four Rings
    Jul 16 2007
    2000 A4 Avant 1.9L BT
    Irvine, CA
    We still have 4 B5's in house, 3 of which are 1.8Ts (2 are avants)
    We have actually considered creating a J31 flash version, if there is enough interest. I know for the hardcore auto-x guys, the J31 seemed to be the weapon of choice. It seems that most prefer to go straight to big turbos these days and that it's more so the K04 market that is dying.
    There will be new version of PC16 coming out soon for the nDBW guys.
    Established Member Two Rings jonrogers42's Avatar
    Dec 30 2007
    Indiana
    just wait and save up 300 bucks and install a fmic off ebay. i got my fmic with piping for 250 and installed in it a night.
    Jul 07 2004
    socal
    Yes I am one of them and as many people know I am not going to let the B5 be left behind.
    Senior Member Three Rings Solaris's Avatar
    Feb 01 2006
    NC
    Quote Originally Posted by Austin@GIAC View Post
    Can you give any information about what has changed in the new PC16 version? Thanks.
    Dec 07 2004
    Quote Originally Posted by Solaris View Post
    It's probably just a bit more refined. the original pc-16 was a bit rough...tq spike like a freight train etc. It probably runs a bit more boost too. Maybe less timing.
    I'm just speculating here.
    - Gary Player
    Established Member Four Rings Yaktizzle417's Avatar
    Aug 05 2007
    2000 A4 1.8TQM
    SpringVegas, MO
    I'll be selling an FMIC and piping soon for a pretty good deally-o
    and an extra A4 front bumper.
    LMK if you wanty wanty.
    ÖMGHI2Ü
    Photography
    Nov 19 2006
    MMM
    Oooh oooh!!! Details!
    What will be the cost for an upgrade? What kind of changes? Any more power?!!
    Jan 17 2007
    2001 A4 1.8TQM, 2009 GSX-R 1000, 1995 Dodge Dakota Sport, 2015 FFR 818
    Quote Originally Posted by Yaktizzle417 View Post
    Specs on the FMIC?
    Aug 05 2007
    2000 A4 1.8TQM
    SpringVegas, MO
    28x7x2.5
    2.5-2.25 pipe conversions- 2.25in piping in the bends that is used on the DIY for it on here.
    ÖMGHI2Ü
    Photography
    Jul 16 2007
    Irvine, CA
    Quote Originally Posted by MikeWasHere05 View Post
    I will have more information as we get closer to releasing the update.
    We are looking to make the fuel delivery more simplified for one. IE. run the injectors at 4 bar.
    More info coming soon.
    Veteran Member Four Rings gotaudi's Avatar
    Jan 26 2006
    2001 A4 1.8T
    Socal
    Unitronic runs 440cc injectors at 4 Bar for the 2001 (which is stock fpr) I dont know how that is simplifying things, I would think it would strain the fuel pump with higher boost applications. I have been hearing about the GIAC BT files, I wish you would have had BT files available about a year ago I would have jumped on that train in a heart beat.
    BetaAlphaTau Member#22
    Mods:
    GTRS Elim+Unitronics+ATP high flow mani+Neuspeed TIP+Custom intake+Labree HFC+Apexi AVC-R+APR Exhaust+Precision FMIC+SB OFE Stage 4+034 street density motor mounts+Purems snub+S4 Front bumper+18" BBS RC rims+Neuspeed race springs+Bilstein shocks+Nuespeed sways=
    73 74 69 6c 6c 20 73 6c 6f 77 <--- Look it up
    Jul 16 2007
    Irvine, CA
    Quote Originally Posted by gotaudi View Post
    Some customers have had a hard time dialing in the A/F perfectly using just a 3bar FPR and have had to resort to tinkering with an adjustable FPR to get it right. We are seeking to alleviate this so that it is pure plug and play.
    Considering what a K04 will draw for fueling, we are not too worried about drying up the pump as it will not flow what your GTRS will.
    Jun 04 2004
    fairfield cnty, CT
    the fueling issues for AEB (PC16) are different than any other model year because of the injector pulse limitations of the AEB ecu.
    are you guys attacking this?
